Old 11-02-2006, 09:28 PM   #1
bikefreax
Member#: 110726
2005 WRX Wagon
San Remo Red
Default Pros & cons between boost gauges
I am looking to get a boost gauge soon but was wondering the pros and cons between the mechanical and electrical. I have turned to the experts for info. I will probably be getting the Prosport gauge as the seem nice and not that all expensive. They currently have the mechanical in WRX green but will come out with the electrical next month. I will also be getting the pod from Subiegal to install it. I dont want a garish piller pod.
bikefreax is offline   Reply With Quote
Old 11-02-2006, 09:32 PM   #2
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Mechanical: Cheap and easy
Electrical: No tubing running into the cabin, spiffy features like peak recall, warning, etc.
RP31 is offline   Reply With Quote
Old 11-03-2006, 09:22 AM   #3
MyRuRex
Member#: 21349
02 WRX Wagon
What about reliablility & accuracy??
I'm curious too... would like to have the warning feature
MyRuRex is offline   Reply With Quote
Old 11-03-2006, 10:18 AM   #4
rkramer
Member#: 118209
2015 WRX Limitec
mechanical has the POSSIBILITY of being both more reliable and more accurate. an electronic gauge is nothing but a mechanical pressure sensor hooked up to electronics to generate an analog signal. You have the same parts as a mechanical gauge, but also a bunch of extra ones to convert the mechanical pressure sensing into an analog signal, and then electronic and mechanical components to display it. a pure mechanical gauge is much, much simpler.
for this reason accuracy of a mechanical gauge can also be higher. fewer parts to need calibrating. one argument is that it won't respond as quick, but keep in mind PRESSURE waves travel at the speed of sound in the tubing.
all that said, you get what you pay for. a really good high end mechanical boost gauge might be better then a bargain basement electronic. (or just as easily the other way around)
rkramer is offline   Reply With Quote
The End of the Cold War & the Disintregration of the USSR... pros & cons? Asinine Political Playground 14 10-07-2004 07:17 PM
Aftermarket clutch & LWFW - Pro & Cons STi4life Transmission (AT/MT) & Driveline 3 03-17-2004 10:17 AM
Electric Buffers - Comments pro & con BackSeatRider Interior & Exterior Modification 7 04-23-2001 10:22 PM
fiber glass body parts. pros & cons? impretzel Newbies & FAQs 6 03-09-2001 10:30 AM
Fuel pump on a N/A: pros & cons please Evil-Mastermind Normally Aspirated Powertrain 5 03-08-2001 08:50 AM
