Old 11-11-2001, 12:34 PM   #1
mWRX
Member#: 8854
2007 B9 Tribeca
Smoke Grey
Default Intercooler mister - rear washer switch
I noticed my sedan has the wiring connector to run 1 more water pump and a spot to put it on the resevior and would like to use it if possible, so...
1 - I want to see if I can use the rear windsheild washer wiring harness to run the pump for a intercooler water mister.
2 - Where is the rear window washer switch go in the WRX wagon? (whick dash switch knockout does it use?)
3 - If the wiring is there, can it just be hooked up and work or are there missing relays/fuses that have to be put in before this will work?
mWRX is offline   Reply With Quote
Old 11-11-2001, 12:42 PM   #2
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
I've been wondering what that was. Sorry I don't know the answers to your Q's.
Ken
DeliciouSpeed is offline   Reply With Quote
Old 11-11-2001, 02:44 PM   #3
Bobora
Member#: 8845
You can do what I did!
Go down to budget rent a car and rent a impreza wagon.
Remove and exchange water reservoir and winshield wiper stalk.
This will be a simple plug and play.
Connect everything back up and return the car.
You will end up with a very stock application and have a few extra switches for other uses.
Then you will have to look for washer nozzles only.
best of luck.
Bobora is offline   Reply With Quote
Old 11-11-2001, 03:10 PM   #4
kensington
Member#: 9113
2k4 WRB STi
RIP#92 Fred"G-Money"Zippy
Nice Too bad I already have a wagon.....
kensington is offline   Reply With Quote
Old 11-12-2001, 06:16 PM   #5
subywan-kenobi
Member#: 4268
2002 WRX Wagon
WR Blue Pearl
best of luck.
That is hilarious!
We don't use a dash switch, it is on the same handle as the front windshield washers.
Mike S.
subywan-kenobi is offline   Reply With Quote
Old 11-12-2001, 06:33 PM   #6
Philip
Member#: 1934
2002 WRX Sedan
Since I have done this (to a degree), I can say it should be possible.
What I have done....
Purchased a rear washer pump (I have a sedan). Popped a hole in the tank for the second pump. (I actually moved the windshield pump to the higher spot so my intercooler would have more water to work from). Hook up second pump wire connector (it is there even if you have the sedan). Put tank back in car.
Find the wire to tie into in the steering column, hook up a switch that grounds that wire....... there you have it.
One main item, do not try to just switch accross the two wires in the steering column, for some reason it does not work. Grounding the one main pump wire does thou.
I used this for around 3 months, till I forgot to tell service department not to fill up the tank. They topped it off with cleaner, so I pulled the pump wire connector so I don't accidently spray windshield cleaner all over my intercooler.
Eventually I will hook up the autospeed auto mister system.
Philip
Philip is offline   Reply With Quote
Old 11-12-2001, 07:05 PM   #7
mWRX
Member#: 8854
2007 B9 Tribeca
Smoke Grey
Default Thanks!
subywan, Phillip-
Thanks, That's all I needed to know!
Bobora - Too late, I already BOUGHT the parts!
What was I thinking!
Old 01-09-2003, 04:27 PM   #8
dust12
Member#: 13417
How did the parts cost? Do you have part numbers? I would like to do this as well, but with some kind've relay that would turn itself off like the window defroster.
dust12 is offline   Reply With Quote
Old 01-09-2003, 06:47 PM   #9
2.FIVEL
Member#: 23317
red, er blue, no black!!
Water sprayer? I made a nitrous intercooler chiller for like 5 bucks! Oh, I had a couple key parts already .
2.FIVEL is offline   Reply With Quote
Old 01-09-2003, 06:51 PM   #10
dust12
Member#: 13417
Do you have a picture of your install? Do you know if it lowered your 1/4 mile times?
Old 01-09-2003, 06:54 PM   #11
2.FIVEL
Member#: 23317
If someone wants to host my pics, I'll post a whole thread. Dont wanna hi-jack this one.
WTB: Headlamp washer switch for GC MyRad25rs Private 'Wanted' Classifieds 9 05-09-2008 08:18 PM
WTB: Headlight washer switch for GC MyRad25rs TXIC Private Classifieds 2 05-09-2008 12:31 AM
Intercooler Mister wiring question LIRex Electrical & Lighting 1 07-09-2005 02:39 AM
STi I/C switch with wagon rear washer plug? for sedan? Killian Maynard Electrical & Lighting 6 04-04-2005 03:20 PM
Where can I order the IC spray switch and a rear fog switch? Schleppy Interior & Exterior Modification 2 04-04-2002 07:31 PM
