Alaskan Impreza Club
Old 11-01-2006, 01:21 PM   #1
907racer
Member#: 120560
Default How much would a water pump set me back?
My water pump in my rs is leaking out so i was wanting to know how much it would cost to get a new one. any info will help. thanks
-Jon-
907racer is offline   Reply With Quote
Old 11-01-2006, 01:34 PM   #2
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
Its about $123 for the pump... installed would be looking at about $415 parts and labour. Thats through Continental Subaru service.
If you want to set an appointment PM me or call me 261-0602
Mavrik is offline   Reply With Quote
Old 11-01-2006, 01:47 PM   #3
Konvict
Member#: 45615
2005 Ford Mustang
Redfire
I'd buy the pump and install it yourself, or recruit someone. Water pumps aren't that hard to install.
Mike
Konvict is offline   Reply With Quote
Old 11-01-2006, 03:47 PM   #4
edo2000
Member#: 68709
2012 WRX
red
Mike
I bought a rebuilt pump for a wrx recently from Schuck's. It looked and worked fine. $71, with $9 back when you turn in your worn out pump. I thought it was a fairly involved install, the crank pulley and timing belt need to come off... If it is anywhere near time for a timing belt on your car, you should do that at the same time.
edo2000 is offline   Reply With Quote
Old 11-01-2006, 03:48 PM   #5
Mavrik
Member#: 90347
Yamaha FZ8
change your timing belt and reseal the oil pump while your in there.
Old 11-01-2006, 03:58 PM   #6
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
Definitely do all at same time.
Racer Dubya is offline   Reply With Quote
Old 11-01-2006, 04:41 PM   #7
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
Mike
hahahaaa!
SQUAD_907 is offline   Reply With Quote
Old 11-01-2006, 05:00 PM   #8
Konvict
Member#: 45615
2005 Ford Mustang
Redfire
OR RECRUIT SOMEONE!!!! Anchorage crew loves install parties. I'd recommend buying a go-fast mod to install to attract more helpers.
Old 11-01-2006, 06:58 PM   #9
907racer
Member#: 120560
yeah the thing is i dont have much money and i live in seward...
Old 11-01-2006, 07:55 PM   #10
JordyB
Member#: 20328
'05 Forester XT
'07 Legacy spec.B
and the water pump is going out on that thing? how many miles you got on the clock?
JordyB is offline   Reply With Quote
Old 11-01-2006, 08:23 PM   #11
907racer
Member#: 120560
40100 miles
Old 11-01-2006, 09:00 PM   #12
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
Originally Posted by SQUAD_907 View Post
hahahaaa!
Yeah... it is not like the waterpump is run by the timing belt or anything... oh, wait it is
I've done a few of these and if you haven't done this on a subaru you will definitely want assistance from someone with experience.
Good luck
Old 11-01-2006, 09:03 PM   #13
GrinderAK
Member#: 87551
97 OBS, 01 RS
2014 SWP FXT
sure it's not the head gasket? makes more sense at 40k....
btw coolant from the weep hole is normal!!
GrinderAK is offline   Reply With Quote
Old 11-01-2006, 09:32 PM   #14
Mavrik
Member#: 90347
Yamaha FZ8
he's out of powertrain and no headgasket campaign to his vehicle.
Old 11-01-2006, 10:34 PM   #15
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
Good luck
this is true. mis-timing the motor can cost costly damage...
00Maddog is offline   Reply With Quote
Old 11-02-2006, 01:11 AM   #16
907racer
Member#: 120560
its more than just a trickle it leaves puddles
how much would meth injection help me? rufracer Water/Methanol Injection, Nitrous & Intercooler Cooling 13 06-16-2007 06:29 PM
How much would you spend for downpipe back custom exhaust? xcdhridr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-16-2005 01:19 AM
how much would new turbo set up cost, what does it entail (specificly what components rbmour Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-26-2005 01:29 PM
how much would a 100 pound sub box slow me down? dijay Car Audio, Video & Security 10 05-09-2002 10:21 PM
How much would it cost for me to have my brake fluid drained and replaced? edkwon Brakes, Steering & Suspension 5 04-11-2002 08:08 PM
