10-27-2006, 10:42 AM | #1 |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
For Hydra users that still have a DeltaDash license...
Take your Hydra log file, change the name of the first column from "timestamp" to "Time", and then you can load that log file up in DeltaDash!
Why would you want to do this? Normally, I use DataLogLab for quick and easy log viewing, but DLL doesn't have 3D graphing yet. DeltaDash does!
10-27-2006, 01:42 PM | #2 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
Nice catch.
10-27-2006, 01:49 PM | #3 |
Member#: 8512
South East
Hm, doesn't work for me with 2.14v11 .XLS files converted to .CSV.
10-27-2006, 01:50 PM | #4 |
Member#: 27108
Hmmm... I'm using DeltaDash version 2.00.123 ... what version do you have?
10-27-2006, 02:21 PM | #5 |
Member#: 8512
South East
Not only that, but when I try out Data Log Lab on a CSV file exported from Excel, it reads it all wrong when I suggest Nemesis 2.1 CSV as the file type.
jblaine 0, software 2 |
10-27-2006, 02:21 PM | #6 |
Member#: 8512
South East
10-27-2006, 02:55 PM | #7 |
Member#: 27108
I save my Hydra log files as CSV files from the get-go. I don't bother with Excel unless I'm trying to do something fancy, and even then, I'm loading up the plain CSV file in Excel.
Try playing with this..? Code:
timestamp,coolant temp (C),AFR (:1),engine speed (rpm),tps (%),boost (psi),vehicle speed (kph),knock ramp (V),air temp (C),duty cycle (%),knock ret. (deg.),wastegate PID (%),cell X (n),cell Y (n),fuel pulse (ms),vacuum (mmHg),advance (deg.) 0,88,14.2,2550,19.2,0.0,20,0.36,25,7.6,0.0,0.0,6,7,2.9,222,42 248,88,14.2,2600,19.6,0.0,20,0.36,25,7.6,0.0,0.0,7,7,2.9,222,43 496,88,14.1,2650,19.6,0.0,21,0.60,25,7.6,0.0,0.0,7,7,2.9,222,43 744,88,14.1,2650,20.0,0.0,21,0.46,25,7.6,0.0,0.0,7,7,2.9,222,43 1000,88,14.0,2700,20.4,0.0,21,0.48,25,7.6,0.0,0.0,7,7,2.9,210,43 1080,88,14.0,2700,20.0,0.0,22,0.38,25,7.6,0.0,0.0,7,7,2.9,222,43 1160,88,14.0,2750,20.0,0.0,22,0.40,25,7.6,0.0,0.0,7,7,2.9,219,43 1240,88,14.0,2800,20.4,0.0,22,0.62,25,7.6,0.0,0.0,8,7,2.9,231,43 1320,88,14.2,2800,19.6,0.0,23,0.48,25,7.6,0.0,0.0,8,7,2.9,231,43 1400,88,14.1,2850,18.8,0.0,23,0.32,25,7.6,0.0,0.0,8,6,2.9,246,44 1480,88,14.1,2900,16.4,0.0,23,0.46,25,7.2,0.0,0.0,8,6,2.6,270,44 1560,88,14.1,2900,16.0,0.0,23,0.46,25,6.8,0.0,0.0,8,6,2.6,297,44 1640,88,13.9,2950,14.4,0.0,24,0.58,25,6.8,0.0,0.0,8,5,2.2,318,44 1720,88,13.7,2950,12.4,0.0,24,0.52,25,6.4,0.0,0.0,8,5,1.9,348,44 1800,88,13.6,2950,11.2,0.0,24,0.38,25,5.6,0.0,0.0,8,4,1.9,390,44 1880,88,13.5,2950,8.4,0.0,24,0.64,25,4.8,0.0,0.0,9,4,1.6,435,44 1960,88,13.2,3000,6.8,0.0,24,0.52,25,4.4,0.0,0.0,9,3,1.3,483,44 2000,88,12.9,3000,0.0,0.0,24,0.54,25,4.4,0.0,0.0,8,3,1.3,534,44 2080,88,12.5,2950,0.0,0.0,24,0.40,25,3.2,0.0,0.0,8,2,1.0,567,42 2160,88,11.9,2850,0.0,0.0,24,0.50,25,3.2,0.0,0.0,8,2,1.0,582,42 2240,88,11.2,2800,0.0,0.0,24,0.34,25,2.8,0.0,0.0,7,2,1.0,585,42 2320,88,11.0,2700,0.0,0.0,24,0.42,25,2.8,0.0,0.0,7,2,1.0,591,42 |
10-27-2006, 03:09 PM | #8 |
Member#: 8512
South East
Yeah, that wasn't an option until I bitched. Excel was required. I just got in the habit of it now, but I will probably start exporting to CSV straight from the Hydra interface.
I'll give your data a shot. |
11-01-2006, 08:23 AM | #9 |
Member#: 11926
Vehicle:2011 Outback Limited Dark Grey |
so hydra has no data logging capabilities?
11-01-2006, 09:06 AM | #10 |
Member#: 8512
South East
Sure it does.
It has no data analysis or graphing capabilities. |
11-14-2006, 02:40 PM | #11 |
Member#: 8512
South East
x99percent:
Export to "CSV file" (specifically) was not an option for 2.1 Hydra users without the latest 2.1 reflash. I just got mine done and see the export option you were using. Before the reflash, there was only "Excel" and "Text file" (which actually was a CSV text file...) as options. |
A Few Questions For Hydra Users | shvrdavid | Other Engine Management | 4 | 10-20-2007 08:50 PM |
Question for hydra users in the DC Metro area | Shabib67 | Mid Atlantic Impreza Club -- MAIC | 5 | 03-16-2006 01:46 AM |
2002 wrx brake pads for street/track that still work in winter | Impreza01 | Brakes, Steering & Suspension | 28 | 11-13-2005 09:46 PM |
anyone have a deltadash that I can borrow in md? | mpower22 | Mid Atlantic Impreza Club -- MAIC | 4 | 06-04-2005 07:57 PM |
To those that still have a stock downpipe... | Spool_up | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 09-17-2004 12:25 PM |
