Old 11-11-2001, 01:37 AM   #1
Niloc
Member#: 3296
99 impreza RS
Default W/W an O2 sensor to read slow & inaccurate?
Does anyone have a clue what would cause an O2 sensor to read slow & inaccurate? My car is obviously running rich ( black smoke) but my O2 reads lean & is slow to react. I have an A/F gauge & it use to give the pritty light show that they do, bounce back & forth; pegging on rich at wide open throttle & leaning out on deceleration. Now it hancs out in the lean all the time, unless I'm crusing at 50 or up; then it goes up a little. Never rich? Not even at W/O throttle, it actually show's that it leans out? The CPU reads the same as the gauge. I am 100% positive that the gauge & sensor work. Any ideas???
Niloc is offline   Reply With Quote
Old 11-11-2001, 02:05 AM   #2
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Ideas
I have an idea. Your O2 sensor is bad. Buy a new one. When they are not working like they are supposed to, chances are they crapped out. Long rich and long lean readings usually mean they are bad, especially when your car is idle. If it doesn't fluctuate back and forth repeatedly, it's toast. Just purchase a new one.
It'll save you a lot of headaches.
Kevin Thomas is offline   Reply With Quote
Old 11-11-2001, 03:10 AM   #3
Niloc
Member#: 3296
99 impreza RS
all ready did that. also tried it in another RS, it works. Also tried bypassing the whirring harness, no change.
Old 11-11-2001, 11:33 AM   #4
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
If both your factory O2 sensor and the a/f sensor are reading lean, and the car is running rich, then the sensors are both bad (unlikely) or they are not reading the actual exhuast content due to a leak upstream pulling air into the exhuast and leaning the exhuast out before it gets to the sensors.
yamarocket630 is offline   Reply With Quote
Old 11-11-2001, 12:48 PM   #5
Niloc
Member#: 3296
99 impreza RS
That's a thought, Ill check it out. Any more ideas
Old 11-11-2001, 11:36 PM   #6
Niloc
Member#: 3296
99 impreza RS
bump
Old 11-12-2001, 12:04 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
well if you O2 was bad you'd have a MIL set...check your connection, sounds like your connection is bad to me, like corrosion has built up.
jeremy
Old 11-12-2001, 12:30 AM   #8
Niloc
Member#: 3296
99 impreza RS
tryed bypassing the harness, it's not the whirring.
Old 11-14-2001, 02:05 AM   #9
Niloc
Member#: 3296
99 impreza RS
Bump
Old 11-14-2001, 08:55 AM   #10
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Question
Already did what? Try a new O2 sensor? Or did you swap in a sensor from another car? You just said that your O2 sensor "works" in another car. Does another car's sensor work in yours?
Did you or will you consider swapping both O2 sensors with another car, or replacing both O2 sensors? At the very least, you should try swapping the rear O2 sensor by itself first. That might do something.
How did you bypass the wiring harness? Did you make up a new set of wires that ran directly from the O2 sensor to the ECU? Which wires and/or connectors were "bypassed"? I'm asking this because I don't think it's your wiring.
-WaC
Wayne
wac is offline   Reply With Quote
Where to install an o2 sensor blackburn_wrx_2005 Newbies & FAQs 8 03-19-2010 09:06 AM
Can an O2 sensor read only lean? reddevil Engine Management & Tuning 6 01-03-2006 08:28 AM
Replacing an o2 sensor on an '02 OB craigz Normally Aspirated Powertrain 0 07-17-2004 12:53 AM
Anyone want to sell an o2 sensor? miraclemonkeywrx North West Impreza Club Forum -- NWIC 1 10-13-2003 07:20 PM
Will an open DP hurt an o2 sensor Blue02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-29-2003 05:26 PM
