Old 11-09-2001, 07:47 PM   #1
elemental
Member#: 2701
'00 obs
Unhappy problem: very bad bad sound. =(
injen used my car as a prototype car for the intake and now there's something wrong, i dont think it is as a result of the intake but it happened while in their possession, just wondering what the problem might be... it doesn't sound very good at all.
my car was making a clacking noise that's coming from somewhere in the middle of the engine bay... it is rpm dependent, the higher the rpms, the faster the sound goes off... but the sound has somehow gone away now and the noticeable difference now without the clacking sound is that the car shakes alot (as opposed to it not shaking at all since the boxer engine is so balanced) but now it shakes a bunch but sound normal.
someone has already told me it might be a spun bearing could this be true, as a result of low oil which i'm not sure should have been the problem since i only changed the oil about 3.5k miles ago, but now that sound is gone so i dont know what he'd say. anyone? would the sound of a spun bearing go away? or is it something else?
thanks
gonna take it to a dealer on monday i guess, cuz i know SOMETHING's wrong, just wanted to know if you guys had a similar problem at all... the car only has about 34k mi. on it anyways
elemental is offline   Reply With Quote
Old 11-09-2001, 08:37 PM   #2
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Do you get the clacking sound all the time, or do you only get it when the engine is either hot or cold?
Richard
http://www.whitetyphoon.com/impreza/
Richard L. is offline   Reply With Quote
Old 11-09-2001, 10:20 PM   #3
elemental
Member#: 2701
'00 obs
it was all the time, but now it's gone, unless it takes about an hour's drive to warm it up (yes, i know i shouldnt have driven it, but there was nothing i could do). but then, even if it was something temporary, there's something still wrong with the whole shaking deal and the engine just sounds funny (hard to describe).
Old 11-10-2001, 12:11 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Make sure you have the stock intake on the car before you take it to the dealer and you should be good to go. I couldn't tell you what the noise is, but with only 34k miles on the car you're well under warranty. Time for a new short block perhaps?
Pat Olsen
'97 Legacy 2.5GT sedan
Old 11-10-2001, 12:22 AM   #5
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Sounds like the infamous cracked piston - check your oil consumption, take to dealer, cash in your savings bonds...
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 11-10-2001, 01:48 AM   #6
elemental
Member#: 2701
'00 obs
wow, you guys are being depressingly serious... this intake would be the first power mod i've ever had on it and the pistons are cracking or something of that level... errrrrrrrrrrg, sounds not fun
Old 11-10-2001, 01:57 AM   #7
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
A spun bearing should not cause your engine to shake. I'm guessing you have a bent connecting rod or a broken motor mount.
Richard
Old 11-10-2001, 02:14 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
well a spun bearing WILL make a clicking noise to the point where once the bearing works itself out it could easily make the engine misfire and vibrate.
But it could also be a broken motor mount..is the MIL(CE Light) on?? Yes or no??
jeremy
Old 11-10-2001, 10:50 AM   #9
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
also a leaking timing belt tensioner will cause a knock noise in the engine.
dave
mspt
PerformanceAutoSolutions is offline   Reply With Quote
Old 11-10-2001, 11:53 AM   #10
elemental
Member#: 2701
'00 obs
that's exactly it, and yes, the CEL is on, although it only turned on after it started misfiring and shaking.
Old 11-10-2001, 12:53 PM   #11
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
I have a HUGE crack in my borla header. The engine makes this "clacking" noise while it's cold, but it then goes away at the engine warms up (the steel expands and the crack closes). It has caused a CEL and the engine vibrates noticably because of this (don't ask me why, though....).
Check for exhaust leaks...
--Roy
LUME is offline   Reply With Quote
Old 11-10-2001, 12:58 PM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
have you had a chance to figure out what code is stored in there??
I rec putting your factory airbox back on and take it to the dealer.
Jeremy
Old 11-10-2001, 01:23 PM   #13
elemental
Member#: 2701
'00 obs
yea, that's what i'm going to do, dealer's closed till monday though.
Old 11-10-2001, 07:56 PM   #14
elemental
Member#: 2701
'00 obs
i should probably know this but do you guys know what the notch, top mark and bottom mark on the dipstick represent in quarts remaining? the last oil change on the car was done by the dealer for the 30k service, it's been just about 3000 miles since then and if they filled it to 4.7 quarts (spec) and it was a little lower than the low mark when the problem happened (must have started eating oil quicker this week because last week it was about midway between the marks, it would have lost more than 3 quarts im guessing. and i did a search on the board, SOA seems to only care if it eats more than a quarter per 1000 miles so im wondering if i can argue this case or not? thanks.
Old 11-12-2001, 02:53 AM   #15
elemental
Member#: 2701
'00 obs
and what does 'work itself out' mean, what is the bearing working out??
Old 11-12-2001, 03:15 AM   #16
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
spins out from between the rod cap and the crank shaft journal.
Jeremy
Old 11-12-2001, 02:09 PM   #17
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
The distance between the top mark and the bottom mark usually represents one quart. If the top mark in your case is 4.7 quarts, then the bottom mark is 3.7 quarts remaining.
Richard
Old 11-12-2001, 03:14 PM   #18
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
yes and with 3.7 qt's remaing and high rev's/hard cornering you could EASILY starve the oil pump.
jeremy
Old 11-12-2001, 03:52 PM   #19
elemental
Member#: 2701
'00 obs
k, well, it wasn't me driving when this happened, i let a company borrow the car to prototype an intake for it and they must have driven the damn thing hard in the 5 miles they put on the clock.... and i'm not sure if i can get them to compensate me or not, i didn't sign anything waiving my rights but nothing to guarantee a working car back either. so.... i have to get some advice on that.
but the car's at the dealer getting checked as we speak, mechanic has like 10 cars waiting before mine so it might be until tomorrow before we know for sure what's wrong.
Old 11-12-2001, 04:01 PM   #20
p-car
Member#: 5534
2000 Cliffdiver RS
Didn't they tell you what they were gonna do with your car?
Did they ran the car on a dyno, go to the drag strip with a g-tech or what?
p-car is offline   Reply With Quote
Old 11-12-2001, 05:44 PM   #21
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
Just don't tell the dealer about letting someone use your car as a test car. Your engine/powertrain (5 year/60k miles) should cover whatever the problem is.
Good luck with getting it fixed.
-Matt
jhonas is offline   Reply With Quote
Old 11-12-2001, 11:12 PM   #22
Aspen_2.5RS
Member#: 3310
Post
This is kind of off the top of my head, but I think the spec is 4.2 quarts. Please correct me if I'm wrong. My book is out in the glovebox.
Aspen_2.5RS
Aspen_2.5RS is offline   Reply With Quote
Old 11-13-2001, 02:13 AM   #23
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Yes, spec is 4.2 quarts for MY00-01 2.5RS. I'm not sure about MY98 2.5RS though. If it's the same, then 4.7 quarts is too much oil, which could cause foaming and ultimately reduce lubrication to bearing surfaces.
Richard
Old 11-13-2001, 04:11 PM   #24
elemental
Member#: 2701
'00 obs
it says 4.7 in my manual, so i guess they take different amounts.
Old 11-13-2001, 07:38 PM   #25
Teh Legacy
Member#: 9853
to keep your mouth
shut.
the clicking sound may be a bad lifter. have you been running it like a teenager?
Teh Legacy is offline   Reply With Quote
Engine RPM falls very slowly / bad throttle resp. spectre_25gt Legacy Forum 15 04-16-2006 07:19 PM
Very loud popping sound! volkl23 Car Audio, Video & Security 4 09-29-2004 11:59 AM
Bad Brake sound? sszyma Brakes, Steering & Suspension 1 04-02-2004 10:24 PM
very odd grinding sound-2k2 wrx 5mt jsmonet Transmission (AT/MT) & Driveline 2 12-14-2002 04:43 PM
