Old 10-27-2006, 10:19 AM   #1
timberwolfmedia
Member#: 129060
2007 STI
Default mystery oil leak
i have an 02 wrx and im loosing about 500ml of oil every 3 days. none on bottom of engine, car doesnt smoke, the only oil i see is a small amount of oil residue on the charge pipe coming from the turbo and on the bottom of the turbo, but it looks old and crusty. any ideas?
timberwolfmedia is offline   Reply With Quote
Old 10-27-2006, 02:32 PM   #2
WRXRgr
Member#: 54942
2004 WRX
You're going thru a quart of oil a week?
...what kind of mileage & speeds are you typically running?
WRXRgr is offline   Reply With Quote
Old 10-27-2006, 03:20 PM   #3
timberwolfmedia
Member#: 129060
2007 STI
i drive about 400mi a week at 70mph
Old 10-28-2006, 04:09 PM   #4
timberwolfmedia
Member#: 129060
2007 STI
bumnp
Old 10-29-2006, 05:12 PM   #5
timberwolfmedia
Member#: 129060
2007 STI
bumnp need answer
Old 10-29-2006, 06:25 PM   #6
devil13
Member#: 80559
2011 WRX
oil in the charge pipe is normal. how many miles on engine. do a compression test.
devil13 is offline   Reply With Quote
Old 10-29-2006, 09:23 PM   #7
2$SPIFF
Member#: 78437
2002 WRXWag 16.5 PSI
Rally Blue
I recently installed uppipe, downpipe and headers and brought it in to get serviced and protuned. My tuner found an oil leak, which i thought was from the filter but turned out to be my main valve cover gaskets and seals. They were replaced for around $200. My car had about 72k miles and is also an '02.
- Pete
2$SPIFF is offline   Reply With Quote
Old 03-10-2007, 02:45 PM   #8
timberwolfmedia
Member#: 129060
2007 STI
i never did solve this problem, i took it to subaru today,and they said there was a TINY leak from the valve cover gaskets, but not big enough to loosea qt a week. they suggested that the engine may be burning oil, however, there is no oil smell in the exhaust, and there is no smoke. i get a small amount of black smoke from the rich fuel mixture when i floor it but thats it.
Is it possable to loose a quart a week out of the exhaust without seeing smoke? i only have the factory uppipe, and i replaced the DP with a HKS. the cats looked very cleam and white, no residue in them.
Old 03-10-2007, 03:00 PM   #9
timberwolfmedia
Member#: 129060
2007 STI
if i do need to replace the rings, what are the special tools i will need for the subaru engine?
I have a new clutch, new timing belt, complete engine gasket set, fluids, PB blaster, Torque wrench, main bearings. what elese should i have?
Old 03-10-2007, 07:47 PM   #10
timberwolfmedia
Member#: 129060
2007 STI
bumpy
Old 03-11-2007, 08:00 AM   #11
meglissWRX
Member#: 115965
not low enough for
nasioc mbr #001
bump for a similar problem. i lost all my oil and blew mine up.
also an 02 with 72k miles
meglissWRX is offline   Reply With Quote
mystery oil leak jclarkwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-24-2008 11:27 PM
HELP!! Header install, now mysterious oil leak from turbo area!! All4bSpinnin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 10-25-2007 03:22 PM
EJ22 Mysterious Oil Leak whitet777 Service & Maintenance 76 05-29-2007 10:54 PM
Mysterious Oil Leak, please help. C J Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 12-14-2006 03:35 PM
mysterious oil leak - need help WRXIN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-03-2003 12:08 PM
