Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Commercial ECU Reflashes
Old 10-28-2006, 07:51 AM   #1
xolosis
Member#: 103373
Default Low RPM Low Load Issue
Guys I've got a strange problem that start a couple of days ago. So it could be mechanical.
Taken -12% from the MAF table due to running a Fuel Pressure Reg to get as close to the AFR Maps as possible. Also the car has run minus MAF setup for 2 months with no known issues.
The car has developed a stutter/surging condition at below 2000rpm and idle is rough. Looking at the logs the diagnoses looks as...
1. Idle is rough and evident from log 1 AF Correction adding fuel, then suddenly settles down to normal - see log 1.
2. Cruising below 2000rpm the car will stutter/surge sometimes violently. Again AF Correction is adding then substracting fuel frequently - see log 2
*** How do you post at NASIOC? Logs are too long to wrap around code! ***
What mechanical problems should I be looking at? Spark Plugs etc?
Now above 2000rpm the car hauls and runs normal with no CEL's etc.
Strange?
xolosis is offline   Reply With Quote
Old 11-01-2006, 12:52 PM   #2
MRF582
Member#: 48219
. Always drive
the race line .
you're tuning in a weird way. Increase the injector scalar instead of removing 12% from the MAF table. The car thinks you're in a lower load zone then you really are causing you to run higher timing than you should. That's the first of your problems.
I know that wasn't much help to your current problem but check for intake leaks.
MRF582 is offline   Reply With Quote
Knock at low RPMs and load fenix-silver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-17-2010 12:51 PM
Low RPM/low boost knocking? Fred Fredburger UTEC 8 11-22-2007 10:59 AM
Flash CELs at low rpm & load? Si2WRX Engine Management & Tuning 8 04-04-2004 06:29 PM
Flashing CEL at mid-low RPMS / low Throttle - then gone johnnytran Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-06-2003 03:45 AM
Detonation during low RPM/High load crash Normally Aspirated with bolt-on Forced Induction Powertrain 4 03-11-2002 11:33 PM
