Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 11-06-2006, 11:54 AM   #1
Drink
Member#: 102682
... ripper's
sister.
Default Boost control problem with GM solenoid
Please help a utec noob
Pertinant mods...
Wrx heads
257 block
td04
Full exhuast
Intake
Inlet hose
FMIC
Walbro
GM solenoid
I'm having problems controlling boost with my GM solenoid. 1st and 2nd gear are spot on. 3rd gear + is where I hit target boost, then shoot right past it and spike at 20psi.
I can't seem to get it to limit boost under load though.
(No logs to provide yet) 170 @ 100% load nets me 20psi. It was drastically reduced to 170 for the 70% load columns+, but it won't control boost at ALL. The abc is also closed all the way. Don't know where to go from here.
Drink is offline   Reply With Quote
Old 11-06-2006, 11:57 AM   #2
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
you have teh AIDS. Reply FTW
His boost goes up and down. Hits 10, jumps to 20, back to 10 pSI. It's very wierd. Ill post his logs tonight.
NITROS is offline   Reply With Quote
Old 11-06-2006, 01:49 PM   #3
TwoFive
Member#: 72511
08 Acura RDX
What is your gain set at?
TwoFive is offline   Reply With Quote
Old 11-06-2006, 04:40 PM   #4
NITROS
Member#: 41561
04 GT3076 2.1
Gain should be set at 48. He is using my map as a base, with my parameters.
Old 11-06-2006, 10:15 PM   #5
Strng1dah
Member#: 7053
[email protected]
1 - Double check all wiring/vac hoses. I know it is simple to install the GM BCS, but it can't hurt to double check.
2 - Try reducing the gain down to the 20 range. I've had much better sucess with it down there.
3 - Reduce your boost values when you reduce the gain. Mine are in the 160 range, so I wouldn't expect you to have to move them too much.
Strng1dah is offline   Reply With Quote
Boost dips quickly between 4,500-5000rpms with GM solenoid PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-16-2007 10:58 PM
Need Help with Boost control Problem sz49/EWG/MBC Zornorph Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 03-11-2007 09:32 AM
bad boost spike with GM Solenoid, and utec ZR2_S10 UTEC 13 05-18-2006 01:31 PM
Problem with "Shifter Solenoid circuit." Hamsterstyle Transmission (AT/MT) & Driveline 2 10-30-2004 12:57 PM
Boost Controller that uses stock solenoid ? Xeno Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-27-2002 12:10 PM
