Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 10-26-2006, 05:46 PM   #1
Mustang Raper
Member#: 84388
2002 WRX,FPG,6MT
Sedona Red Pearl, Carbon
Default Where to start with tuning.
Just bought a Utec, installing tonight, my question is, where do i start with the tuning, it is loaded with stage 2 base maps, and I would prefer not to spend the money on a protune til I finish modding my car.
Current mods:
3in TBE,
EBC,
K&N drop in
intake silencer delete
Atm. BOV
Near Future Plans:
Catless uppipe,
Big TMiC,
800 CC Injectors,
Walbro 255,
Vf39 turbo,
I am located at about 4000ft above sea level, and am able to get a hold of only 91 octane. Where should I start?
Mustang Raper is offline   Reply With Quote
Old 10-26-2006, 06:08 PM   #2
Gethin
Member#: 2998
IMHO do the uppipe before you up the boost. The TurboXS basemaps are just to get you started, timing is for 93 octane and you will probably get knock if you just use the basemap off the bat with 91 octane, they need to be tweaked pretty heavily from the get go. They run usually very rich for safety (the stage 2 map I used dipped into the 9's as an example).
With no wideband, the only thing you can tweak really is the boost map along with the ABC/EBC to reach your boost targets, as per the TurboXS manual, and I wouldn't do that before changing the uppipe.
If you have not tuned a car before, you have a LOT of reading to do! Start with the manual, read it 5 times, then also look at Mick the Ginge's tuning guide too, even though it does not cover some of the newer features in the new firmware.
Gethin is offline   Reply With Quote
Old 10-26-2006, 06:15 PM   #3
Mustang Raper
Member#: 84388
2002 WRX,FPG,6MT
I know that there is alot of work to be done changing the maps. I figured take the timing down across the board cause of the 91 octane. And, the uppipe is going on first and then the TMIC, both of which are in the mail and will be arriving soon. Should I move up the the stage III base maps by TXS?
Old 10-26-2006, 06:54 PM   #4
Gethin
Member#: 2998
I'd stick with the stage 2 until the other bits come in. I'd take a few degrees out across the board with 91. Also make sure you datalog with that EBC in there to make sure your boost is under control. I'd also use the stock BPV for now (and forever )
Old 10-27-2006, 03:48 PM   #5
Mustang Raper
Member#: 84388
2002 WRX,FPG,6MT
Ok, so even though the base maps are written specifically for the mods I am going to have I should stay with the stage II? Anything else that might be helpful for me to know about?
Old 10-27-2006, 07:16 PM   #6
HonduHunter
Member#: 28408
2002 vf48ed WRX
i think you should go stage 3 when you get the TMIC
HonduHunter is offline   Reply With Quote
Old 11-05-2006, 10:10 PM   #7
Mustang Raper
Member#: 84388
2002 WRX,FPG,6MT
So I got my Utec installed and it seems to be working fine. Need to retard the timing though, think I hit knock last night. Any other opinions on which maps to start with?
Old 11-06-2006, 12:03 AM   #8
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Start with stage II, since that's what those mods put you at. And take the advice in post #4. Do you have a wideband O2 sensor?
RP31 is offline   Reply With Quote
Old 11-06-2006, 02:37 PM   #9
Mustang Raper
Member#: 84388
2002 WRX,FPG,6MT
Wideband is on the way. I am now at stage 2, the question is when i get the IC should I go to stage III?
Old 11-06-2006, 02:45 PM   #10
RP31
Member#: 123574
CGM STi
Yes you should, because that is what TXS considers to be stage III.
Where to start with upgrading and what to do Nate_1990 Newbies & FAQs 7 04-23-2010 02:13 AM
Where to start with map for the StreetTuner roybfr AccessPort 3 04-09-2006 11:55 PM
where to start with 16g turbo? prometheum UTEC 3 04-01-2006 10:53 AM
just purchased a 05 STI where to start with mods? 1 BLOWN V8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 07-29-2004 02:31 PM
Where to start with my 2000 Outback Wagon? Justin Tyme Noren Legacy Forum 3 04-12-2002 08:46 PM
