Old 10-29-2006, 11:52 AM   #1
WReXd
Member#: 114101
93 Impreza L Swap
Default Scangauge in clock pod!
Inspired by Hondo88 (the scanmaster 3 in clock pod guy), I took on this little project, and am very happy with it! Pics:
What do you guys think?
WReXd is offline   Reply With Quote
Old 10-29-2006, 11:55 AM   #2
aznatama
Member#: 60316
2004 STi
very nice
aznatama is offline   Reply With Quote
Old 10-29-2006, 12:00 PM   #3
CatfaceType-R
Member#: 81102
looks pretty clean, gj
CatfaceType-R is offline   Reply With Quote
Old 10-29-2006, 12:06 PM   #4
Theblack
Member#: 105601
2007 Mazdaspeed6
WOW ~searches price~ hope you don't have that copy written.. was it “hard”/take more then 5 hours
Edit for spelling
Theblack is offline   Reply With Quote
Old 10-29-2006, 12:36 PM   #5
JBravo920
Member#: 73420
2008 Camry XLE
& 10' Kawasaki Vulcan 900
write up!!!! That looks great. I love having a clock in my car, but I would definetly ditch it for that!
JBravo920 is offline   Reply With Quote
Old 10-29-2006, 02:13 PM   #6
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Nice work! I had already mounted a V1 remote display there, so my scangauge is just mounted above the vent on the left side of the dash.
RP31 is online now   Reply With Quote
Old 10-29-2006, 08:21 PM   #7
WReXd
Member#: 114101
93 Impreza L Swap
Edit for spelling
It wasn't hard, just a little scary. I knew if I didn't get it right the first time, I'd have to buy another pod for like $20-30, so that was plenty motivation to keep me careful. Took me maybe like 2-3 hours, but I'm one anal guy. It wasn't really hard. If I can do it, I bet any idiot could. I wish I had taken pics and stuff during the process, but I didn't because I knew it'd take me longer to finish, and at the same time I knew it might turn out crappy in the end anyway. If someone were to send me their clock pod and a donation I'd do a write up, but it's pretty self explanatory. Just grind and drill holes...
Old 11-03-2006, 01:22 AM   #8
WReXd
Member#: 114101
93 Impreza L Swap
bump!
Old 11-03-2006, 03:39 AM   #9
Handsdown
Member#: 29355
that looks really cool. too bad it's 165 dollars.
Handsdown is offline   Reply With Quote
Old 11-04-2006, 04:37 PM   #10
TKDKracker007
Member#: 52492
2014 WRX Premium
sexy dirty black
$165 is not that bad. I almost bought a Scanmaster3, but this is more what I wanted anyway, at what, $80-100 less?
Just rec'd mine today, looking forward to mounting it later.
And for the OP, cool install. I don't want to lose my clock though.
TKDKracker007 is offline   Reply With Quote
Old 11-04-2006, 05:12 PM   #11
WReXd
Member#: 114101
93 Impreza L Swap
I had the same feeling, so my project now is putting the clock in that wasted space next to the cup holder. I hate having to push buttons on my head unit to check what time it is...
Old 11-04-2006, 10:19 PM   #12
SkyRealms
Member#: 91527
'06 SGM WRX Ltd
Stg 1+
nicely done
SkyRealms is offline   Reply With Quote
Old 11-04-2006, 11:31 PM   #13
eazyd123
Member#: 110489
very very well done...low profile is always good
eazyd123 is offline   Reply With Quote
Old 11-05-2006, 01:13 AM   #14
keoni004
Member#: 69652
2011 BMW 335i
'05 WRX Wagon (RIP)
How'd you route the connector from the OBD port to the pod? Does the connector get in the way while you drive/get in?
keoni004 is offline   Reply With Quote
Old 11-05-2006, 01:26 AM   #15
WReXd
Member#: 114101
93 Impreza L Swap
I just maneuvered through all the wiring behind the gauge cluster and junk. It's not really hard. The connector doesn't get in the way at all. Only way I notice it's there is if I rub my knee against it. I was thinking about drilling a hole through that plastic piece surrounding the connector, but it's so discreet I don't think it's worth it.
Old 11-14-2006, 08:53 PM   #16
Hondo88
Member#: 77222
06 WRX
Wow, dude that looks really good. I think it looks better than mine.
http://forums.nasioc.com/forums/showthread.php?t=959627
Do you have any trouble with the LCD in the cold?
Hondo88 is offline   Reply With Quote
Old 11-14-2006, 09:02 PM   #17
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
the obd port pops out in like 2 seconds.. you could just pop it out and pull it behind the dash piece and plug it in so you dont have to drill any holes..
nice install btw
vipernj is offline   Reply With Quote
Old 11-14-2006, 11:11 PM   #18
WReXd
Member#: 114101
93 Impreza L Swap
Thanks, guys! I haven't had to drive my car out in extreme temps, so I don't know whether or not I'd have problems... we'll see as winter comes.
Old 11-15-2006, 09:34 PM   #19
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Really nice install!
Old 09-26-2007, 03:14 AM   #20
wishbone
Member#: 106958
2005 WRX Wagon
What did you do about the third button you can't access? The one on the lower right that is covered up. I'm working on doing this now.
Also how did you attach the display to the pod? Did you just glue it on there?
wishbone is offline   Reply With Quote
Old 09-26-2007, 11:55 AM   #21
Paranoid Fabrications
Member#: 140712
2008 WRX STI
Nice install, very very clean. but good question, where is that other button?
Shane
Paranoid Fabrications is offline   Reply With Quote
Old 09-27-2007, 10:41 PM   #22
WReXd
Member#: 114101
93 Impreza L Swap
thanks, guys! this thread's pretty old, and I don't have my scangauge anymore (won't work with my jdm ecu)...
Anyway, if you look REAL close, you can see a small hole where the 5th button should be. I kept a small screwdriver in my car, which I'd stick through that hole to press the 5th button. It sure wasn't ideal, but it worked. Also, I used duct tape to keep the scangauge on there, haha. I didn't want to make it a permanent install in case I ever decided to take it out (which I ended up doing).
Old 09-28-2007, 09:45 PM   #23
wrx614
Member#: 71848
2003 WRX
I mounted my plx wideband in my clock display.
wrx614 is offline   Reply With Quote
Old 09-28-2007, 11:22 PM   #24
wishbone
Member#: 106958
2005 WRX Wagon
ahh ok well I mounted mine a bit different so I can see all the buttons. Took a LOT of dremeling to get it how I want it. It turned out ok, I'll snap some shots of it soon.
Old 09-30-2007, 11:53 AM   #25
WReXd
Member#: 114101
93 Impreza L Swap
yeah, post some pics. I'm really curious to see how you did it.
UTEC LCD readout in clock pod cdvma Interior & Exterior Modification 171 06-15-2009 11:47 AM
FS Omori gauges in clock pod vortectoy Interior/Dressup/Audio & Security 7 05-16-2007 01:02 AM
Scangauge in clock pod! WReXd Interior/Dressup/Audio & Security 4 03-29-2007 11:16 AM
ScanMaster 3 in Clock Pod Hondo88 Interior & Exterior Modification 3 03-12-2006 03:06 PM
