Old 11-09-2001, 10:56 PM   #1
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
Default FREE mods
what are they
so far i've done the following
silencer removal
vent opening
lighted emblem
nomadtw is offline   Reply With Quote
Old 11-10-2001, 12:09 AM   #2
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
I think you will find a lot of results if you do a search.
-Wes
RebelINS is offline   Reply With Quote
Old 11-10-2001, 12:56 PM   #3
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
remove pasanger and rear seats.
remove electric window motors
remove cruise control and AC
remove all hard trim
Free lightweight mods....
LUME is offline   Reply With Quote
Old 11-10-2001, 03:15 PM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
remove that stupid weight behind the glovebox.
Take out hood vent blocking plates
paint the back of the subaru emblem
debadge trunk
Eric
Eric SS is offline   Reply With Quote
Old 11-10-2001, 05:11 PM   #5
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
You could also steal some performance parts...
Actually I don't approve of theft, but you did ask for FREE mods...
Upgrade your ground wires to bigger gauge is cheap but not free. The subarus don't have many free mods... Not like a mustang where the engineering was not smart and people could do easy fixes/removals/mods...
janikphoto is offline   Reply With Quote
Old 11-10-2001, 05:56 PM   #6
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
learn to drive better. I for one am still working on it.
Poppa smurf is offline   Reply With Quote
Old 11-10-2001, 09:19 PM   #7
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
The stupid weight is called a knee bolster, it keeps the passenger in the proper position when the airbag deploys during a front end collision.
Peaty is offline   Reply With Quote
Old 11-10-2001, 09:28 PM   #8
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Yeah, who needs that thing... while you're at it, get rid of the airbag
Eric
Old 11-10-2001, 09:38 PM   #9
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
I think they have a cool compartment that goes in place of the airbag.
There is a weight just over the plate by the cross member that can be removed. I think it's for vibration dampening but it's just a lump that sits there. It's above the plate usually used to jack up the front of the car when using a floor jack.
Old 11-10-2001, 09:52 PM   #10
Fusion
Member#: 553
2000 2.5RS Coupe
Silverthorne Metallic
Y'know, I've never really understood the importance of the firewall. Maybe you can dremel it out? j/k of course
Fusion is offline   Reply With Quote
Old 11-11-2001, 02:05 AM   #11
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
Just don't ever have an engine fire/clutch explosion/get in an accident/drive in the rain
SoobATV is offline   Reply With Quote
Old 11-11-2001, 03:12 AM   #12
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
What does upgrading your ground wires to a bigger gauge do???
LVSUBARU is offline   Reply With Quote
Old 11-11-2001, 12:31 PM   #13
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Remove the blinker fluid reservoir
Eric
Old 11-11-2001, 05:41 PM   #14
Evan J. Kelly
Forever Scooby Newbie
Member#: 11172
2000 GC8 RS Coupe'
FlatBlack&BlueRidge Pearl
Default weight
Sounds stupid, if not immature, but I gutted the whole inside of my car, doors, ceiling and all. It greatly improved everthing, literally. You could keep whatever you want in the car. But all of that sound deadening material, and especially that tar/asphalt shif Subaru puts all over the bottom of the inside of the car, has got to go. It is a serious pain in the ass to get out, but there is like a hundred or so pounds of this crap from the firewall to the trunk.
Evan J. Kelly is offline   Reply With Quote
Old 11-11-2001, 05:47 PM   #15
Evan J. Kelly
Member#: 11172
2000 GC8 RS Coupe'
Not a whole lot, I think think it is better for your conscious than anything else. I suppose stuff is brighter, the car starts up marginally better, and everything is kinda enhanced.?. Anyways, my first comment is dead on, it makes you feel better about your car. Every little thing helps when you're pushin under 200 horses.
No joke intended.
Old 11-12-2001, 09:51 PM   #16
janikphoto
Member#: 10471
2000 BMW Z3
It is a very cheap mod to upgrade to bigger ground wires from the engine to the firwall and from the engine to... Isn't there one going to a frame-type of area? I remember seeing a few ground straps. Anyway, It's true that it won't do much, but any improvement in reducing electrical resistance is good and will at least marginally extend the life of all electronic components. It's like sucking a milk shake through a bigger straw. Less strain and more juice can be transferred. So you'll feel better knowing your car has had a weaker point upgraded even if that weak point wasn't a major isuue to begin with... And besides, all the other good free/cheap ideas were already mentioned. I needed SOMETHING new!!! One other thing would be a very good coat of wax. Subaru paint is so thin that it chips when leaves fall on the car!!!
Old 11-12-2001, 10:30 PM   #17
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Someone told me that electricity travels mostly on the outside of wires so lots of strands are better then few. More surface area,Can someone confirm this?
Old 11-12-2001, 11:05 PM   #18
Fusion
Member#: 553
2000 2.5RS Coupe
Well, I know a higher strand count is typically more expensive and of higher quality. Sounds like it's important for something.
Haig
Old 11-13-2001, 12:52 AM   #19
KeithRS
Member#: 3436
1987 Rockhopper
Yellow
Thumbs up
Remove the A/C, power steering, and alternator. They add unnecessary drag and weight. Replace windows with clear lexan.
Recharge the battery frequently and don't run at night (shouldn't use lights) since you don't have an alternator.
KeithRS is offline   Reply With Quote
Old 11-13-2001, 01:22 AM   #20
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Will upgrading to bigger ground wires help prevent me from getting electricuted every time I get out of my subie!!!!
Old 11-13-2001, 01:34 AM   #21
Ripper
Member#: 7774
drill lots of random holes in your hood for cold air to get in
Ripper is offline   Reply With Quote
Old 11-13-2001, 03:03 AM   #22
RotarFreak
Member#: 8144
Default aka
SPEED HOLES, they make your car go faster
Doughnutt,,,......
RotarFreak is offline   Reply With Quote
Old 11-13-2001, 09:45 AM   #23
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
That is true, current travels on the outside of the cable. That is why there we have stranded cables, for more current flow and they also bend easier. Stranded cables have more perimeter, just like a four-leaf clover that fits inside a circle has more perimeter.
Charlie
edit: stranded cables do not have more "surface area"
wcbjr is offline   Reply With Quote
Old 11-13-2001, 10:06 AM   #24
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
Most of the current will travel on the outside of the wire. When you have a stranded wire though, the whole bundle of strands is one big wire as far as the electricity is concerned. Its more like that for flexibility than anything else. A solid wire would be better for current flow, since resistance is a function of cross-section area. there's little pockets of air between each strand. All bigger wires'll really do for you is make your headlights dim less when you're cranking music, and it'll help your car start. most of your electricity is coming from your alternator when you're underway anyways. you can disconnect the battery when you're driving and the car won't know the difference for the most part.
cheapest mod you can do is make a CAI out of old-school exhaust bits from auto-zone and rubber clamp-down plumbing couplers from home depot. $20 later, and you have a CAI about 80% as good as a Ganz. it won't look as nice and it won't sound as mean, but its worlds better than the stock system. this it for MAP cars only, and you keep the stock airbox and filter.
-IggDawg
IggDawg is offline   Reply With Quote
Old 11-13-2001, 01:53 PM   #25
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
I'll take free mods from anyone giving them out.
Brad
MY99 2.5GT is offline   Reply With Quote
1 Free mod & 1 $10.49 mod 2.5 SUBY Member's Car Gallery 18 11-16-2005 07:00 AM
Cheap and free mods? SubieFL Normally Aspirated Powertrain 36 11-28-2002 12:42 AM
rattle free mods??? initialx Newbies & FAQs 2 01-14-2002 11:14 AM
Cheap or free mods for WRX? dman918 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-11-2001 06:54 PM
Free mods LAYLOW Newbies & FAQs 9 06-04-2001 10:13 AM
