Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 10-26-2006, 12:50 AM   #1
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
Default Borg Warner S256 and S362 Turbos
I currently have a stock mount GT30R kit with a .63 in my 2.0L Subaru WRX 02, But I will be puting in a S2 2.5L crawford shortblock soon with STI Type C heads .. I am looking for more power that the GT30R can produce with the same spool characteristic as the GT30R turbo on my new 2.5L S2 block....
I was looking to get a GT35R .82 in till I came across a post in Supraforums about Borg Warner turbos and became really intrested in the Schwitzer/Borg Warner S362 turbocharger, with its Extended Tip Technology.
This turbo has the 62mm inducer which is rated at 65 lbs/min, this turbo is designed to work efficiently between 500-650whp. with better spool than the GT35R turbo....
José Savinon
AXA is offline   Reply With Quote
Old 10-26-2006, 01:37 AM   #2
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Any links to more information?
RP31 is offline   Reply With Quote
Old 10-26-2006, 02:35 AM   #3
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
http://www.bullseyepower.com/index.php
Bullseye Power web page info
"Bullseye Power is proud to announce our further association with BorgWarner, having become a national performance distributor for BorgWarner and AirWerks turbochargers"
Old 10-26-2006, 02:39 AM   #4
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
I am leinnig towars the S258 more and more .....
Old 10-26-2006, 02:58 AM   #5
dvang
Member#: 84188
05 legacy
caravan full of kids now
this part is a bit interesting too, for the bolt on guys tho
http://www.bullseyepower.com/wrx_turbos.php
dvang is offline   Reply With Quote
Old 10-26-2006, 03:01 AM   #6
v rod
Member#: 17575
2005 sti
cgm
these turbos look real tempting!
my friend will be trying out two s200's on his nsx. can't wait for his results!
v rod is offline   Reply With Quote
Old 10-26-2006, 03:03 AM   #7
v rod
Member#: 17575
2005 sti
cgm
does anyone have results with the 50 trim yet?
Old 10-26-2006, 07:48 AM   #8
pux888
Member#: 8356
02 STi swap
12 WRX limited
Im sure its output would be very similar to a green.
pux888 is offline   Reply With Quote
Old 10-26-2006, 11:59 AM   #9
davidm_sh
Member#: 5994
2004 Impreza WRX STi
Java Black
Just an FYI folks-
TEC - www.turboengineering.com
http://www.turboengineering.com/cust...ies/ht300.html
Has been dealing with Borg-Warner/Schwitzer for the past 3 years or since I have know him. I know a couple of people who have the HT series turbos on their STi blocks up here at high altitude and they perform VERY well. They are right there with the GT35R series turbos but are better IMHO given their wider efficiency islands and higher PRs. From my recollection they usually edge out the GT35R setups up here on pump gas.
I know one person up here with a street trim STi running I believe a HT200 @ 20-22psi (spring pressure with EWG setup) broke into the high 11s on pump gas up here at 5800ft asl!! The person isn't even that big of a drag racer either!! Xephyr runs one of these turbos as well. Super Rupair sells them still I believe and Harvey (the tuner) there could give more details on the power they make in his experience. I am only going off of second hand information on the power they have made from what he was told me.
If I were to go rotated mount this is the turbo series I would go with from what I have seen.
davidm_sh is offline   Reply With Quote
Old 10-26-2006, 12:11 PM   #10
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
Errol from TPS ( autorize dealer for BW turbos):"The S256 will tear that gt35r up. Out spool and out flow".....
Woa.. I think I found my new turbo...
Old 11-04-2006, 10:25 AM   #11
TurboDXsti
Member#: 106671
2006 Sti
grey
Yea I've been contemplating this turbo for a few months now , glad to find this post , BTW does anyone know if the turbo can be used with the Perrin rotated mount piping kit ?
TurboDXsti is offline   Reply With Quote
Old 11-04-2006, 11:45 AM   #12
InfamousDX
Member#: 25413
Well some of the Subaru guys need to get these so we can get some results!
Old 11-04-2006, 11:53 AM   #13
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
Default S200 Turbo
According to TPS is a perfect fit ,when you order this turbo with the correct exhaust housing for your application.. In my case I will have to order the t3 five bolt exhaust housing .... BW recommended a .55 AR exhaust housing with the S256 do to the long manifold runner we have in our cars and the cold temperature of the exhaust gasses in our cars..
My compressor cover in my GT30R is 7.1/4 inches and the S256 is 7.1/2 inches ..... Not much off a difference between the two...
I will provably will order my turbo in a few weeks , I am giving time to see how the stainless steel hold up compare to cast Iron in the exhaust housing.... I
Jose Savinon
Old 11-04-2006, 11:58 AM   #14
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
Take a look ....
http://www.bullseyepower.com/s200_acura.php
Is not a Subaru but great numbers with the new S200 extended tip turbo ....
Remeber this is a 1.8 car .....
Old 11-04-2006, 11:58 AM   #15
TurboDXsti
Member#: 106671
2006 Sti
grey
so as long as I get the S256/ S258 in a t3 trim with 4 bolt exhaust housing , it should bolt up to the perrin piping kit ( uppipe & down pipe) ?
Old 11-04-2006, 01:33 PM   #16
modaddict
Member#: 95840
sold to a good bud
awaiting next car
didn't clark chime in, in the other thread?
i too, would like to see how these perform on more suby's
modaddict is offline   Reply With Quote
Old 11-04-2006, 02:13 PM   #17
solarin006
Member#: 109975
Is the borg warner a 3" 4 bolt? Perrin uses a 2.5" 4 bolt on their DP.
solarin006 is offline   Reply With Quote
Old 11-08-2006, 10:08 AM   #18
IPT
Member#: 23300
1996 Talon TSi AWD
It is the 2.5" bolt pattern. Just like Perrin uses.
IPT is offline   Reply With Quote
Old 11-29-2006, 11:06 AM   #19
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
New test on the BW turbo.....
Check this out...
S200 Vs GT30R turbo .... HP, Boost and Torque....
http://www.bullseyepower.com/forums/viewtopic.php?t=87
Data like this is making me a believer.......
Jose
Old 11-29-2006, 11:46 AM   #20
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
Jose Savinon
So the S200 is basically like a GT30R?? If so, the .63ar on the GT30R is to small and causes to much back pressure. So why would going with an even smaller ar on the S200 work??
SloRice is offline   Reply With Quote
Old 11-29-2006, 11:48 AM   #21
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
Check this out...
Jose
totally useless info. The S200 makes 10-15whp more than the GT30R at 1psi more boost.
Old 11-29-2006, 12:00 PM   #22
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
I agree Tim. I see no advantage over the 30R.
Clark
AZScoobie is offline   Reply With Quote
Old 11-29-2006, 12:09 PM   #23
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
I better not get into this .................
Old 11-29-2006, 01:14 PM   #24
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp 9.91@146
I'm not knocking on you or trying to create a pissing match. I'm just looking at the data provided in the multiple links in this thread and I'm not seeing an advantage. The only difference I saw was the S200 came up to 21psi 300RPM prior to the GT30R.
But! If you know how Mustang Dyno's and Suby's get along (like I do), you'll know that they probably used dyno roll speed to get an RPM pickup, which makes comparisons based on RPM almost impossible unless you know the exact roll RPM to vehicle RPM calibration # and use it for both runs, which most tuners don't.
Old 11-29-2006, 01:47 PM   #25
TurboDXsti
Member#: 106671
2006 Sti
grey
guess i know what i'm getting for christmas now
FS:Custom Rotated Borg Warner S256 TurboWRX32 MAIC Private Classifieds 18 03-15-2010 07:09 PM
FS: Custom Borg Warner s256 Rotated Set-up TurboWRX32 Engine/Power/Exhaust 10 03-15-2010 07:08 PM
Borg Warner S256 Rotated Build UpSideDownDesi Proven Power Bragging 122 08-09-2009 01:32 AM
Borg Warner S256 turbo - ~400whp cornerbuddy28 Engine/Power/Exhaust 17 07-31-2008 05:53 PM
Brand new Borg Warner S256 turbo garagedefeat Engine/Power/Exhaust 54 11-13-2007 05:18 PM
Message Board Statistics All times are GMT -4. The time now is 07:11 AM.
