Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 10-28-2006, 10:40 AM   #1
adam555
Member#: 6339
Default whose old car was this? anyone from here?
http://www.autotrader.com/fyc/vdp.js...g=1&cardist=30
02 wrx - Monarch Motorspots.
is a 104k too many miles in your opinion?
adam555 is offline   Reply With Quote
Old 10-28-2006, 10:45 AM   #2
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
104k is not a lot of miles for a modern Subaru, and at $9k it could be a good deal. You need to look for signs of mods that ould bother you, and get an independent mechanic to inspect it (including a compression test).
Snowphun is online now   Reply With Quote
Old 10-28-2006, 10:47 AM   #3
adam555
Member#: 6339
they say it has a turbo timer in the description so I am guessing who ever owned it did not know too much about the car, otherwise they would have known that they did not need it. how much does a compression test cost usually?
Old 10-28-2006, 10:56 AM   #4
TheMadScientist
Member#: 23717
2005 Big red
That all depends on the level of mods. I have a TT but I all so have an oil cooled only turbo.
Go buy a kit at autozone or sears. Some kits cost as much as having someone do it for you. A compression tester is a very good tool to have.
TMS
TheMadScientist is offline   Reply With Quote
Old 10-28-2006, 11:06 AM   #5
adam555
Member#: 6339
TMS
im assuming this car is running the stock turbo, hence why i said was pointless. who knows maybe it has an upgraded turbo and they dont realize it? As for a compression test, thanks I had no idea that you could buy one yourself. I will definitly go check into that. Thanks.
Old 10-28-2006, 11:08 AM   #6
adam555
Member#: 6339
could anyone explain how the tester from autozone would work for engine compression? Thanks all.
Old 10-28-2006, 11:59 AM   #7
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
BOV = clueless previous owner = pass on this one.
jack
Old 10-28-2006, 02:20 PM   #8
AruisDante
Member#: 122365
2015 WRX STI Limited
Ice Silver
There's also always the possiblity that at one point it HAD a different turbo on it that was oil only cooled, and then when they sold it they took it off. A lot of people do this with used cars, a) because the dealer will give you in many cases more money for a stock car and b) because you then can make some of th emoney back selling the parts or you can reuse them.
This is why it's important to get the car checked out by a mechanic to make sure it's all in good working order.
AruisDante is offline   Reply With Quote
Old 10-28-2006, 02:35 PM   #9
adam555
Member#: 6339
very true
i just got back from looking at it. seems nice, ran ok. Might go back for a test drive. front end hit though at one point I believe.
Old 10-28-2006, 02:55 PM   #10
Judau
Member#: 110717
2000 Impreza 2.5RS
Blue Ridge Pearl
I've seen this same car for sale on multiple online car searches... for 9k, it seems to be a deal. But yeah, throw out the BOV (i.e. sell it to someone who doesn't know better :P).
Judau is offline   Reply With Quote
Old 10-28-2006, 07:29 PM   #11
JeremyRS
Member#: 65126
00 Leggy Wagon
99 Silverado, 06 HD
Fred @ Monarch is a good guy. Just to throw that out there.
JeremyRS is offline   Reply With Quote
Old 10-28-2006, 07:35 PM   #12
Mystic
Member#: 89826
05 STI
some blue color
i am glad someone had luck with him ...
i went to go look at a black STI 04 he had said thing was mint walked around the car while i was on the phone and picked out everything ... i drove all the way up there from the cape and the car was smashed before on the right rear side and had horrible body work done to it ,then he starts the car up cold and revs the piss out of the motor 3-4 times so i can hear the BOV ...he had no history on the car ...i was just upset i drove all the way up there and the car was a ****box i feel bad for whoever bought it
PS i would stay away from a car that was modded
Mystic is offline   Reply With Quote
Old 10-28-2006, 07:57 PM   #13
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
jack
+1 2345
iamrazor is offline   Reply With Quote
Old 11-27-2006, 09:33 PM   #14
beat22
Member#: 113763
15 sti launch
04 wrx wrb
i can't agree... i looked at a psm 02 wrx that was repaired very poorly there... just check it over well
beat22 is offline   Reply With Quote
Old 11-27-2006, 10:26 PM   #15
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Could anyone explain how the tester from autozone would work for engine compression? Thanks all.
Generally you unscrew One sparkplug, and screw in a fitting connected to a hose with a compression gauge at the other end. You then run the engine (on three cylinders) and obtain a reading. Then you replace the fitting with the sparkplug and repeat the process for the remaining cylinders.
You then compare the readings (they should each be within 10 percent of the other cylinders) with the readings of a healthy new production engine and from these numbers decide upon the relative health of the engine you just tested.
Jonathan is offline   Reply With Quote
Old 11-27-2006, 10:36 PM   #16
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
or not...
Sideshowbob is offline   Reply With Quote
Old 11-28-2006, 05:03 AM   #17
TheMadScientist
Member#: 23717
2005 Big red
NO NO NO
You take out ALL the plugs. Screw tester into one cylinder, disable the ECU by pulling the fuse. Crank the motor with the starter while holding the throttle WOT. Has to be done on a warn motor.
TMS
was this anyone on here novacivic New England Impreza Club Forum -- NESIC 17 10-18-2008 11:02 PM
Was this anyone on here? NightHawk New England Impreza Club Forum -- NESIC 4 10-15-2008 10:24 PM
Was this anyone on here? slo06sti North West Impreza Club Forum -- NWIC 46 07-31-2008 12:03 PM
Was this anyone in here? SilverSubie2.5 South East Region Forum 2 05-21-2007 08:35 PM
Who is this???Anyone from here? Cossack Vancouver Impreza Club Forum -- VIC 36 09-05-2006 01:22 AM
