Old 10-27-2006, 05:55 PM   #1
crystal_freak
Member#: 108010
Default Blouch Dom III
per the blouch web-site
"Looking for Garrett GT full ball bearing performance and efficiency that bolts-on to your WRX/STI? Look no further! The turbo experts at Blouch Performance Turbo have developed this custom performance upgrade to set your Subie project apart from the rest! Initial dyno results indicate substantially quicker spool than the stock VF-39 with significant gains in horsepower and torque. The Dominator III features a state-of-the-art 52 lb/min Garrett GT compressor wheel, a high efficiency Garrett GT turbine wheel, Garrett GT full ball bearing system and adjustable upgrade wastegate actuator calibrated at 15 PSI."
quicker spool than a VF39 with a 52lb turbo?!?!?!?!??? even with the gratest of all voodoo magic, i dont see this happening. i know this was on an STI but still!
thoughts.
crystal_freak is offline   Reply With Quote
Old 10-27-2006, 06:04 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Might be possible if they used a really small exhaust turbine housing.... Would severly limit top end though.
Which it doesn't look like they did (after I checked the website), so they are full of crap saying it'll spool faster than the stock turbo.
Old 10-27-2006, 10:22 PM   #3
drumr78
Member#: 43449
2015 STi
I have the Dominator III and it hits 24psi at 3800rpm and holds 24psi to redline. So, they seem to know what they are talking about since the vf-39 i had only would hit 18 psi by 3800rpm and then taper down to 15psi by redline. Both Turbos were run on 93 oct gas and also dyno'd on the same dyno.
drumr78 is offline   Reply With Quote
Old 10-28-2006, 01:38 AM   #4
WRXShawn
Member#: 35742
2002 PPG + FPGreen
they can say stock turbo and that could mean that the stock downpipe is also in place, (2 cats). If the dominator III spools the same on a catless setup as a VF39 spools on a stock setup, I think they have the right to make that claim. So it seems fair to me.
BTW, this doesn't apply to a 2.0L forum b/c Blouch has only tested this turbo on 2.5L engines. (I emailed and asked them months ago)
WRXShawn is offline   Reply With Quote
Old 10-28-2006, 10:47 AM   #5
crystal_freak
Member#: 108010
drumr78-
are you running a 2.0l or 2.5?
Old 10-28-2006, 10:57 PM   #6
drumr78
Member#: 43449
2015 STi
Originally Posted by crystal_freak View Post
drumr78-
2.5l stock block '04 STi.
Blouch Dominator III Turbo
stromung DP
cat delete
Apex'i GT SPEC cat back
K&N Typhoon
Helix 860cc injectors
walbro 255lph fuel pump
TurboXS FMIC and BOV(recirc)
GM Boost Solenoid
One step colder plugs
COBB protune by Agile Auto
Custom made turbo heat shield and turbine heat wrap.
402whp and 383wtq on 93oct @ 24psi holding to redline
that's all the info about my setup
Old 12-15-2006, 03:42 PM   #7
Golfa
Member#: 21394
Sold 2004 STi
08 WW Evo X
what is this turbo comparable to? what is it better than?
Golfa is offline   Reply With Quote
Old 12-15-2006, 04:44 PM   #8
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
To answer: a lot and a lot, you can't compare turbo vs. turbo in the real world. Read the Turbo FAQ for more info on comparing turbos.
Blouch Dom III issue... Stames_wiltz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 09-11-2008 02:25 AM
Feeler-blouch Dom Iii stretchedk7 Engine/Power/Exhaust 1 04-03-2008 08:50 PM
Blouch Dom III 04 STI orionh2215 Proven Power Bragging 50 02-17-2008 10:14 AM
07 Sti Blouch Dom. III 1/4 times hova Proven Power Bragging 11 10-11-2007 06:47 PM
GT52 vs. Blouch Dom III...Which spools faster? bulgarianfreak55 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-16-2007 10:07 PM
