Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 09-24-2011, 05:18 AM   #101
T.McRally
Member#: 148201
Can anyone tell me which diff gets hotter a helical or a plated ?
Thanks
It's Ok, I'm sorted.
The plated diff creates more heat.
T.McRally is offline   Reply With Quote
Old 10-05-2011, 11:15 AM   #102
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Originally Posted by sponaugle View Post
Here are the part numbers for each of the diffs (front, rear, and center)
Rear Diff
38410AA080 - 2004 Rear Diff Unit
38410AA080 - 2005 Rear Diff Unit
38410AA120 - 2006 Rear Diff Unit
38410AA140 - 2007 Rear Diff Unit
NOTES: 04 and 05 are the same. I have taken an 04 Diff apart, and rest assured it is clutch pack based. 2006 had a new rear diff, as did 2007.
Front Diff
38410AA060 - 2004 Front Diff Unit
38410AA100 - 2005, 2006, 2007 Front Diff Unit
NOTES: Sure enough, the 04 US 6MT had a Suretrac front diff, as the 060 part number is also used in the Version 8 JDM 6 Speed ( C, D ). 05, 06, and 07 all have the same front diff.
Center Diff (DCCD)
38913AA160 - 2004, 2005 Center Diff Unit
38913AA190 - 2006, 2006 Center Diff Unit
NOTES: 04 and 05 has the same center DCCD unit, which was upgraded in 06. The center diff used in all cases (160 and 190) are the same as used in the JDM 6 speed of the same years. AA160 was used in C,D, and E JDM 6 speeds, and AA190 was used in F and G.
Does anyone know if it would be possible to use the Front LSD out of a 2011 STi in a 04 STi?
tia
Bishop is offline   Reply With Quote
Old 02-02-2012, 01:07 PM   #103
seanwstrum
Member#: 306832
Default 96 sti ver 3 gf8 trans swap
What would it take to put a newer 6spd in mw 96 gf8
seanwstrum is offline   Reply With Quote
Old 02-02-2012, 07:29 PM   #104
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You posting in the right thread.
You reading the sticky threads.
You not being so damn vague.
Old 02-04-2012, 09:02 PM   #105
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Pretty much the same as putting it into a GD.
aboothman is offline   Reply With Quote
Old 03-10-2012, 11:44 AM   #106
delhiforester
Member#: 223204
I would really appreciate some recommendations for a rear LSD upgrade.
My vehicle is an '04 Forester body with '04 Sti drivetrain (from a USDM, California donor), set up for stage rally. It is really a purpose built rally car that sees mostly dirt/gravel/sand for competition. You can see a picture here http://www.xplorearth.com/ . All differentials, front/center/rear are '04 USDM Sti stock. Running a DCCDPro controller for the center diff.
What makes it fun is that I can still drive it on the street since the road regulations in India are not very strict, so I get away with driving a rally car on the street .
I have had problems with my rear stock differential, and have seen lots of metallic particles and chunks coming out with the oil. So my conclusion is that the rear LSD is not working much and needs repair or replacement.
Looking for advice on what to do next:
1. Repair the LSD - parts are expensive and takes specialized skill to do correctly. Not sure that I can do it correctly, or have the time to do it over and over till I get it right.
2. Purchase an aftermarket LSD that will give better performance than the stock LSD, and is plug and play. Advantage is that I could buy a unit that is better suited to dirt/gravel/sand.
3. Recommendations on future upgrades for the front & center diffs based on my type of usage.
So please let me know your opinions. Thanks!
delhiforester is offline   Reply With Quote
Old 01-02-2014, 01:20 PM   #107
LouisFCO
Member#: 345643
This might be a newbie question, though my comprehension is a bit better than that.
- On a bone-stock, daily driver 2002 wrx, what would be the advantages/disadvantages to swapping in an ATB rear differential over the stock unit?
AND
- Would one need to upgrade the center differential as well?
I am trying to understand how the various upgrades affect the handling/driving in Subaru's AWD setup. I am familiar with Quaife's ATB in FWD Volkswagens, but it seems like the changes in handling are more extreme? In my Corrado, I can just expect more understeer.
LouisFCO is offline   Reply With Quote
Old 01-02-2014, 08:07 PM   #108
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Your OEM rear will last forever, an aftermarket will not and make zero difference on a daily driver.
If you upgraded the center from DCCD, you'd be buying a unit that costs more than your whole car.
Old 01-03-2014, 09:07 PM   #109
djdawson2
Member#: 377705
Default Brand new
I'm old (49) - bought my first Subaru 4 days ago. It's an '05 Sti with 27k miles on it. My life has been Audis and Porsches, so I'm new to these cars completely - but I've been doing heavy work and mods for decades.
So - my test ride was a complete joy. Probably 10 miles of driving around, but probably never broke 60mph. I buy the car. I never put a ton of time into pre-purchase because I'm used to doing or rebuilding everything on my own, and have a very well equipped shop.
My mistake - I drive the car the 40+ miles to my home. The first time I come to a complete stop when nearing my house, a start out in 1st while making a slight turn, and it sounds like the drivetrain is about to come entirely out of the car... I mean BAD clunking/clanking and binding. The binding reminds me of a failed viscous coupler in a Jeep, but the banging/clanking I've never heard before.
I let the car sit overnight... the next day, nothing. This makes it even more compelling that it is the center diff... only acting up once it gets hot.
I drive it around today to 3 local (Denver) Subaru tuner shops, and they all seem to agree.
So, here I am at this thread. I don't want to mod - I just want to replace the center diff with OE. I've done them on other cars, and they are typically not difficult at all.
For the new guy - where can I get the OE center diff for a decent price? Secondly, any links to a replacement procedure would be great.
Thanks,
Dave
djdawson2 is offline   Reply With Quote
Old 01-04-2014, 12:43 AM   #111
djdawson2
Member#: 377705
Asshats? Is that a recommendation?
I'll give them a call. I think I may end up doing this myself. The seller has agreed to cover the cost it seems, but I may rather learn it than have someone do it for me.
I'll give them a call - see if they might have the diff.
Thanks,
Dave
Old 01-04-2014, 09:38 AM   #112
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Asshats is my term of endearment for them. If they can't help you, you have REALLY done something "great" in the driveline world.
Old 01-23-2014, 06:54 PM   #113
Crazyced
Member#: 378119
2004 Impreza WRX
World Rally Blue
I have a 04' WRX and love it, but in the snow, the back end tend to swing around during acceleration (straight line). I was thinking of the possibilities of having a mechanical LSD in the rear to correct this.
But now I wonder, wouldn't the benefits be very negligible as long as I have the weak stock viscous center diff? I mean the newfound available traction in the rear would be bypassed to the front as soon as some slippage appear wouldn't it?
Crazyced is offline   Reply With Quote
Old 01-23-2014, 07:30 PM   #114
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
LSDs are expensive. Unless you are snow racing, spending several hundred to a thousand to correct an annoyance on a daily driver is rather silly. Is it worth it?
Old 01-23-2014, 11:03 PM   #115
Crazyced
Member#: 378119
2004 Impreza WRX
World Rally Blue
It would be relative to the person and how cheap they could get one for.
But thinking about the possibilities is free though, hence the question.
Old 02-14-2014, 06:10 PM   #116
derkahn
Member#: 123160
05 obxt
gtx3071r e-85 wagon
good read for those who are fully down the differential rabbit hole..old (er) than most info out there but interesting.http://www.oldrallysport.on.ca/articles/diffs.html
derkahn is offline   Reply With Quote
Old 02-17-2014, 10:35 PM   #117
TravelinMan
Member#: 373867
Thanks,
Dave
This should help:
http://www.subaruforester.org/vbulle...ce-them-46979/
TravelinMan is offline   Reply With Quote
Old 08-18-2014, 12:58 AM   #118
skunkman
Member#: 118141
95 'lifted' legacy
sub'd for reference!
skunkman is offline   Reply With Quote
Old 09-12-2014, 10:17 AM   #119
calebw15
Member#: 358808
2003 Hybrid WRX
Bump from the dead -- I have a JDM 6 speed and my r160 attached to it just locked up last night so I'm trying to find a r180 to replace it but I cannot find the rear diff gearing for the life of me. Is it 3.54 or 3.9? My transmission code is Ty856wb7ka
calebw15 is offline   Reply With Quote
Old 11-14-2014, 03:09 PM   #120
Arkadion
Member#: 358368
2005 Impreza 2.5RS
Crystal Grey Metallic
If I'm swapping a WRX rear VLSD center coupling into an RS R160, should I be able to get away with doing minimal adjustments since I'm not messing with the pinion gear, as long as the center coupling sits snugly on its bearings?
Arkadion is offline   Reply With Quote
Old 08-12-2015, 09:46 PM   #121
Riddykitty
Member#: 427961
Default Trying to figure out what i have
Trying to figure out what I have for rear diff. 02 WRX 5sp 2.0L turbo Not sure if this is a V lsd and a 3.9 ratio or what.... any advice?
Riddykitty is offline   Reply With Quote
Old 08-13-2015, 12:27 PM   #122
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Open the case and look.
mrsaturn7085 is offline   Reply With Quote
Old 08-17-2015, 03:35 PM   #123
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
The 02-07 wrx rear diff has a 3.54 ratio V-LSD. Also, like mrsaturn7085 suggested, if you need absolute answers you can open it up. Tip it up onto the input flange, take off the diff cover, the ring gear will have the ring tooth count and pinion tooth count etched into the outer surface. Divide ring number by pinion number and you will get your ratio.
Examples:
39/11 = 3.54 ratio
37/9 = 4.11 ratio
Dominator is offline   Reply With Quote
Old 09-06-2015, 10:58 AM   #124
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Stupid question time:
Ring and pinion sets... How interchangeable are they between generations and different transmissions? And same for R160 and R180 rear diff sets?
Seraphinwolf is offline   Reply With Quote
Old 09-06-2015, 12:19 PM   #125
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
A ring and pinion, to my knowledge, are same/same throughout the years so if you have a 5MT RP set from 1865 you can throw it into a 2015 5MT.
Not sure what your question is with regard to rear diffs:
Are they the same throughout the years? Technically yes. Same relative size and shape so you can take a R160 from 1942 and bolt that bitch up to your 2004 WRX. Now the kicker is.....does the older R160 ratio (as shown in post #123 above) match your car? If yes, bolt and go. If no, it will bolt up and then explode due to wrong ratios.
Injector, Fuel Pump, and Fuel Rail FAQ: Read if you are thinking of upgrading! Unabomber Newbies & FAQs 175 08-23-2016 11:35 PM
Transmission FAQ: Read if you are thinking of upgrading! Unabomber Transmission (AT/MT) & Driveline 219 07-03-2016 06:59 PM
Turbo FAQ: Read if you are thinking of upgrading! Unabomber Newbies & FAQs 213 06-14-2016 10:24 PM
Suspension & Driveline FAQ: Read if you are thinking about upgrading! Unabomber Brakes, Steering & Suspension 82 05-06-2013 08:47 PM
Turbo FAQ: Read if you are thinking of upgrading! Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 70 06-19-2006 04:37 PM
