Old 11-11-2001, 12:12 AM   #1
mick dundee
Member#: 8200
98' 2.5RS
Question Under drive pulleys
I am looking into buying a unorthodox racing UD pulley. However, I am bit concerned about this being safe for the motor. I read on the ENDYNE website a while back that when you replace a regular crank pulley with an under drive pulley, you are essentially omitting the vibration dampening for the motor. Therefore in the long term the engine will literally shake itself to pieces. Is this the case with the EJ25 or not? I did a search and someone said that the EJ25's crank pulley isnt a vibration dampening device. Im in the dark here..................
mick dundee is offline   Reply With Quote
Old 11-11-2001, 12:57 AM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
The general consensus is the Subaru boxer engine (flat four) does not need a harmonic dampner and replacement pulleys are safe.
However, the under drive pulleys mean the alternator and the AC will not have enough juice. Since 85% of the gains from a pulley are due to less weight, and for each 1lb lost off the crank the car will accelerate like it has 2.7hp more, the lightweight normal sized pulleys are the way to go. They also mean the belts fit right.
Take a look at www.ImprezaRS.com/product2.htm#pulley for a set that replaces three pulleys and losed approx 5lbs. There is a single pulley available for less on the www.ImprezaRS.com/shoppingcart.htm page.
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 11-11-2001, 01:00 AM   #3
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Re: Under drive pulleys
Maybe I can shed some light then. Bottom line is that there have been many people (including me) that has had their pulley on their cars for a long time and none of our engines shook itself to pieces.
So, are you going to get a pulley?
Kevin Thomas is offline   Reply With Quote
Old 11-11-2001, 01:06 AM   #4
mick dundee
Member#: 8200
98' 2.5RS
thanks for the info, Im gonna order one
Under drive pulley MaddogWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 88 12-24-2010 04:06 PM
Local Sale: Under Drive Pulleys for WRX & RS RALLYT-WRX Mid Atlantic Impreza Club -- MAIC 0 04-17-2003 11:24 AM
Unnorthodox Under-drive Pulleys hobun2 Normally Aspirated Powertrain 4 04-02-2002 05:17 PM
under drive pulley AngryChert Normally Aspirated Powertrain 1 07-27-2001 09:57 PM
Under drive pulley gains ITR&RSGUY Normally Aspirated Powertrain 16 07-23-2001 10:40 AM
