Welcome to the North American Subaru Impreza Owners Club Thursday May 7, 2015
Old 11-10-2001, 01:57 PM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Default What size is that engine plug near the oil filter?
There is a big engine plug right next to the oil filter on our engines. Anyone know what size allen wrench it takes??? 12mm is to small and 14mm is to big but they don;t make a 13mm allen. I tried snap-on, Craftsman, and husky. none of them make one. it jumps from 12mm to 14mm to 17mm. I can't imagine that it is english. Called Subaru and they don't have a special tool for it.
Eric
Eric SS is offline   Reply With Quote
Old 11-10-2001, 02:28 PM   #2
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Why do you want to remove it?
yamarocket630 is offline   Reply With Quote
Old 11-10-2001, 03:07 PM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I need to get it off my EJ25 and put it into my EJ22T. I'm ready to start the car if it weren;t for that stupid plug!
Eric
Old 11-10-2001, 04:50 PM   #4
ylexot
Member#: 6878
2002 MBP 2.5RS
1994 GMC Sonoma
I wouldn't think it would be English either, but it can't hurt to try.
BTW - 13mm = 0.5118in which is pretty darn close to 1/2"
That's probably why 13mm isn't sold in the US
ylexot is offline   Reply With Quote
Old 11-11-2001, 12:10 AM   #5
cvalle-sd
Member#: 420
2001 Cr-V
Isn't that a drain plug for coolant from the block?
cvalle-sd is offline   Reply With Quote
Old 11-11-2001, 12:34 AM   #6
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Negative. It is a oil plug. There are two of them on the front of the block.
It is a 13mm. You can find one, but the only reason that I was able to get one that fit is because we had one at the bike shop that I work at.
If it helps, the thread inside is the exact same as the oil pan plug.
Impreza Rider is offline   Reply With Quote
Old 11-11-2001, 10:39 AM   #7
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
If all else fails, find and American car with any 13mm head bolt, and locktight two nuts jammed together on it. Then use a wrench or socket on the nuts. Unless the plug is @!#%% tight, it should come out this way. (old mechanic's trick when you can't find the right size allen wrench or socket)
Old 11-11-2001, 12:29 PM   #8
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Actually, it is a drain plug for the water. I'm talking about the one on the BOTTOM of the block, not the 2 on the front.
I ended up buying a 1/2" Allen wrench and it is a touch small. I stripped the bottom plug. luckily, one of the oil plugs on the front of the motor was the same size and not as tight so I barley managed to get that one off. Car runs awesome!
Eric
Old 11-11-2001, 12:56 PM   #9
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
ok...I know which one you were talking about now. Don't pay any attention to me
Old 11-11-2001, 09:42 PM   #10
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
from here:
http://www.scoobymods.com/mods/impreza/oilcooler.php
14mm there is such a thing, I got one...
Peaty
Peaty is offline   Reply With Quote
Old 11-11-2001, 11:49 PM   #11
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I have a 14mm also. Trust me, it does not fit the plug I needed.
Eric
Old 11-12-2001, 10:52 AM   #12
cvalle-sd
Member#: 420
2001 Cr-V
So what is the official procedure for draining amd refilling the coolant?
Old 11-12-2001, 11:20 AM   #13
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Before I got the proper allen wrench I tried the bolt with 2 nuts and some loc-tight trick. The nuts still turned. I ended up using a stud remover tool on the end of the bolt threads w/ the head in the plug, this on the end of a 24" breaker bar. Major pain. Of course when it finally did let loose I whacked my hand pretty bad.
Peaty
Old 11-12-2001, 05:05 PM   #14
Silver2000RS
Member#: 857
I agree with Peaty. The coolant drain plug is 14mm (9/16" will also work). Was your plug clean? Maybe you had some gunk in the plug that prevented the 14mm wrench from fitting.
I had to remove the plug on the driver's side for the block heater. I tried finding a 14mm allen wrench but failed. I also tried welding a nut and bolt (grade 8) together but the bolt sheared.
Finally, I drove to CarX and they had a 14mm allen 'L' wrench. Their strongest mechanic finally got it loose. (I though he was going to pop a vein in his neck. ) They only charged me $10 to loosen the plug.
I drove home and drained the coolant and installed the block heater myself. (My local Sube dealer wanted $80 for the full job!)
Silver2000RS is offline   Reply With Quote
Old 11-12-2001, 05:22 PM   #15
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
I ended up getting a 14 mm allen for just under 3 bucks from a tool supplier on the web. I didn't really need it because I finished installing the oil cooler. But since I spent so much time trying to locate one locally it was the principle of the thing. I forget exactly where but I think I have the URL at home. The wrench needed for each drain plug (right and left) is the same but the plugs themselves are diffent sizes. The drivers side one, the one for the block heater, is smaller for some reason. My wife's OB limited came with the heater but we've never used it.
What Temp is right time to check the oil. Chandy69 Newbies & FAQs 13 10-14-2009 05:33 PM
what size is the outside thread for the oil galley plug? NEED QUICK ANSWER Evo Killer Interior & Exterior Modification 6 10-09-2009 12:26 PM
'00 RS: What size is the oil plug? Siper2 Newbies & FAQs 8 12-22-2004 04:43 PM
What size is the socket for the oil drain plug Lever2ooo Service & Maintenance 8 05-08-2004 06:10 PM
Is the ATF filter and the oil filter the same size? Kwyjibo Service & Maintenance 6 12-06-2002 10:40 AM
