Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 09-14-2008, 11:45 PM   #76
xyzalvarez
Member#: 188341
booked
xyzalvarez is offline   Reply With Quote
Old 10-26-2008, 05:51 AM   #77
BurschiK
Member#: 109250
Edit:
Sorry Unabomber, I hope it's better now?
Will the JDM STi V5/6 TYpe RA front diff (Helical, 5MT) fit in a RS/WRX gearbox?
Will this effect more understeer at turn in?
http://www.rocketrally.com/website/i...roducts_id=304
BurschiK is offline   Reply With Quote
Old 10-26-2008, 09:25 AM   #78
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Has anyone learned how to post appropriately?
Old 10-31-2008, 02:51 PM   #79
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
Originally Posted by llavalle View Post
Alright, here's another one...
Possibility 1) In that case, that wouldn't be call "Symmetrical AWD"..
If the viscous coupling unit is "plugged" at the rear of the transmission like it appears to be in your image(between the transmission and the driving shaft), that means the following :
1-Front wheel are ALWAYS turning at the same speed as the driven shaft
2-Rear wheel are connected to the driven shaft by a viscous coupling
Driven shaft = lower shaft in the picture I posted.
That means that, if I floor it when I'm on ice(4 wheels on ice),
1-The front wheel start to spin
2-Since the transmission side of the coupling is turning faster than the driving shaft side, the viscous coupler reacts and start turning the the rear wheels
3-All 4 wheels spins
Possibility 2) More plausible, that is a 50/50 symmetrical drive
More something like : (the drawing is right, it's the colors I'm unsure about)
Mauve Color : Input from engine, travels by the gears to the green shaft
Green : Hollow shaft connected from the gears to the central diff
Blue : pinion shaft connecting the front side of the diff to the front wheels
Red : Gears(probably a reduction of the outout speed to lower the driving shaft vibrations) and shaft connecting the rear side of the diff to the rear wheels.
Is that right.. I'm unsure about the hollow shaft with the pinion shaft going through... Can anyone confirm this...
1-Hollow shaft is always spinning at the same speed as the diff casing
2-Front wheels are connected to one side of the diff
3-Read wheel are connected to the other side
1-All 4 wheels spin... if traction is equal on the 4 wheels.. and if you don't take into account the inertia of the driving shafts, joins, etc etc.
Which one is right?? I'd go with #2.. am I right?
I'm talking about a regular Impreza... manual transmission( I know the automatic isn't using a viscous coupler... but it should look almost the same)
So did anyone ever answer this post? I'm finding this to be good reading material and the discussions stopped cold.
scramjett is offline   Reply With Quote
Old 01-09-2009, 09:40 AM   #80
thejean
Member#: 17763
Originally Posted by sponaugle View Post
Here is a quick look at all three diffs in the US cars.
JDM and EU coming.
Jeff Sponaugle
Hey Jeff, you never did post the diff types for the JDM rear diffs. Do you have these?
thejean is offline   Reply With Quote
Old 01-19-2009, 08:10 PM   #81
Dave_RalliSpec
Member#: 45702
To add a couple points of information to this very cool thread:
1. Viscous LSD's are speed sensing. The work by reacting to speed differences between the two axles. They are limited in the time it takes them to respond and therefore they are not an ideal solution. They are designated by their torque reaction per difference in rotational speed. For example the stock unit is 4 kgf-m (torque reaction) / 100rpm (speed difference). Increasing this value increases how quickly it can respond because it will be able to redirect more torque for the same difference in shaft speeds. However, if the value is increased too much then a small difference in shaft speed (such as one that occurrs in a normal tight radius corner) will generate enough torque reaction as to create a noticeable understeer condition.
2. Gear type LSD's and clutch type LSD's are torque sensing. They respond to torque input and/or torque differences across the drive shafts. They do not need to be waiting for a speed difference (as in wheelspin) to be doing their job. These types of LSD's are designated by their bias ratios. Basically what ratio of the torque at the low traction side can be redirected to the high traction side.
3. Torsen, Quaife, and Helical LSD's are all very similar...all gear types that involve complex interactions between the gear teeth to do their job. Quaife and Helical LSDs both use helical type gears. Torsen uses a worm gear arrangement. These LSD's typically have bias ratios in the 1.5 to 4 range I think. However, most are not set up with any preload (although it is possible to build in some preload with these LSD's by shimming the end play of the gears against the case to a certain amount of interference fit). Therefore when the torque at one wheel is zero or very near zero (wheel off the ground or on ice) then the LSD cannot transfer any torque to the other wheel (anything multiplied by zero is still zero!).
4. Clutch type LSD's (Salisbury type...also known as plated diffs) use stacks of clutch plates alternately splined to the axle and the diff case. Pressure to apply the clutch packs comes from a set of pressure rings. The spider gear cross shaft rests on sets of ramps cut into the pressure rings. When torque is applied to the diff the shaft rides up the ramps and forces the pressure rings apart thereby applying the pressure to the clutch packs. Clutch type LSD's set up for racing generally have very high bias ratios (upwards of 6:1 I think). They also can be set up with significant preload if desired. The preload on the clutch plates ensures that the LSD can still do something even when there is no zero traction at one wheel.
5. The DCCD's open torque split is determined by the tooth arrangement of its planetary gear set. Unlike a typical diff's spider and pinion gear arrangement which gives a 50/50 split as long as available traction on both axles is equal, the planetary gears provide a torque split biased toward one end (be it 35/65 or whatever it is designed for) as long as available traction is equal. Attached to that planetary gear set is a clutch pack and a second clutch pack controlled by an electromagnet. The pressure on the clutch pack (which biases torque back toward a 50/50 split) is determined by the current flowing through the electromagnet. Therefore it is a clutch type LSD that can be electronically controlled to alter its operating characteristics.
In terms of tuning the clutch type LSD, your options are as follows:
A. Preload setting -- increasing preload increases its effectiveness in very slippery conditions. However, this preload must be overcome in order to go around a corner (which is why these LSD's when set up with any measurable preload will make noise). It will generate understeer. Preload is set both by a preload spring (some types use a bellville washer but Cusco's RS type uses coil springs) and also by the stack height of the clutch pack (the thicknesses of the clutch plates).
B. Ramp angles -- there are two ramp angles, one that influences on-throttle operation and one that influences off-throttle (decel) operation. When an LSD is described as 1way, 1.5way, or 2way they are talking about the off-throttle ramp angles. 1way types only offer LSD action on acceleration and have no ramps on the decel side. 2way types have equal ramp angles for both accel and decel. With 1.5way have steeper angles on the decel side vs. the accel side so it takes more torque to create the same pressure (basically on decel the LSD is working but less effective). Some manufacturers for some reason use other values such as 1.6way or 1.7way but they are just describing the relative angles from one side to the other.
C. Active friction surfaces (lockup percentage?) -- By altering the arrangement of clutch plates (outer splined vs. inner splined plates) you can alter the number of "active" friction surfaces in play. Reducing the friction surfaces reduces the bias ratio.
In terms of general recommendations....
Front LSD: for track, autox, and street use most people find that a gear type front LSD is most predictable and easiest to drive near the limit. It does not generate much understeer on corner entry due to the absence of preload and the low bias ratio under decel. A 1way clutch type LSD can be just as, if not more, effective when set up properly for the conditions and the driving style of the user. But if it is not set up well then it will cause difficulties for the driver. For slippery conditions such as rallyx, iceracing, rally, etc. it will be beneficial to run a 1.5way plated front LSD as it will help with braking stability. Preload should be set according to available traction and driver preference. For tarmac drivers having difficulty under braking it can also be worthwhile to try a 1.5way LSD with low preload.
Center LSD: I am very interested to try the PPG Torsen center LSD but have not yet had the chance. I suspect it may be an excellent track option. I would avoid using a 20kgf center viscous except for gravel, snow, or ice...or maybe straight line drag racing. On high speed tracks with no tight corners it may be OK but it will be counterproductive on tight tracks or autox. The Cusco Tarmac gear is worthwhile only when you have good front and rear LSD's to back up the fact that it is an open diff.
Rear LSD: There are very few instances for racing applications where I would not recommend a clutch type rear LSD. They are so tuneable that there is no reason not to use one (other than the need to rebuild it every season or every other season). The stock viscous unit used in the WRX and 2000-2001 RS models is essentially useless (the unit is so thin as its packaged off the side of a standard open diff and its capacity is very limited). The factory R180 clutch type LSD is set up extremely loose from the factory and should be rebuilt with appropriate preload and possibly different pressure rings if you want to use it for racing. For a street application the stock Torsen or a Quaife unit is usually preferrable from the standpoint of not needing to be rebuilt and creating very little noise.
I guess if anyone has any questions they can email me (please don't PM me I don't check them very often). I also have a somewhat complete JDM transmission chart if someone needs info on factory diffs, gear ratios, or whatever. Me and Jeff actually cross checked some of our info at one point.
Dave_RalliSpec is offline   Reply With Quote
Old 01-20-2009, 12:19 AM   #82
thejean
Member#: 17763
Thanks Dave. That post should be added to the differential FAQ.
Old 01-20-2009, 10:21 AM   #83
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Damn right it should be and I did add it. My undying thanks Dave!
Old 01-22-2009, 10:09 PM   #84
thejean
Member#: 17763
Dave, I see the R180 angle rings on your website aren't all that expensive. Is this a DIY type item or does it require a tranny specialist to install. I have the rear diffs out of the car and without fluid so now would be a good time to do this upgrade... Thanks, JC
Old 01-23-2009, 10:44 AM   #85
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You'll have to email him about that. To my knowledge, if you know what you are doing, you can do it.
Old 04-18-2009, 11:28 PM   #86
JohnnyBlaze420
Member#: 165364
2004 WRX STi
I heard from someone that having different sized tires (sidewall) or having one underinflated on an STi for an extended period of time causes damage to the differential/transfer case. I was just wondering if this was true and how long you would have to be driving with your tires in that condition for that to occur. I have a feeling he was blowing smoke up my @$$ but I was still curious nonetheless.
JohnnyBlaze420 is offline   Reply With Quote
Old 04-18-2009, 11:47 PM   #87
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Your owner's manual called, it wants you to find the answer to this there. As to how long it will last until it exploded, no one on the planet knows.
Old 05-13-2009, 03:52 PM   #88
suub07
Member#: 163702
2007 impreza 2.5
UGM
take a look at this thread, its both interesting and somewhat entertaining.
suub07 is offline   Reply With Quote
Old 05-14-2009, 02:43 AM   #89
mmario4
Member#: 211333
2009 WRX
It was a storm today. Wind, rain, dark clouds. Prefect opportunity to take off the traction control to learn how my new 2009 WRX at slip angles performs. I was applaud to find what seemed like open differentials.. A couple more tests seemed to confirm that I wasn't just overpowering the differentials but that they where really acting like open differentials..
I come to this tread only to confirm that sad news that I had discovered only a few hours earlier while gaining seat time. Guess I will have to stick with TCS ON for a while.
Thanks for the great post on differentials btw.
mmario4 is offline   Reply With Quote
Old 05-29-2009, 12:20 PM   #90
impreza_GC8
Member#: 123295
2000 2.5RS moneypit
2012 Ford Fusion 6MT (DD)
I've searched but haven't been able to find how to tell what transmission and diff are in my car based on their stamped numbers. My car has had a few different engines and transmissions in it and I don't know what its current setup is. It feels like a 4.44 when compared to my 2.5RS which has 4.11 and turns lower RPM.
EDIT: I found NorthUrsalia's listing but its a bit then when it comes to the USDM models. Additionally, where is the transmission code located?
DOUBLE EDIT: Got it all sorted out.
impreza_GC8 is offline   Reply With Quote
Old 06-26-2009, 02:53 PM   #91
scottdaniels13
Member#: 215210
Anyone know where I can find a 4.11 rear ring and pinion for my 1993 Subaru WRX Type RA JDM?? Im stumped finding one that will fit
scottdaniels13 is offline   Reply With Quote
Old 06-26-2009, 08:34 PM   #92
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
I can tell you where to go though, but people would call me mean. We have an ENTIRE parts wanted forum, try there rather than crapping in a thread.
Old 02-18-2010, 01:58 AM   #93
nos
Member#: 53129
02 WRX cobbstage2
The very rare WRB
What would be easier: taking out the stock r160 on the 02 WRX 5speed and replacing it with another one, or puting in a replacement LSD in the current diff? My LSD is shot. I don't race or need anything spectacular. I just want to have both wheels spin when I'm in some snow.
nos is offline   Reply With Quote
Old 02-18-2010, 07:30 AM   #94
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
We all have opinions, but I think swapping out the entire pumpkin would be easier than swapping out the guts. Just make sure you get a 02-05 WRX R160 which has a viscous LSD in the rear as some newer and older R160s have open diffs. There may be other years with viscous diffs, but that's what I know off the top of my head.
Old 04-15-2010, 02:27 PM   #95
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Any further info on the 6-speed center diff options for us JDM Non-DCCD owners?
subydude is offline   Reply With Quote
Old 05-30-2010, 08:14 AM   #96
555
Member#: 20161
1998 Impreza ST
555
What is the max operation temperature Subaru differatials? I mean the max temp when the ecu gets the difftemp light on.
555 is offline   Reply With Quote
Old 05-30-2010, 09:22 AM   #97
carnz-pj-410
Member#: 110994
RS Coupe
1988 FZR400
rear diff light comes on when the fluid gets above 302F*
carnz-pj-410 is offline   Reply With Quote
Old 06-28-2010, 11:52 AM   #98
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Anyone using a Cusco 1.5 front diff?
Looking to do this and wanted feedback
BUILTSTI is offline   Reply With Quote
Old 02-07-2011, 10:57 PM   #99
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Bump for me to read through deeper tomorrow... When my eyes are working fully...
Seraphinwolf is offline   Reply With Quote
Old 02-14-2011, 12:26 PM   #100
Tiller35
Member#: 217006
I'm a huge noob to this... But what are the limits of the STi differential? Meaning can it only go to 70/30 or what?
Tiller35 is offline   Reply With Quote
Transmission FAQ: Read if you are thinking of upgrading! Unabomber Transmission (AT/MT) & Driveline 215 07-30-2015 02:13 PM
Injector, Fuel Pump, and Fuel Rail FAQ: Read if you are thinking of upgrading! Unabomber Newbies & FAQs 158 07-13-2015 03:19 PM
Turbo FAQ: Read if you are thinking of upgrading! Unabomber Newbies & FAQs 205 05-06-2015 02:22 AM
Suspension & Driveline FAQ: Read if you are thinking about upgrading! Unabomber Brakes, Steering & Suspension 82 05-06-2013 08:47 PM
Turbo FAQ: Read if you are thinking of upgrading! Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 70 06-19-2006 04:37 PM
