Old 10-27-2006, 10:51 PM   #1
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
Default Multiple tire setup on an 8" and 8.5" wheel on an STI
so, i have this 06 STI ... and i've been playing w/ different tire setups.
i actually have the following setup:
(stock setup)
18 x 8, e48 w/ 235/40/18 S03 w/ swift springs
18 x 8.5, e48 w/ 255/40/18 rt615 w/ swift springs
18 x 8.5, e48 w/ 245/40/18 (yet to drive on)
wondering any other folks out there w/ a similar setup... @least a setup from a 235 to a 255 tire setup as above...
i really like the stance, however, on my 40 min. commute home everyday i go through this freeway we have here that is not in the best condition (specially in california standards)... 680 between pleasanton and fremont for the local peeps... the car seemed to take a longer time for the car to settle when i hit a bump @ high speeds... when i went from the 235 to a 255... same setup... i changed the camber and the wheels/tire since i've made the change.
i guess w/ more tire, the ride does feel pretty smooth... though i can already tell that my Gas milage is getting killed... not so much from the drag of the tire... but the fact that i'm hanging every possible corner
current stance as she sits outside...
just trying to compare notes.
-sd
suby_dude is offline   Reply With Quote
Old 10-27-2006, 10:55 PM   #2
import111
Member#: 24447
2010 Evo GSR
GG
Have you taken any hard corners with (18 x 8.5, e48 w/ 255/40/18 rt615 w/ swift springs) that setup? Any rubbing in the rear?
import111 is offline   Reply With Quote
Old 10-29-2006, 12:56 AM   #3
suby_dude
Member#: 17397
WRB, White
not after i cambered the rear... i'll post alignment settings on monday i left it @ the shop.
-0-sd
Old 10-29-2006, 08:11 PM   #4
MartinD
Member#: 57231
yep you need to sell me those wheels after sema.
MartinD is offline   Reply With Quote
Old 10-29-2006, 08:54 PM   #5
PRODRIVEN
Member#: 111
1999 Impreza 2.5 RS
EJtwentyfied -> '04 STi
Forget the tire setup. I want info/more pics of the rear lip
PRODRIVEN is offline   Reply With Quote
Old 10-29-2006, 09:33 PM   #6
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
i feel that 255/40/18 is too tall on a Subaru, even on an Evo. if u want a taller sidewall i'd stick with 245/40/18 or 265/35/18. i have 235/40/18 Azenis on my WRX with stance coilovers and i work in downtown san francisco. its really not that bad. it also depends on ur suspension setup. if u have springs on stock struts its gonna be a little bouncier than coilovers.
ommmjido is offline   Reply With Quote
Old 10-30-2006, 04:58 PM   #7
RainMaker
Member#: 93301
06 CGM STI SM#17
Now with alot less verve!
Here's a silly question...
What do you think would happen if you put 275/35/18s on the 18x8.5's?
I've essentially got that setup coming, but on a et45
RainMaker is offline   Reply With Quote
STi fitment of 255/40/17s on Rota 8.5" wheels 2phless Tire & Wheel 25 04-19-2006 03:27 PM
8.5" Wheel on a GM6 2.5RS? serendipity Tire & Wheel 8 11-29-2005 04:32 PM
8" or 8.5" Wheels on STI w/ Pinks roybfr Tire & Wheel 10 04-05-2005 01:19 PM
understanding the 8" or 8.5" wheel Bundyboyz Tire & Wheel 12 10-05-2004 09:12 AM
Is an 8.5" wheel to wide for the STi? essogas Tire & Wheel 39 01-15-2004 11:13 AM
