Old 11-29-2006, 05:39 PM   #26
kingsubi
Member#: 19239
2011 WRX
Originally Posted by Unabomber View Post
Differential FAQ
So what should I upgrade my car with?
RS/WRX center: JDM STi 20kg center viscous unit. This increases the break away torque from the stock 4kg unit to hold rear traction longer.
Just to add here that the 20Kg/mm center is not a very street friendly at all and that STi offers a 12 Kg/mm center diff (rallispec can get them) that provides a great alternative to dccd for beefing up the AWD system.
kingsubi is offline   Reply With Quote
Old 11-29-2006, 08:35 PM   #27
BIGSKYWRX
Member#: 7958
09 GH B+
What advantages would one see going from a vicous unit in the rear (WRX) to a Torsen type?
Is there a readily available rear Torsen/helical unit for the WRX?
TIA
Old 11-29-2006, 09:05 PM   #28
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Yes there is. www.gearboxtech.com sells a Torsen type PPG rear differential. Someone else may make one as well, but that's all I know off the top of my head. As to the advantages...that's a toughy as you have some issues:
viscous vs torsen theory
viscous vs torsen practical application
The theory is that the torsen will be a more stable upgrade in terms of reliability and torque transfer.
The practical application is that the torsen will give you more rear grip.
Both of these are relative offerings based on what I've heard though as like suspension components, you have a quality/known part that is designed to do XXX and there's always a bunch of jackasses that post that it does YYY.
Old 11-29-2006, 09:18 PM   #29
BIGSKYWRX
Member#: 7958
09 GH B+
^ thanks. I need to start w/ the front- that much I do know
Old 01-31-2007, 04:36 AM   #30
Skoobie
Member#: 139327
Default 2 Way Center Diff
What will a 2 way center diff do in an all wheel drive? Specially with a 1.5 front and rear (not main concern but answer if you like or know, the more knowledge i get the better) Thanks.
Skoobie is offline   Reply With Quote
Old 02-01-2007, 03:56 PM   #31
lh0628
Member#: 138256
2004 FXT
Great post! Thanks.
lh0628 is offline   Reply With Quote
Old 03-02-2007, 11:51 AM   #32
Chapel
Member#: 3496
1995 Roadmaster
Beige
What lock % is the stock WRX Rear diff capable of?
Where can I find the STi 20Kg center diff?
Chapel is offline   Reply With Quote
Old 03-02-2007, 11:54 AM   #33
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Sti 20kg center can be found at www.rallispec.com
I believe its 978
Old 03-02-2007, 12:10 PM   #34
Chapel
Member#: 3496
1995 Roadmaster
Beige
what about the 12kg one? is that special order?
Old 03-02-2007, 05:21 PM   #35
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
12kg is damn hard to find and wont bolt up to our new RS/WRX trannies, hence it's not mentioned.
Old 03-13-2007, 05:26 PM   #36
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Originally Posted by bWRX View Post
I am not finding this FAQ to clear up a lot of my confusion regarding the various diffs that have been supplied stock in the USDM STi.
The 2007 apparently have a Torsen in the rear, as a new thing. I've noted a few posts talking about this like its a really significantly great improvement for some reason. But according to your FAQ, 2007 is the third model year for the USDM STi to have torsens in both front and rear - the 2004s had a suretrac unit in front.
As near as I can tell, it went like this:
2004 - Suretrac front, "mechanical" rear
2005 - "Helical" front, "mechanical" rear
2006 - "Helical" front, "mechanical" rear
2007 - "Helical" front, "Torsen" rear
Now, if really, for all intents and purposes, Torsen = helical = mechanical, I'd like to hear you explain why that is, but me and a lot of guys like me are still standing around out here wondering what the tiny little differences between these various units are, or where we can go to research it ourselves. There is a lot less general info about diffs out there than there is, say, suspension or forced induction concepts.
Thanks!
Here are the part numbers for each of the diffs (front, rear, and center)
Rear Diff
38410AA080 - 2004 Rear Diff Unit
38410AA080 - 2005 Rear Diff Unit
38410AA120 - 2006 Rear Diff Unit
38410AA140 - 2007 Rear Diff Unit
NOTES: 04 and 05 are the same. I have taken an 04 Diff apart, and rest assured it is clutch pack based. 2006 had a new rear diff, as did 2007.
Front Diff
38410AA060 - 2004 Front Diff Unit
38410AA100 - 2005, 2006, 2007 Front Diff Unit
NOTES: Sure enough, the 04 US 6MT had a Suretrac front diff, as the 060 part number is also used in the Version 8 JDM 6 Speed ( C, D ). 05, 06, and 07 all have the same front diff.
Center Diff (DCCD)
38913AA160 - 2004, 2005 Center Diff Unit
38913AA190 - 2006, 2006 Center Diff Unit
NOTES: 04 and 05 has the same center DCCD unit, which was upgraded in 06. The center diff used in all cases (160 and 190) are the same as used in the JDM 6 speed of the same years. AA160 was used in C,D, and E JDM 6 speeds, and AA190 was used in F and G.
sponaugle is offline   Reply With Quote
Old 03-13-2007, 10:01 PM   #37
Skoobie
Member#: 139327
Bump, i would really like to knnow about this
Originally Posted by Skoobie View Post
What will a 2 way center diff do in an all wheel drive? Specially with a 1.5 front and rear.
Old 03-14-2007, 02:13 AM   #38
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Here is a quick look at all three diffs in the US cars.
JDM and EU coming.
Jeff Sponaugle
Old 04-25-2007, 12:34 PM   #39
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
How does it drive on the Street? I guess you mean by wheel hop on turns or binding?
SubaruImpreza_power is offline   Reply With Quote
Old 04-26-2007, 01:56 AM   #40
Platis
Member#: 147256
Default Subaru Center Diff
Dear friends
I am writing from Greece, so please forgive me for my poor English. I need your help, i see you know many details about diffs!
I am rallying in Greece (Gravel Rallies) using a Prodrive Impreza N8 2002. Recently my center diff has been broken. It is an " Early Grey 2001" one, named by Prodrive. I have searched to find a rerpair kit, there is no availability worldwide. So i decided to buy a brand new "Golden'' (named by Prodrive) one, Part No 38913AA190. Alternatively i can find a 38913AA160 too. The problem is that a Subaru Technician-friend of mine- told me that this new C.D will blow up if i will use it with my curent ECU ,which is The Pectel-Prodrive one. And he told me also that it may work properly connecting (interfering) on the C.D. leads a resistance (resistor).
Is this correct? Do somebody Knows something about? Please help me,replying here or by Email at [email protected].
Many thanks in advance
Platis.
Platis is offline   Reply With Quote
Old 04-26-2007, 06:49 PM   #41
Platis
Member#: 147256
I am a scooby newbie. So i cannot send by Email my questions to Unabomber. Please could somebody do this for me?
Thank you
Platis
Old 06-10-2007, 01:21 PM   #42
Menik
Member#: 105966
2005 Cobb Stg2 STi
w/ WRX Wing & Roof Vent!
Originally Posted by Platis View Post
Dear friends
Platis.
I would ask prodrive directly, they're surprisingly helpful: [email protected]
Menik is offline   Reply With Quote
Old 08-01-2007, 07:13 PM   #43
impreza_GC8
Member#: 123295
2000 2.5RS moneypit
2012 Ford Fusion 6MT (DD)
Very informative writup, thanks! Just one thing I noticed that wasnt addressed however (and the reason why I was searching this thread in the first place).
I read an article on Differentials that stated that Viscous-type Diffs begin to lose their LSD coupling ability after 60,000 miles or so due to degradation of the viscous fluid. If this is true, my RS has 83,000 miles on it, so my rear LSD is acting more like an open diff than it was when it rolled off the dealer showroom in 2000. This is worrysome to me, so is it worth replacing to a gear-type LSD that wont wear out after 60,000 miles? Thanks.
impreza_GC8 is offline   Reply With Quote
Old 08-01-2007, 07:49 PM   #44
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Sounds bogus to me. The visous fluid is silicone and silicone does not wear out. I could be wrong, but I don't think so.
Old 08-02-2007, 01:43 AM   #45
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
EVERYTHING wears out eventually, but I have no clue what the operational life of a vlsd unit would be. Well... when I tried hand-turning rear wheels with my 90k mile vlsd diff... the wheels spun in opposite directions and felt exactly like an open diff, but who knows? I have a clutch-type now... Love it love it, but it is really clunky when making sharper turns and has enough bite to sometimes chirp a tire during tight parking lot turns. And all this even using actual subaru LSD oil (even came in a blue can with all kinds of japanese characters on it and almost no english).
jhargis is offline   Reply With Quote
Old 08-02-2007, 09:23 AM   #46
Skidd
Member#: 1853
GC6 Supercharged
STM
As I understand the VLSD, you in fact "should" be able to turn the wheels by hand. the limited slip coupling doesn't kick in until the fluid heats up enough to lock the sides. I don't think turning by hand applies enough force to heat up the fluid. Or am I way off here?
Skidd is offline   Reply With Quote
Old 08-02-2007, 11:49 AM   #47
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
From how I understand the principle, your theory is correct. I mentally imagine it as wizards and elves, but smart people say silcone fluid heats up and fills grooves, then *insert magic event here* and your LSD is a real LSD.
Old 08-02-2007, 02:14 PM   #48
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
That is why a VLSD sucks! You have to have a wheel spin (not just slip) for it to even start to work.
Crazykev is offline   Reply With Quote
Old 08-02-2007, 02:22 PM   #49
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
You'd think there would be enough preload/friction/drag/etc. there to at least get the other wheel to turn in the same direction though... I guess not.
However vlsd works, it was slow to react and when/if it did it wasn't particularly noticable. I could never get the tail out with my vlsd, even in the wet, and never wanted to risk hitting the e-brake and stressing the center diff... With the clutch type, it's just a matter of some streering wheel rotation + some added throttle, and whoa I'm going sideways! Absolute day and night difference.
Old 08-02-2007, 02:49 PM   #50
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
That is how my Suretrac is. Steps the rear right out The cusco center diff helps too.
Injector, Fuel Pump, and Fuel Rail FAQ: Read if you are thinking of upgrading! Unabomber Newbies & FAQs 180 09-13-2016 02:41 PM
Transmission FAQ: Read if you are thinking of upgrading! Unabomber Transmission (AT/MT) & Driveline 219 07-03-2016 06:59 PM
Turbo FAQ: Read if you are thinking of upgrading! Unabomber Newbies & FAQs 213 06-14-2016 10:24 PM
Suspension & Driveline FAQ: Read if you are thinking about upgrading! Unabomber Brakes, Steering & Suspension 82 05-06-2013 08:47 PM
Turbo FAQ: Read if you are thinking of upgrading! Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 70 06-19-2006 04:37 PM
