Old 10-30-2006, 10:17 PM   #1
05blkwrx
Member#: 104954
05 wrx
black
Default alright guys a nitrous and meth question
i have a 05 blkwrx i have a vf34 565cc injectors, 255 fuel pump, ebay intercooler, and tbe....i was wondering before i take my to the dyno....which would yield me more power nitrous r meth.....these will only be run at the track...im leaning more to nitrous but let me know what u guys think
05blkwrx is offline   Reply With Quote
Old 10-31-2006, 01:09 AM   #2
Ultimate Collision Center
Member#: 69072
both like me, but if you want shear numbers nitrous will give you more...let me know if you need a kit...
Ultimate Collision Center is offline   Reply With Quote
Old 10-31-2006, 11:52 AM   #3
05blkwrx
Member#: 104954
05 wrx
black
but would a stock 2.0 internalls take both meth and nitrous
Old 10-31-2006, 11:56 AM   #4
Member#: 69072
It will certainly take meth and a 35 shot without a problem as long as you aren't running a fp green or 35r setup or something that is already pushing the limits...We had a wrx that ran a direct port 75 shot for over a year on race gas and it was fast, he finally blew the motor when he uped it to a 100shot...
Old 10-31-2006, 12:22 PM   #5
05blkwrx
Member#: 104954
05 wrx
black
so u think 50/50 meth and a 35 shot on a 116 map would be safe and quick too
Old 10-31-2006, 12:24 PM   #6
Member#: 69072
you won't even need 116 if you run 50% meth and nitrous...if tuned properly you will be very safe...
Old 10-31-2006, 12:27 PM   #7
05blkwrx
Member#: 104954
05 wrx
black
ok one more question where do i put the nitrous fogger...n the silicone between the intercooler and the intake shooting it directly in the intake...then where does the meth fogger go the same place
Old 10-31-2006, 01:24 PM   #8
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
I have an FP Red but I'm only pushing 422whp corrected which means 385whp uncorrected here at this altitude (5800 feet). I have a complete Nitrous kit in my garage from my WS6 LS1 that I'm thinking about installing with my Snow kit. I could activate when the nitrous with the pump wire.
For a small 35 shot, are we talking dry or wet nitrous?
R0DENT is offline   Reply With Quote
Old 10-31-2006, 01:50 PM   #9
SpeedR
Member#: 95401
MKIV STI
S4 951
You have to add fuel some how to not blow your **** up.
X amount of Oxygen needs X amount of fuel PERIOD.
If you run super rich and want to lean it out you can run a small shot, but then you have just eliminated your safety factor witch is y you were running rich to begin with.
SpeedR is offline   Reply With Quote
Old 10-31-2006, 03:49 PM   #10
Member#: 69072
If you have a fmic it makes the install very easy, if you don't then just mount the two nozzles as far apart as you can, I have my meth closer to the TB than the nitrous one...
Old 10-31-2006, 03:50 PM   #11
Member#: 69072
Wet shot is the only type of nitrous I like to use...I wouldn't have it activated with the meth injection instantly as you may have a really lean condition suddenly...I would use some sort of manual switch for the nitrous that way if something goes wrong you just let off the switch and the nitrous stops spraying, I have my switch on the dead pedal of my evo...
Old 10-31-2006, 03:53 PM   #12
PolarisSnT
Member#: 85905
2004 WRX
So if you are already tuned for 100% alcohol and want to add Nitrous, a retune is needed? Or since its a small shot its not necessary?
PolarisSnT is offline   Reply With Quote
Old 10-31-2006, 03:56 PM   #13
Member#: 69072
Depends on your mods but a small 35 shot in most applications will be fine...
Old 11-02-2006, 09:29 PM   #14
05blkwrx
Member#: 104954
05 wrx
black
cool hell yea i might have to do it
Old 11-02-2006, 09:34 PM   #15
Member#: 69072
do it...
Old 11-02-2006, 10:20 PM   #16
05blkwrx
Member#: 104954
05 wrx
black
how many people have actually done this and had there motors last
Old 11-02-2006, 10:25 PM   #17
Member#: 69072
I have 4 cars currently running the combo, one was an evo and the motor kicked the bed at 50K miles when we tried running a 100 shot...the motor was a stock motor and the bottom end just couldn't take the additional torque...
Old 11-02-2006, 10:26 PM   #18
Member#: 69072
If you look at the turbo GN which have been around since the early 80s they have been running this combo for a while...thats where I got the idea of doing it...
Old 11-02-2006, 11:26 PM   #19
05blkwrx
Member#: 104954
05 wrx
black
yea but turbo gn dont have the ****ty bottom end like we do
Old 11-02-2006, 11:30 PM   #20
Member#: 69072
This is true but a subaru that we were running had a stock 2.0l with a vf34 and a direct port setup and held up for over a year of extreme abuse on a 75 shot. We finally toasted the motor when we upped it to a 100 shot. The thing with nitrous is that you have to know your limits, its very easy to just up the jet size and the added power is noticable but their is a certain point in which your motor will not take it any more. If you go with a small shot you will have no issues.
Old 11-03-2006, 12:24 AM   #21
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
GN's don't have forged rods or crank like the STi has. Both share same crappy pistons.
Old 11-04-2006, 11:15 AM   #22
05blkwrx
Member#: 104954
05 wrx
black
its not the pistons im worried its the cheapass piston rings.......i dont know im just scared to run nitrous with boost cause nitrous effects boost differently
Old 11-04-2006, 11:24 AM   #23
Member#: 69072
It raises psi a little but nothing serious with a small shot...
BOV and METH question 05 WHT STI Newbies & FAQs 4 08-17-2009 12:15 AM
EWG 20G and meth questions turbochad Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 03-20-2008 10:16 AM
Any nitrous AND meth users here? japslapr Water/Methanol Injection, Nitrous & Intercooler Cooling 2 11-23-2007 07:19 AM
Misconceptions about Nitrous and Meth SpeedR Water/Methanol Injection, Nitrous & Intercooler Cooling 9 11-03-2006 01:40 PM
Does a black A-pillar pod look alright on a WRX and gauge questions thrillho Interior & Exterior Modification 9 07-30-2004 09:25 AM
