Old 11-10-2001, 02:57 AM   #1
Anson Moy
Member#: 9451
2001 RS Saloon
Deep Mica Blue
Default Turbo intercooler in place of aftermarket intake
I have a question I've been thinking about for a long time. Is it feasible to install a turbo intercooler without a turbo (probably add on later)? Taking out the hood scoop panel and using the intercooler like an aftermarket intake system? I know this sounds funny. Has anybody done this before? Will this work better than the aftermarket intake system?
Anson Moy is offline   Reply With Quote
Old 11-10-2001, 03:15 AM   #2
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
An intercooler that uses outside air can't cool the charge below ambient temperature. Its purpose in forced induction applications is to compensate for the heat of the intake charge that goes along with it being compressed (the compression raises the temp hundreds of degrees). A normal intake will be better.
Ben
bsquare is offline   Reply With Quote
Old 11-10-2001, 03:21 AM   #3
Anson Moy
Member#: 9451
2001 RS Saloon
Deep Mica Blue
Got it. Thanks so much for clearing this up.
Talking about aftermarket intake, which is best in performance for the money?
Old 11-10-2001, 03:26 AM   #4
bsquare
Member#: 1911
2000 Impreza 2.5RS
GanzFlow with a K&N filter in the stock air box.
Ben
Old 11-10-2001, 04:49 AM   #5
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Don't want to step on any toes...but...
Best bang for the buck would have to be the PDM Racing intake. Pretty much identical in specs to the Ganzflow, but cheaper to begin with, and now with the piss poor Canadian currency it'll be even cheaper for you Americans.
Keiho is offline   Reply With Quote
Old 11-10-2001, 05:03 AM   #6
Andrew
Member#: 1170
2005 STi
i believe this has been discussed before. someone mentioned that a muscle car guy used an IC after the intake and found small gains. or something to that degree. the consensus was that its a waste of money.
Andrew is offline   Reply With Quote
Old 11-10-2001, 05:16 AM   #7
bsquare
Member#: 1911
2000 Impreza 2.5RS
I really prefer the GanzFlow because it maintains the stock airbox and that has an extremely positive effect on throttle response and low end performance.
Ben
Old 11-10-2001, 08:27 AM   #8
Panzer1939
Member#: 2427
Love my Cobb CAI.
Tim Albert
American Citizen
Panzer1939 is offline   Reply With Quote
Old 11-10-2001, 03:06 PM   #9
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
bsquare: That's what the PDM Racing is to. Like I said, it is virtually identical to the Ganzflow. In fact I think PDM was the first to run with a 3" cold air pipe.
Old 11-10-2001, 08:23 PM   #10
Anson Moy
Member#: 9451
2001 RS Saloon
Deep Mica Blue
Despite you guys arguing over which is best, I just went out and made my own homemade intake. All I need was 10mm and 11mm sockets, socket wrench, flat head screwdriver, scissor, 4" hose clamp and a 3" flexible/extendable aluminum dryer air
duct. Pulled the aluminum from the airbox to the fender
and all the way to the bumper's air duct under fog lamp. I hope
mice or birdie will not nest in there overnight.
I'm missing a K&N oem flat panel filter though
Old 11-10-2001, 09:09 PM   #11
DustinR
Member#: 8264
2001 Impreza 2.5 RS
95 Impreza 1.8 Coupe
Ill second the love for Cobb CAI
DustinR is offline   Reply With Quote
Old 11-11-2001, 12:59 AM   #12
ImprezaRS dot com
over boosted again
Member#: 1458
2006 B9 Tribeca LTD
2005 Impreza 2.5 RS
Thanks Keiho, I didn't need the extra GanzFlow customers with the US economy doing so well
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 11-11-2001, 01:13 AM   #13
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Re: Turbo intercooler in place of aftermarket intake
Truthfully Anson, no-one here can answer this. Why don't you try it out and report your findings to us. We can decipher and theorize why we think it will or will not work but in application on a normally aspirated Scooby, we don't know. It may very well be a good idea for some miscellaneous reason. So go and try it out and let us know what you think of it. I'm sure no-one thought that a 2.5RS could gain 15hp+ from just an intake change.
Sometimes you just never know until you try.
And yes, someone here as already did something similar to what you are talking about. They didn't use an intercooler but the stock intake air plenum housing. They cut the top half of it off and installed a filter of sorts over the bottom half. It got pretty dirty (they had pics of it on here) but they liked it a lot. I'm not sure if they were the only ones to do this modification either. Good luck!
Kevin Thomas is offline   Reply With Quote
Old 11-11-2001, 01:37 AM   #14
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Larry: No worries...I'm sure people will still buy from you anyway. I know I would if I lived in the States, less hassles with customs/taxes. I most certainly didn't mean to "take customers" away from you! If I came off as that I apologize.
Old 11-11-2001, 01:53 AM   #15
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Here is a pic of my 3" PDM intake:
It looks great, fits great, and sounds great.
Richard
http://www.whitetyphoon.com/impreza/
Richard L. is offline   Reply With Quote
Old 11-11-2001, 06:26 PM   #16
Anson Moy
Member#: 9451
2001 RS Saloon
Deep Mica Blue
Default Re: Re: Turbo intercooler in place of aftermarket intake
Kevin,
Yeah, I've thought of trying that out but Bsquare said it's not feasible. Scroll all the way up and read his post and let me know what you think.
An intercooler is not cheap though. I will keep trying to find a bargain intercooler though. Will let you guys know if I do have a chance to try out this experiment.
Anybody got a intercooler lying around collecting dusts?
drop in filter or aftermarket intake ? boostedsti06 Newbies & FAQs 23 01-06-2007 07:57 PM
Post pictures of aftermarket intakes!!! im getting tuned litlechina Member's Car Gallery 33 02-24-2006 11:32 AM
STi ECU in place of Baja Turbo ECU BAJAGT Subaru Conversions 7 02-23-2005 11:07 PM
Anyone pics of single in place of stock 2-DIN Scoobie Newbie Car Audio, Video & Security 22 01-02-2002 03:46 PM
Message Board Statistics All times are GMT -4. The time now is 10:56 PM.
