Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 10-30-2006, 01:30 PM   #1
elgorey
Member Sales Rating: (1)
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
Default Integra racecar for sale. SCCA ITA / Honda Challenge H4
Posting this for a friend. Ive driven the car and it is very fast, well sorted, and well developed. Nothing halfassed, this is not a thrown together racecar. Everything developed and tested.
contact via email at [email protected]
The car is a 1995 Integra RS Shell - lightest shell available, no sunroof, no ABS, cruise control, power locks.
I bought the car in San Diego, CA with 95k miles, and drove it back non-stop to Va with zero issues at all. It had spent its whole life in Southern California with one owner, there is no rust, bent body panels, seized bolts or frame damage anywhere.
Clear title in hand, was street registered until May 06. This was my first season racing with the car, only 7 Honda Challenge races with 3 pole positions and 3 wins. The car has current NASA logbook, no contact or incidents. The car is fast, fun, sorted out with tons of spares. The car will be available for rides @ Summit Point Shenandoah Nov 11-12 (Carguys HPDE) and Test Drives for a serious buyer.
$10k OBO - car is located in the Northern Va (DC Metro area)
If interested contact via email at [email protected]
In-Car Video: (video from the latest race will be posted soon)
Pics:
Details:
Engine
Ebay intake Tube, K&N Filter
Comptech Icebox
SMSP Custom B18B1 Header
SMSP Exhaust w/ turndown behind driver
Neptune ECU, dyno tuned by Jack Harris @ P1 Auto
IT/HC prepared Cylinder Head, Justice Racing Engines
Endyn Oil Catch Can, plumbed into breathers on engine block
P/S System Removed, steering rack outlets looped to a breather
Drivetrain
Transmission Rebuilt Sept 05, all new OEM honda seals, bearings, synchros
ATS 4.9 Final Drive
ITR OEM LSD
Toda Clutch
Toda 9lb Chromoly Flywheel
New Axles July 06
Motul Gear300 Fluid Always Used
Safety/Interior
Piper Custom Cage - meets all scca/nasa specs
Piper seat mount with slider - sparco slider/sidemounts, custom base
(Driver seat not included in sale!)
(2) Sparco Harness - FIA stamped 2010
Corbeau Forza Passenger seat
Sparco 383 suede steering wheel, Sparco 2" spacer and hub
Autometer Oil pressure warning light (18psi switch in factory location)
ITR shift knob and shift boot
2.5# Fire Extingushier
Suspension
Koni SPSS3 Shocks
Ground-Control Sleeves
Ground-Control Upper Hats (front and rear)
Several Sets of springs - 800, 850, 900, 1000, 1100, 1200lb
Current Spring rates on car are 850f/800r - very neutral and easy to drive
Orijin Motorsport Front LCA Spherical Bushing Kit
Mugen Front LCA 'compliance' bushing
Mugen Front UCA rubber bushings
Hardrace Adjustable Rear Toe Arms (spherical bushing)
Hardrace Adjustable Rear Upper Control Arms (spherical bushing)
Hardrace Spherical Trailing Arm Bushings
OEM Rear LCA's (New Jul 05)
OEM Front Swaybar (21mm)
Hollow Rear swaybar (1.25" x .095") with aluminum bushing blocks and bar arms, Metric Rod Endlinks
Comptech Subframe Brace (prevents subframe tearing with large swaybars)
Spare Swaybars - Hollow 1.25 x .120", Comptech 22mm
OEM ITR Front Strut Tower Brace
Stoptech Brake Lines
New Wheel Bearings, Hubs, Lower Balljoints and ARP Studs Front Aug 05, Rear Feb 06, all OEM Honda
New Tie Rod Ends and Upper Control Arms Feb 06, OEM Honda
Brake Calipers Rebuilt Jul 2006
Front and rear fenders rolled
Recent alignment (laser rack, Curry's Auto), Camber -2.5/-1.0 front/rear, Toe 1/16" toe out/0 toe front/rear
Cornerweight Feb 2006
Wheels/Tires
(4) Kosei K1, 15x7 +45 Offset
(4) Kumho V710 225/50/15, 16 heat cycles
(4) Kumho V710 225/50/15, 7 heat cycles
(4) Kumho V700 205/50/15 full tread wets - used for one qualifying session (3 laps) and one race at CMP
Misc Prep
IO Port Camcorder Mount
P/S removed, but still have full system in a box for IT-compliance
Lamin-X film on headlights/turn signal lenses
'Soft' front tow strap
"Carbon Fiber" front spoiler - custom modifed into 4 separate pieces, could be patched together and re-used
Spares
(3) Spare Cylinder Heads
Comlete (but dissasembled) short block - crankshaft still in block
Axles - (3) driver side, (2) passenger side.
Distributor - (1) complete and (2) set of internals (coil, ignitor, cap, rotor)
Plug Wires
Plugs
Front Calipers - 2 sets, both rebuilt
Brake lines - OEM
Almost complete set of suspension arms front and rear, several sets of front upper arms
Front Hubs/Spindles assembled
Rear Hubs
Brake Rotors (at least 8 in good condition)
Front Brake Pads (one set of XP10 @ 50%, one set of new PFC Carbon Metallic, one set Cobalt VR @ 20%)
Alternator
Stock ECU - can have socketed and chipped to match ECU in car
OPM LSD
4.4:1 Final Drive Gearset
4.2:1 Final Drive Gearset
Stock Clutch
Stock Flywheel
Stock Airbox
Fuel Filter
Fuel Injectors (4)
Misc Seals
Complete Engine Gasket/Seal Set
Timing Belt/Tensioner
Alternator Belt
Stock Header/Cat
elgorey is offline   Reply With Quote
Old 10-30-2006, 01:35 PM   #2
84SubaruDL
Member Sales Rating: (4)
Member#: 42179
SON! F 22's i roll
on 33" 12 fity SON!!!
nice i wish i had 10k for this
free bump
84SubaruDL is offline   Reply With Quote
Old 10-30-2006, 02:22 PM   #3
Butt Dyno
Street's closed, pizza boy
Member Sales Rating: (27)
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
My friend Dan needs to buy this
Old 10-30-2006, 03:28 PM   #4
teh Phil
Member#: 24888
So I guess this means RJ is racing his bike instead?
teh Phil is online now   Reply With Quote
Old 10-30-2006, 03:43 PM   #5
WRXtranceformed
Member Sales Rating: (22)
Member#: 79322
2007 Acura TL-Hype S
ASM
Bump for RJ's racecah! =)
WRXtranceformed is offline   Reply With Quote
Old 10-30-2006, 04:01 PM   #6
Ryan
Member#: 15433
#98 ECHC H4 Integra
RJ has ADD and doesnt know what he's doing next year......
Magic 8 ball says next project is likely a miata.
Ryan is offline   Reply With Quote
Old 10-30-2006, 04:14 PM   #7
elgorey
Member#: 4374
06 Titan,99,94 SM
wait.... why did I post this for you when you had a forum login? donkey
ps- resistance is futile
btw, tell the subaru kids where your #98 originated from
Old 10-30-2006, 04:37 PM   #8
Ryan
Member#: 15433
#98 ECHC H4 Integra
The number I got when i whooped your ass at that subaru autox challenge event in your own car? I think I still have the number plates and the plaque.
You brought it up
(ok, it was only by a few tenths and you coned away your best run...)
Old 10-30-2006, 04:46 PM   #9
Butt Dyno
Member#: 17301
is the "dark side"
http://www.subaruchallenge.com/txt.r...va.results.txt
But you both beat Hoppe!
Evan if you ever get misty for The Wing (tm) and want to autox, let me know
Old 10-30-2006, 04:48 PM   #10
kcook
Member Sales Rating: (40)
Member#: 78074
2005 STi
what motor is in the car? the ls motor? if u mentioned it then oops cause i didnt see it
kcook is offline   Reply With Quote
Old 10-30-2006, 05:46 PM   #11
teh Phil
Member#: 24888
Although that would be convenient, as the smurf blue #25 miata is up for sale.
Old 10-30-2006, 05:55 PM   #12
Butt Dyno
Member#: 17301
is the "dark side"
Oh noes!!
What's he going to do?
Old 10-30-2006, 05:57 PM   #13
Ryan
Member#: 15433
#98 ECHC H4 Integra
B18B (non-vtec 1.8L, I would put it at 140whp) - the block is original to the car. Honda Challenge/SCCA IT rules require you to run the same engine type that originally came with the car.
Old 10-30-2006, 05:57 PM   #14
Ryan
Member#: 15433
#98 ECHC H4 Integra
Originally Posted by ButtDyno View Post
Hoppe Sucks!!!
Old 10-30-2006, 09:43 PM   #15
teh Phil
Member#: 24888
Oh noes!!
He's looking at S2k's and Evos and then he'll probably instruct.
CRX Racecar For Sale (again) Jack NESIC Private Classifieds 10 05-25-2007 07:14 PM
Prepared Honda CRX racecar for sale Jack NESIC Private Classifieds 2 12-15-2006 08:18 PM
H5/ITB Civic and CRX Si Racecars for sale Zephyr Tri-State Area Private Classifieds 2 11-29-2006 11:44 AM
USTCC Subaru WRX Racecar for Sale B Esquire Private 'For Sale' Classifieds 9 11-23-2005 03:37 PM
USTCC Subaru WRX Racecar for Sale B Esquire Bay Area Impreza Club Forum -- BAIC 1 10-22-2005 01:14 PM
