Old 10-30-2006, 09:10 PM   #1
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
Default Parts needed for an STI drivetrain swap into an 01 RS
Hey all, was wondering if anyone had a parts list of what is needed for a full drivetrain swap from an USDM sti to my RS. and if there is anything different needed from 04 to the 05+ drivetrain or if the parts are interchangeable(or what parts are interchangeable) thanks all
James
SubeSTIle is offline   Reply With Quote
Old 10-30-2006, 09:47 PM   #2
mjd85la
Member#: 35176
1998 2.5 RS Impreza
2000 gray OBX
Default part list
hope this helps some
heres my old list:
2.5l long block, injectors
Vf 39 turbo
Sti top mount intercooler
By pass valve
All piping from intercooler, hoses
Boost solenoid
Header, dp,up-pipe, cat-back
Intake manifold
Complete front cross member with Sti sway bar
Complete engine, chaise (bulkhead), rear harness
ECU
Waste gate control solenoid
Intake system (airbox, hoses, airflow sensor, etc.)
cooling header tank
coolant hoses (header tank to radiator, heater tank to overflow tank, heater)
power steering pump, reservoir, and all lines/hoses
fuel pump & controller
fuel level sender (full gas tank if you dont want remove anything)
tranny & motor mounts
6spd tranny w/ clutch, flywheel
Full DCCD harness, switches
Gauge cluster
Shift hardware
ABS unit for dccd
ABS pump ^^^^
Rear sub frame, mounts, w/ r180 diff.
Axles
Driveshaft
Trailing links
control arms
Radiator
Petal set with drive by wire
all associated switches relays, g-sensors
fuse box's
alarm boxes (opt)
integrated module
Steering Colum(need for +06)
Remote reservoir
Steering rack
Dash pad
Dash beam
Center bezel
Gauge cluster
Heater core
02 sensors
airbag system
airbag harness
full hub assembly
4 rotors
4 calipers, brackets
pads, etc.
mjd85la is offline   Reply With Quote
Old 10-30-2006, 09:49 PM   #3
RR02wrx
Member#: 99614
12 STi Limited
It's a long parts list. You can put pretty much everything on the GC except 05 stock rims IIRC. (04s = 17x8, 05s = 17x8.5)
I swapped as much as I could into my car:
Complete engine, harnesses from front to back, trans, entire rear end, suspension, fuel tank, brakes/hubs/rotors, subframe, k-member & tranny supports/etc... a ton of little parts I sort of lumped them all together. (This is all from an 04 USDM STi)
05 hubs are alot nicer than 04's I beleive. You can even do the interior, or do bits of the interior. The newer clusters will fit in the GC dash with very small amounts of modification to the cluster. Front/rear seats fit.. door cards do not.
There are modifications to the track people typically do during the swap because the track width is wider on the GD's. (GC rear lateral links, and GC front lower control arms.. most go with the aluminum STI ones - People also shim the front control arms - mind you I have done none of those but instead merely rolled my fenders)
RR02wrx is offline   Reply With Quote
Old 10-31-2006, 04:33 AM   #4
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
thanks for the input. i am just going to roll the fenders to fit the wheels. why do the 05 wheels not fit? do they rub on the inside or on the fender?
Old 10-31-2006, 09:39 AM   #5
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
I thoguht the 05 wheels will fit if you swap the hubs and brakes to an 05? I know they use a different hole pattern, 5x114 vs. the 5x100 the other Subarus use.
AaronB is offline   Reply With Quote
Old 10-31-2006, 05:15 PM   #6
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
thats what i was thinking also, since the track on the 05 isnt much different if at all from the 04 as far as width. thanks again for all the info.
James
Old 10-31-2006, 08:33 PM   #7
RR02wrx
Member#: 99614
12 STi Limited
05 rims are 8.0" wide and 04 rims are 7.5" wide, that is the only reason. If you had 04 rims on the 05 setup it would fit.
Again, I do not know this from experience. I just know this from being told through my searches on here during my swap experience, from people who told me they knew from experience..etc.
*edited* to change wheel widths
Old 10-31-2006, 11:44 PM   #8
slvr04sti
Member#: 125302
04 rims are 7.5
slvr04sti is offline   Reply With Quote
Old 11-01-2006, 02:11 AM   #9
RR02wrx
Member#: 99614
12 STi Limited
I tried googling looking for how wide 04 STi rims are for about 20 minutes and came up with absolutley nothing... I guess the 04's are 7.5 then and 05's are 8? Then the 05's should fit.. but I know I was specifically told the 05 rims will not fit on the GC.. Little drunk and I dont want to search anymore. Bedtime.. nite.
Old 11-01-2006, 02:44 AM   #10
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
04' STi bolt pattern = 5x100
04' STi BBS wheels = 17x7.5_ET53__(16.5 lbs)
05' STi bolt pattern = 5x114.3
05' STi BBS wheels = 17x8_ET53
Per http://forums.nasioc.com/forums/showthread.php?t=448097
Old 11-02-2006, 03:29 AM   #11
mjd85la
Member#: 35176
1998 2.5 RS Impreza
2000 gray OBX
nm.....
Old 11-02-2006, 05:59 PM   #12
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
another question, can i use a new tranny, say an 05 or 06 tranny with the 04 rest of the parts? i may end up piecing everything togeather as i can afford to buy parts and just wanted to make sure. Thanks again for all the help
James
Old 11-02-2006, 06:08 PM   #13
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
yes. I think the 07 has different ratios, but as far as I know the 04-06 trannys/diffs are interchangeable...
Keep in mind I don't have one, so I may be way off....
Old 11-02-2006, 08:49 PM   #14
zc911
Member#: 98256
quick question, can i leave the stock RS hubs and braking system alone if i cna;t get it right away? I am going ot be using 05 Sti parts (rear diff, and front/rear axles)
zc911 is offline   Reply With Quote
Old 11-02-2006, 08:51 PM   #15
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
If you use the STi rear diff you have to change everything in the rear.
If not you will need to change the gears in your rear diff to get the correct FD ratio, then you can reuse your stock rear.
Old 11-04-2006, 01:11 PM   #16
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
It's gonna cost you alot more if you buy it in pieces, It's gonna nickle and dime you to death. Try and save and then buy a complete drivetrain, THEN you can figure out what little parts you need.
John2.5RS is offline   Reply With Quote
Everything needed for a complete STI 6 speed drivetrain swap into an 02 Cyclops Transmission (AT/MT) & Driveline 244 05-18-2016 03:28 PM
4080's 05 STI reborn/swapped into a 01 GC 4080wrx Member's Car Gallery 92 08-30-2010 08:45 AM
04 sti drivetrain swap into 03 wrx please help!!!! mike739wrx Transmission (AT/MT) & Driveline 6 03-15-2010 03:36 PM
Need Info On Sti Block Swap Into 03 Wrx!!!! wrxtacy03 General Community 2 05-21-2008 10:08 AM
Parts needed for an STI drivetrain swap into an 01 RS SubeSTIle South West Impreza Club Forum -- SWIC 2 10-31-2006 04:15 PM
