Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 11-10-2001, 08:05 PM   #1
FormerSubTech
Member#: 11913
2000 Forester
Default torn between Potenza 950 and Dueler H/L for Forester
I'm getting ready to replace the 205/70-15 tires on my 2000 Forester. the Dueler H/L's seem like a logical upgrade over the Dueler H/T's that it came with. the potenza RE950 alos looks like a god choice, especially since it can be had in the slightly lower 65 series profile.
we do go camping several times a year where we need to drive on gravel rods and off road a bit and perhaps once or twice a year to the snow. other than that, the car sees all highway.
I know with the 65 series, I'd loose a little tire circumpherence but it seems minimal.
would appreciate any advice.
oh, and I plan to install the FHI 18mm rear sway bar if that matters.
thanks!
FormerSubTech is offline   Reply With Quote
Old 11-11-2001, 08:48 AM   #2
Crashton
Member#: 3808
2005 Forester XT!!!
Crystal Gray Metallic
Got to http://tirerack.com They have all kinds of info. If you go with a 215/65/15 you will have a wider tire with better handling than you'd have with 205/70/15 tires. At Tire Rack take a look at the specs of the tires you're interested in. Some of the 215/65/15 are just about the same overall diameter as the 205/70/15 H/T's.
Chuck
Crashton is offline   Reply With Quote
Old 11-15-2001, 05:30 PM   #3
juice
Member#: 1424
1998 Forester
Acadia Green Metallic
I'd also go with 215/65R15s. The extra width helps in sand because they float better. That compensates for the tiny loss in ground clearance. 215/70R15 will also fit.
I was in the same boat last year, and ended up getting an aftermarket Plus One set of alloys and 225/60R16 tires, which I love. Mine were $643 delivered, but I got a special on wheels from http://www.discounttiredirect.com/.
They were just $75 per rim, and I sold my steel ones for $100 for the set, so my net cost was just $200 for the upgrade. Totally worth it.
-juice
juice is offline   Reply With Quote
Old 11-16-2001, 07:01 PM   #4
Ken S
Member#: 1895
05 Leg GT Ltd. W
Default O/T
FomerSubTech:
Off topic, but can you fill us in about being a former Subaru technician? I noticed your interesting username and saw the brief description in your profile. Which dealer did you work at? Any interesting behind-the-scenes stories about our vehicles?
Ken
Ken S is offline   Reply With Quote
Old 11-16-2001, 07:34 PM   #5
FormerSubTech
Member#: 11913
2000 Forester
Talking
I worked at Diablo in Walnut Creek between 1985 and 1992. I did a lot of transmission (manual & auto), electrical, fuel injection and engine work. I avoided regular maintenance work like brakes & services etc. too boring.
I'm a computer weenie now working in silicon valley at a (still profitable) high tech firm.
I even know what an FF1 is and what a 360 is. :P
Torn between DIY and an Expert mhoward1 Off-Topic 13 03-11-2010 11:49 AM
I can't decide between a WRX and STi (or STI for that matter) WhiteOnRice Newbies & FAQs 54 01-31-2008 12:26 AM
Torn between Crucial Racing shorty DP and Cobb high-flow DP sandwi54 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-07-2006 07:39 PM
torn between cusco and white line TerenceT Brakes, Steering & Suspension 6 04-11-2002 07:30 PM
torn between Potenza 950 and Dueler H/L for Forester FormerSubTech Brakes, Steering & Suspension 1 11-10-2001 09:06 PM
