Welcome to the North American Subaru Impreza Owners Club Sunday December 21, 2014
Old 10-29-2006, 09:27 AM   #1
69_Lex
Member#: 105923
04 WRX
Default Occassional knock at idle?
I was doing some live tuning and noticed that at idle I was getting an occasional knock (720-730rpm). I didn't log it but was curious if anyone else has seen any knocking at idle. I don't get any knocking under load, only an occasional one at idle? Not sure if it is a true knock or if the sensor is picking up noise from belt tensioner or valve noise. Just wanted to know if this is common or not. 2004 WRX 28kmi Mods are 16g, Spearco TMIC, pnp exhaust manifold, helix uppipe, turbo xs stealth back exhaust, perrin pulley, walboro pump, and one step colder plugs.
69_Lex is offline   Reply With Quote
Old 10-29-2006, 09:29 AM   #2
OvrClkdPmp
Member#: 64467
2013 Forester XT
Sage GReen
ill bump this as i have seen the same with my logs. unknown cause.
OvrClkdPmp is offline   Reply With Quote
Old 10-29-2006, 09:43 AM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....and I have too....it really can not be true 'knock'....it has to be some sort of mechanical transient being 'heard' as knock.
I chased it all over hell and back and in the end.....fergetaboutit.
This has been posted before....
Old 10-29-2006, 09:46 PM   #4
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
Try raising the idle. Some have said this helps get read of the instance. However, the source of the instance has yet to be found.
scoobdude is offline   Reply With Quote
Knock at idle? windozer Open Source Reflashes 15 09-29-2009 02:41 AM
Knock at Idle broben05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-18-2007 04:33 PM
Knocks at idle.(06 WRX) weggy Newbies & FAQs 21 10-13-2006 12:07 AM
knock at idle only? crashtke Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-12-2006 01:24 AM
