Old 11-10-2001, 05:02 PM   #1
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
Default Blitz SUS Induction Kit, Al? Anyone?
Did you ever find out if the Injen made any difference over the Blitz SUS? Finally, does anyone have the Blitz SUS in stock? I'd like to pick one up.
Conduit is offline   Reply With Quote
Old 11-10-2001, 05:56 PM   #2
Bradus
Member#: 10036
2008 Infiniti G35x
Volvo XC90-T6
I ordered my Blitz SUS from Titan Motorsports and the contact person is Bottle ([email protected]).
According to the ETA told to me, my unit is supposed to arrive this week. Not sure what their stock situation is like.
David
Link to Titan Motorsports web site: http://www.ecarshops.com/Merchant/me...&Store_Code=TM
Bradus is offline   Reply With Quote
Old 11-10-2001, 06:47 PM   #3
Jan Shim
Member#: 6366
1998 WRX Wagon (Ret)
Default ... or Sard EX+ drag filter!
All this while on iClub i have ignored posts about induction kits and i recall rather vaguely there was once a 'war' between the Blitz SUS and Injen CAI kits .. curious, I did a search to see what the Blitz SUS kit is about and quite disappointed to see it's nothing more than a standard induction kit comprising of a pod filter, fitting adapter and mounting braket. The bit that concerns me as should the rest of the Subaru community is the poor filtration of the Blitz filter element as tested ...
http://www.mkiv.com/techarticles/fil...t/1/index.html
http://www.mkiv.com/techarticles/fil...t/2/index.html
... there are variety of air induction kits offered at my vendor's shop but few for the New Age GDA, except Apexi Power Intake and Sard EX+ Top Intake. I've decided to talk a little bit about the uniqueness of the Sard item, this being the second generation design and has a potential for being a better choice than the Blitz. Firstly, it comes complete with an adapter pipe on which the stock MAF sensor is migrated from the factory pipe.
Jan Shim is offline   Reply With Quote
Old 11-10-2001, 07:08 PM   #5
Jan Shim
Member#: 6366
Secondly, the SARD EX+ features a removable rubber pad that you can remove at the drag strip for an unfiltered and less back pressure suction, like the big drag boys! In addition to this, SARD provides an option Racing Funnel that is said to optimise air flow through the 'top intake'.
Thirdly, the entire SARD filter housing is wire enforced so there's little chance of it collapsing or subject to easy damage unlike other Japanese filters I have personally encountered.
Old 11-10-2001, 08:30 PM   #6
subywan-kenobi
Member#: 4268
2002 WRX Wagon
WR Blue Pearl
Rob, if you can't find one through any of the vendors, I may be willing to sell you mine as I might be switching to the AEM or perhaps SARD when I do the TEC testing. I have PM'd you the details if you are interested.
Mike S.
subywan-kenobi is offline   Reply With Quote
Old 11-10-2001, 08:40 PM   #7
Conduit
Member#: 6162
I think I am a little confused. The Blitz SUS doesn't come with a new MAF housing? That's kinda goofy for a bracket and filter Also, does anyone have concerns about the SUS filtration level?
Jan, are you selling this Sard goodie also? I'll try and catch ya online.
Mike, what are your thoughts on the SUS? Why switch to the Injen or AEM?
I just want something to mount to my new samco inlet hose
Old 11-10-2001, 08:56 PM   #8
Conduit
Member#: 6162
Ok Jan, I read your links Is the Apexi kit available now through you? I am all about that
Old 11-10-2001, 09:02 PM   #9
subywan-kenobi
Member#: 4268
2002 WRX Wagon
WR Blue Pearl
Here is the picture of what the Blitz looks like Rob:
As you can see in Jan's picture, it is pretty much the same setup as the SARD: an adapter fitting, the filter, and a mounting bracket.
I have been pleased with the gains of the Blitz unit. Good gains across the power band, but noticeable gains in the first 2 gears where I felt like the car lacked some. I'm sure the filtering properties aren't as good as some of the other units, but here in the Bay Area, I'm not too concerned about my engine ingesting anything too harmful especially since the unit is in the engine bay and not the fenderwell.
The AEM and the Injen I think are both CARB approved and visually, the intake is noticeable if I was pulled over, so I might fare better with the law. Perhaps that won't matter though once the TEC is installed!!
Mike S.
Old 11-10-2001, 09:07 PM   #10
Conduit
Member#: 6162
Mike, you should pick up a nice black samco inlet hose to go along with that, 188 from forge motorsport I PM'd ya.
Old 11-10-2001, 09:24 PM   #11
subywan-kenobi
Member#: 4268
2002 WRX Wagon
WR Blue Pearl
Already ordered 2 days ago!!
Mike S.
Old 11-10-2001, 09:31 PM   #12
Bradus
Member#: 10036
2008 Infiniti G35x
Volvo XC90-T6
Conduit and Mike S.
What is the samco inlet hose? Is this something to go with the Blitz?
Thanks,
David
Old 11-10-2001, 10:00 PM   #13
subywan-kenobi
Member#: 4268
2002 WRX Wagon
WR Blue Pearl
As requested, here is the pic of the Samco piece:
It replaces the restrictive black plastic piece connected to your compressor wheel opening of the turbo. You then connect the intake to this piece.
Mike S.
Old 11-10-2001, 10:11 PM   #14
Jan Shim
Member#: 6366
OK, here's the deal with the Apexi Power Intake. I fitted one about six months ago convinced after i had seen the filtration test results. In a matter of four months from initial use, I noticed the filter assembly exhibiting signs of fatigue .. seems as though the lattice structure of the weakly wired pleats just collapsed. I installed the filter myself and it had never been subject to the mishandling of workshop mechanics so I thought this occurence was too weird.
Then i recall (and you guys might have read in my earlier posts) having encountered engine stutters/hesitation after hitting a deep flood on my very wet afternoon. The engine compartment around the filter was completely soaked, I'm certain the filter element was equally soaked and ingested a healthy gulp of moist filtered air. Not too long after this incident, the filter element just mysteriously collapsed as shown. I attribute this weakness to poor design and compromised structural integrity. Looking at the pic, you can see only one side of the filter assembly has a pillar support, the rest of it none. Had the Apexi Power Intake design take the approach of Sard for example, it would not look so sorry under such wet circumstances!
I know this isnt a freak one-off occurence as there are two more Power Intakes that suffered the same fate. It's almost impossible to avoid water ingestion over here.
Old 11-10-2001, 10:11 PM   #15
Torch
Member#: 10172
Where can you pick up one of those?
Torch is offline   Reply With Quote
Old 11-11-2001, 07:06 AM   #16
Bradus
Member#: 10036
2008 Infiniti G35x
Volvo XC90-T6
Mike S.
Thanks Mike. This is great.
Did you order this from the UK (where Forge is based) or is there a US-based supplier you could recommend.
Also, I went to the web site and saw numerous Samco pieces for Subaru but none specifically said 2002 WRX. Which part number did you order?
Thanks,
David
EDIT: I have found some US suppliers of the Samco pieces. I would still be interested in knowing which part number you ordered - thanks. The pipes are available in Blue or Red according to one dealer (www.rallyperformance.com).
Old 11-11-2001, 07:48 AM   #17
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Default That samco piece.....
Does it replace the "ribbed", flexible section of the intake in this pic?
Or does it replace the hard plastic section after that? That ribbed section really bothers me, there should be a substantial pressure drop (restriction) through something like that. Is there a easy mod to replace that with something smooth?
Kevin
Red Rocket is offline   Reply With Quote
Old 11-11-2001, 10:00 AM   #18
Jan Shim
Member#: 6366
Default Re: That samco piece.....
Kevin
No it doesnt. It requires another aftermarket pipe such as this one by ZeroSports This pipe is sold either together with the ZS intake filter or a single product. Check their website for product info and part number if any.
Old 11-11-2001, 12:06 PM   #19
Conduit
Member#: 6162
Is there some particular reason why noone makes an intake that goes from the filter to the turbo?! I mean, dear me, three parts from three seperate vendors just to get an INTAKE? The Injen and a Samco are looking better and better.
Old 11-11-2001, 12:31 PM   #20
subywan-kenobi
Member#: 4268
2002 WRX Wagon
WR Blue Pearl
I was just thinking the same damn thing Rob!! I mean that is pretty stupid if you ask me, I have to order parts from 3 separate companies just to have my intake the way I want it.
Bradus, I don't have any part #'s, but the vendors who can get this stuff sell them in different kits and should know what you are talking about: The piece shown above is known as the high velocity turbo inlet pipe, then there is the IC set, which consists of 3 more hoses, and there is also a set of 2 hoses for the radiator set.
I ordered mine from Forge through this thread in the vendor classifieds:
http://www.i-club.com/forums/showthr...hreadid=110535
Jan, does your vendor stock that Zero Sports piece or can you get it at least??
Mike S.
Old 11-11-2001, 01:12 PM   #21
Bradus
Member#: 10036
2008 Infiniti G35x
Volvo XC90-T6
Jan,
I'm interested in knowing more about the Zero Sports piece too.
If you can post vendor info here please.
Thanks,
David
Old 11-11-2001, 01:25 PM   #22
Conduit
Member#: 6162
Bah, I'm getting the new AEM in the private GB. That does what the other intake does plus the zero sports pipe. Thanks all, these guys are really dropping the ball.
take care,
rob
Old 11-11-2001, 06:06 PM   #23
Jan Shim
Member#: 6366
Originally posted by Bradus
Jan,
Thanks,
David
I'm sorry David, i dont know which vendor in the USA carries ZeroSports products. Even my vendor here has stopped stocking their products as it simple costs too much compared to other competiting Japanese products. Seems though ZeroSports is the only one that has a complete range of Impreza goodies from intercooler scoop air splitter to radiator top shield (actually drops 2-3'c in water temps), etc. Good luck!
Old 11-11-2001, 06:18 PM   #24
Bradus
Member#: 10036
2008 Infiniti G35x
Volvo XC90-T6
Okay Jan, thanks anyway. I just liked the look of the piped featured in the picture you uploaded.
Cheers!
David
Old 11-12-2001, 11:20 AM   #25
subywan-kenobi
Member#: 4268
2002 WRX Wagon
WR Blue Pearl
Bradus, if you really want that piece, talk to Imprezer, he can get you anything from Zero Sports or any JDM company for that matter. As for me, I think I am going to go the AEM route for sure for the same reasons Rob posted.
Mike S.
FS: Blitz SUS intake, TurboXS RFL-H BOV, Thule fit kit cavi Engine/Power/Exhaust 0 11-26-2006 10:03 PM
Blitz SUS air intake kit lawn boy Private 'For Sale' Classifieds 3 09-08-2005 05:54 PM
FS Blitz sus intake system (new) and WRX tuner water injection kit M32WRXin3seconds Tri-State Area Forum 3 02-19-2004 11:19 PM
Anyone have Mach V's unichip map for TurboXS Stage 1 or 2 WITH Blitz SUS? Verdugo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-26-2002 12:19 PM
Are there any blitz induction kits for the RS?HELP DarkLite Technical Forum Archive 3 09-16-2000 07:51 PM
