Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 10-28-2006, 02:37 AM   #1
qUicKnesS05
Member#: 101552
2002 WRX/STI Hyrbid
like every other one
Default Uppipe leak Need to See if anyone have used muffler cement.
Well i got an UR uppipe with the EWG setup btw they make the worst ***** ever uppipe doesnt sit right on my header ive tried everything to make it work ive done plenty of uppipe install and never had a problem with leaks. And also there uppipe flange to the turbo, the bolt didnt fit right i had to reem or ream out one of the holes on the turbo flange to even make it fit. So i was seeing if anyone else had any sort of remedies for me. My buddy andy at xotic said to use muffler cement but that was for the catback but ive never seen the stuff if anybody has could u help a brother out cause i cant take this BS anymore. And if the stuff would hold up under that heat. Thnx.
-Ricky
BTW Ultimate Racing, ive had nothing but bad fitment from them i bought a tial BOV with there homemade flange to fit the TMIC and that didnt fit wasted 300 dollars and now this uppipe BS im never buyin anything from them ever!! I shouldve bought an element instead but oh well i guess im tired of b*tchen now. PEACE.
qUicKnesS05 is offline   Reply With Quote
Old 10-28-2006, 02:45 AM   #2
jahl7787
Member#: 97326
04 sti
I'm sure youv'e used new gaskets, but Qualco makes a great joint and crack exhaust system sealer I used on my downpipe and it works great.
jahl7787 is offline   Reply With Quote
Old 10-28-2006, 02:51 AM   #3
qUicKnesS05
Member#: 101552
2002 WRX/STI Hyrbid
from the dp to the cat back right, if so that spot doesnt even get close to getting as hot as the header to the uppipe i need some that will withstand like 1,500 degrees+.
Old 10-28-2006, 02:56 AM   #4
jahl7787
Member#: 97326
04 sti
Old 10-28-2006, 03:15 AM   #5
qUicKnesS05
Member#: 101552
2002 WRX/STI Hyrbid
good look man that much work ima do some more research on it i really appreciate that mayne.
-Ricky
Old 10-28-2006, 11:15 AM   #6
page02wrx
Member#: 124053
Back to BONE STOCK
Not trying to rub it in but slowboy racing had a really nice EWG up pipe you should have looked into... they just take the invidia up pipe and flange it for whatever EWG you use... and its invidia so you know chances are in your favor for it fitting.
But SBR does make mistakes too, my EWG flange was a bit warped (probably from the heat of the welding) and I kept blowing 35mm gaskets..... so I told them about it and no hesitation they said bring it up and they'd make it right for free...
Anyway try advance auto I know they have Muffler sealant, maybe it has the temp on it?
Simple to use too, just wire brush the spot a bit, then put the putty on and let it sit a couple hours (I'd do it over night)
page02wrx is offline   Reply With Quote
Old 10-28-2006, 02:34 PM   #7
qUicKnesS05
Member#: 101552
2002 WRX/STI Hyrbid
Well yeah I shouldve done research on the ewg setup but my got it first and it fit fine so that's why I went with it but its done and over with so I got to live with it now but thnx for your input though I really appreciate it.
Ricky
Old 10-28-2006, 03:29 PM   #8
gold rush
Member#: 90110
2004 wrx wagon
Had the same problem with my UR up-pipe. Nothing worked to band-aid fix it, so I bought a Vibrant Flex piece, welded than in and no problems since.
gold rush is offline   Reply With Quote
Old 10-28-2006, 04:09 PM   #9
qUicKnesS05
Member#: 101552
2002 WRX/STI Hyrbid
yeah its bs they sell that uppipe for so much what a bunch of scam artist.
wtb: i need parts.....check to see if you have these to sell! jakesurfin TXIC Private Classifieds 2 02-01-2009 07:37 PM
WTT: feeler to see if anyone... visualsinz Wheels/Tires 2 01-31-2008 04:47 PM
need something used look to see if i have it sr55stiguy Private 'For Sale' Classifieds 7 11-13-2005 07:54 PM
Easiest way to see if you have an uppipe? mrvoid General Community 17 09-15-2005 09:55 AM
I need to send flowers, anyone have flower shop hook-ups? GimmeScoobySnacks Southern California Impreza Club Forum -- SCIC 5 06-11-2003 10:51 PM
