Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 11-11-2001, 12:11 AM   #1
blackbok
Member#: 12176
2002 Geo Metro
Teal
Question I'm new (and I have questions...)
Hey everyone.I'm new to this forum (as well as to Subaru). I've had my 2002 RS 5 speed for 3 weeks now, and it's great. I do have some concerns though.
When I'm driving in a straight line ( more so at higher speeds) my steering seems to be a little "loose". That is, it feels like my front tires are a bit squirly. Not drastically bad, just enough to be irritating. I'm taking it in to get looked at, but I'm just curious if anyone knows anything about it. Allignment, balance? I'm new to anything near a performance car, so forgive me if I sound naive.
What about support bars? Do they improve in line stability, or are they purley for cornering?
Another thing that has been bugging me is the engine noises after I turn the car off. It makes "popping" and cracking noises for about 5 mins. I haven't broken the 1000 mile mark, so is that just the new engine breaking in?
Thanks to everyone in advance. I'm glad I found a place where I can talk w/ people about this car!
blackbok is offline   Reply With Quote
Old 11-11-2001, 09:36 AM   #2
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
The popping/crackling is your exhaust system cooling and shrinking again. When you run the car, the exhaust gets hot (duh!) and expands. When it cools, it shrinks and clicks.
Geek Guy is offline   Reply With Quote
Old 11-14-2001, 12:51 PM   #3
jds
Member#: 7991
Default Re: I'm new (and I have questions...)
Welcome! You picked a pretty good place to ask questions. THere's a lot less flaming here than other places
My first guess is alignment. Sometimes cars are delivered from the port with the alignment off a bit. Having a good alignment done can make a HUGE effect on how the car feels. Also, check your tire pressures. Low pressures can make the car feel a little "soft" or "bouncy".
I'm not quite sure what you mean by "support bars". Sway bars (also called "antisway bars". Go Figure.) will reduce body roll when cornering. That can reduce understeer / increase oversteer. I'd recommend you get to know the car and how it handles better before making suspension modifications.
It's just various engine bits cooling and shrinking. The popping and ticking is normal. Don't worry about it. It will probably persist WELL past your break in (like for the life of the car).
Yer Welcome.
-Joe
jds is offline   Reply With Quote
Old 11-14-2001, 03:21 PM   #4
Julian
Member#: 1182
MY00 RS
BRP
I second checking the tire pressures. My RS came off the truck with 50psi in each tire...that could cause some handling perculiarities. Also, the stock tires aren't that great, but between alignment and tire pressures, you should be able to solve the problem.
Julian is offline   Reply With Quote
Old 11-14-2001, 04:43 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
As part of the Pre-Delivery Inspection (PDI), the dealer's technicians are SUPPOSED to inspect tire pressure and alignment. To me, "inspecting" the alignment is the same as "performing" an alignment, but who knows what it means to the technician. And, sometimes, steps are skipped.
I have a '95 Legacy L wagon (90k miles) as well as the '02 WRX, and they both insist on making loud ticking and cracking noises from the exhaust system long after they've been turned off.
Jon [in CT] is offline   Reply With Quote
Old 11-15-2001, 09:45 PM   #6
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
Unfortunately Pre Delivery Inspections seem to usually be pencil whipped or checked off while on a quick jaunt to have the car cleaned up. I'd check the tire pressures first. Sometimes dealers/manufacturers under inflate them to make the ride seem softer. If the tire pressures are correct I'd have the alignment checked out. I would think that this would be done for free under warrantee. Just my opinion.
You bought a great car!!! Enjoy it!!!
Keith99RS is offline   Reply With Quote
Old 11-18-2001, 01:51 PM   #7
blackbok
Member#: 12176
2002 Geo Metro
Teal
Thanks to everyone. I adjusted the tire pressure and it rides ALOT better.
Thanks again!
So i'm a dissapoined with my STi Wagon spec springs and I have Questions... SubbieAndCoop Brakes, Steering & Suspension 8 04-28-2007 01:34 AM
Hi, I'm psychoskip and I have 1 testicle. psychoskip Off-Topic 46 03-19-2007 08:49 PM
I'm 20 and I have high blood pressure. eurojax Off-Topic 13 07-06-2004 03:13 PM
yep, I'm new, and have a slew of questions Romy Newbies & FAQs 6 06-16-2004 08:29 AM
Hi!!! I'm new, and have some questions! Kickz107 Newbies & FAQs 4 10-08-2002 03:27 AM
