Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 10-31-2006, 08:04 PM   #1
knertified
Member#: 33244
Default plugging EGT bung on Header?
I need to take the gauges out of my car and either swap a header with someone or plug the EGT hole I tapped on the header. Could I just simply put a bolt in it? The header gets close to 1500 degrees so I dont want a bolt melting or breaking off and going right through the turbo. Is there any other alternatives or is the bolt okay?
knertified is offline   Reply With Quote
Old 10-31-2006, 08:06 PM   #2
WRX Shenanigans
Member#: 101378
I have a bolt plugging my uppipe for that last 10k miles or so and no sign of breakage, IMO it'll be just fine.
WRX Shenanigans is offline   Reply With Quote
Old 10-31-2006, 08:06 PM   #3
dibblejr
Member#: 94070
05 LGT
Stainless steel bolt will be just fine. Thats what I have in mine.
dibblejr is offline   Reply With Quote
Old 10-31-2006, 08:32 PM   #4
knertified
Member#: 33244
Thanks guys!
Old 10-31-2006, 10:27 PM   #5
TMessick
Member#: 882
2004 WRX Wagon
very blue
Check your thread size first! Not sure what you have, but several EGT probes were using 1/8" NPT thread. You can get cheap brass pipe plugs at your local home supply for a couple of bucks and it should work, but I'd personally reccomend stainless as others have mentioned. If it's a normal bolt thread, find a good ACE hardware and grab a stainless bolt or socket cap screw. Not 100% sure where the best place to get stainless pipe plugs would be but summit has them for too much money:
http://store.summitracing.com/partde...5&autoview=sku
And this place seems to sell them on the cheap:
http://www.vancouverbolt.com/PIPE.HTML
http://www.fittingsupply.com/sqhepipl3sts.html
TMessick is offline   Reply With Quote
Old 11-01-2006, 06:07 PM   #6
Barge
Member#: 62941
2004 WRX
Rally Blue
McMaster has pipe plugs on the cheap.
Barge is offline   Reply With Quote
Old 11-07-2006, 08:25 PM   #7
knertified
Member#: 33244
Thanks, I didnt even know pipe plugs existed
Old 11-09-2006, 10:23 PM   #8
mikeyg
Member#: 86497
04 STI
I'm having this issue as well, I have a defi egt bung that I need to plug, i'm currently leaving the sensor in there to prevent a leak. Is there anyone that definitively knows what will work to plug this. I have no idea what the thread is and need a solution fast. Any help will be great.
mikeyg is offline   Reply With Quote
Old 11-10-2006, 09:27 AM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Most EGT bungs are 1/8-27 npt. Go to Lowes or mcmaster.com and get a 1/8 male-female and a 1/8 plug. They are called brass pipe fittings on mcmaster.com.
Old 11-10-2006, 09:50 AM   #10
mikeyg
Member#: 86497
04 STI
Thanks man!
EGT bung on aftermarket headers? mannyOlicious Newbies & FAQs 3 10-09-2008 08:40 AM
installing egt bung on coated headers? orionh2215 Newbies & FAQs 6 09-26-2007 04:28 AM
where to put the EGT bung on the header? Drink Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-08-2006 05:28 AM
EGT Bung for Header WillysPU Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-26-2005 03:44 PM
FS: Borla Header w/EGT Bung on Cyl. 4 Jard Mid Atlantic Impreza Club -- MAIC 4 02-28-2005 12:34 AM
