Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-28-2006, 09:09 PM   #1
BrigadoonB
Member#: 100524
2012 WRX
Default which setup would get me the most reliable engine w/ greatest numbers?
I have a 04 STI, Ecutek, TBE and APS CAI. I'm looking at getting a 20g on my current set-up but I also want to use my TMIC and stock injectors......which brings me to the question above...Which set-up would get me the most reliable running engine with greatest numbers.
I'm considering water/alcy/meth and any combo in between. If you tell me the one you would go with and why and where I could get the kit and where I could get the items to fill the tanks.....much apreciated!!!
fyi:
I would like to keep the kits at $500 or less.
The car will be a daily driver.
BrigadoonB is offline   Reply With Quote
Old 10-29-2006, 04:58 AM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
with that turbo you will need bigger injectors than stock if you want to keep it reliable...
jigga is offline   Reply With Quote
Old 10-29-2006, 07:51 AM   #3
hippy
Member#: 36528
2002 Impreza Wrx
I don't agree........... If you want to keep the stock injectors, you will most likely need to run 50/50 or 100% alc to compensate for the lack of fuel system capacity unless you run a really really lean a/f ratio and/or low boost.
Imo, you will get a good amount of performance and reliability(safety)for $500 or less if you get a basic system(from any company) that has a good problem monitoring system(dds3 from aquamist might be a good choice). If you went with a controller kit, you'd sacrifice safety for more control, and that might not even make your car run any better.
peace
Old 10-29-2006, 09:25 AM   #4
dibblejr
Member#: 94070
05 LGT
I partially disagree with hippy. Yes for under $500 you can get a kit that will help you achieve your goals.
However I run the coolingmist kit with the controller for optimization. I have had no problems with my kit whatsoever.
I believe all of the kits have faisafes now.
As far as materials, I distill my own water and I buy alky at home depot.
Jay-R
dibblejr is offline   Reply With Quote
Old 10-29-2006, 03:34 PM   #5
BrigadoonB
Member#: 100524
2012 WRX
can you run any setup with any of these kits? alcy,meth,water?
jigga....already talked to a tuner and STI stock injector will work fine on a 20g, as long I run one of these kits. He said I should be running around 90-95% capacity on the injectors.
Old 10-29-2006, 05:14 PM   #6
dibblejr
Member#: 94070
05 LGT
Yes you can run any setup with any of the kits. You just need to get tuned for it.
Water alone will net you 0hp gains, but will allow your tuner to advance the timing a bit, thus getting you some more power. Water alone is used for more of a safety measure than anything else.
jay-R
Old 10-30-2006, 01:17 AM   #7
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
I, too think that you can run your stock injectors with a WI kit. I am running the CoolingMist Stage 2, which is just about $500 complete. With my 18G I am seeing IDCs in the 80s with 50-50 meth-water, so there is quite a bit of headroom. And I am running a relatively small injector.
bcblues is offline   Reply With Quote
Old 10-30-2006, 08:40 AM   #8
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Yeah but then you're constantly relying on the alky injection system, what if you wanted to turn that system off and just run all motor/turbo, you couldn’t because of limitation on the injectors. IMHO, the turbo and motor setup should be kept separate from injection, that is if you want to go stage 4 do so with the appropriate components, then add injection later if you choose; or vice versa but keep the two systems independant...
xcntrk75 is offline   Reply With Quote
Old 10-30-2006, 12:51 PM   #9
Ultimate Collision Center
Member#: 69072
PM me if your interested in a Snow Kit, I can do that for a lot less than 500...with the money you save I would definitely go with some injectors just in case you don't want to run methanol all the time...
Ultimate Collision Center is offline   Reply With Quote
Old 10-30-2006, 12:53 PM   #10
CatfaceType-R
Member#: 81102
get injectors....don't leave the chance on the table of starving your motor
CatfaceType-R is offline   Reply With Quote
Old 10-30-2006, 04:53 PM   #11
dibblejr
Member#: 94070
05 LGT
You do not need to change injectors to run water, alky, meth or any combination of.
The mist is going straight into the cylinders so quick. You will require a tune.
A stock car can run any of the combination just fine, with a tune.
Jay-R
Old 10-30-2006, 07:19 PM   #12
BrigadoonB
Member#: 100524
2012 WRX
I'm always going to run Alcy once I get it hooked up. I have Ecutek so switching over from to another is a bit more challenging for me. Side note.....Don't get me wrong Ecutek was the best choice for me because i dont like off the shelf maps because I believe every car reacts differently...hence Ecutek is more custom fit since it has to be tuned specifically to your own car.
I was thinking about a 75/25 alchy/water mix.....anyone hear of this?
I really just want a reliable engine with a 20g that fits my setup and keep the TMIC (hence the alchy).
Old 10-30-2006, 07:38 PM   #13
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
I often wonder how does one run their car with ECUTEK when you are out of anti-detonant, escecially with high % of alcohol in the mix.
Even with a good failsafe system incorporated, how does one implement "plan B" as ECUTEK cannot chnage MAP?
Aquamist is offline   Reply With Quote
Old 10-30-2006, 07:39 PM   #14
dibblejr
Member#: 94070
05 LGT
Going to low on the mix will not get you any gains.
50/50 is safe as long as you are tuned for it. In the winter 75/25 may freeze, but for winter you may want to run without juice for that reason.
Old 10-30-2006, 08:08 PM   #15
hippy
Member#: 36528
2002 Impreza Wrx
Originally Posted by Aquamist View Post
....Even with a good failsafe system incorporated, how does one implement "plan B" as ECUTEK cannot chnage MAP?
Plan b(switch from failsafe) could turn on a seconday injection system(or secondary injector in case of clog). For less then the price of some systems, you could have two systems with a failsafe. Plan b could also just be not running the car hard til the injection system is running normally. What I mean is, with propper upkeep, are the chances of there being no injection any higher then a boost problem, a tire being flat, or whatever? If the boost was skyrocketting, people would normally just not run the car hard....
Originally Posted by dibblejr View Post
....In the winter 75/25 may freeze, but for winter you may want to run without juice for that reason.
More alc=less chance of freezing.
peace
Old 10-30-2006, 08:15 PM   #16
BrigadoonB
Member#: 100524
2012 WRX
I'm in FL...so freezing is not really an option.
Aquamist....my failsafe system is me.....just like how I check my oil on a regular basis. Ecutek was the best choice for me but with everything...it does have a down side.
Question of the Day: Which Engine is the Most Reliable? AVANTI R5 Non-Subaru News & Rumors 27 04-03-2008 03:38 PM
Which would make you the most nervous ? Sausage Political Playground 16 07-20-2006 12:42 PM
which tuner has the most reliable stg 2/3? mistaare Engine Management & Tuning 14 03-17-2005 01:23 PM
Which Blow off valve will give me the MOST HP? AaronWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 09-13-2003 04:56 PM
