Old 11-02-2006, 07:54 PM   #1
cruzinWRX2
Member#: 83922
05 STi
black
Default Having Issues With Spark Plugs
Anyone here having problems? I've got a front mount ic, an oversize perrin inlet ,walbro fuel pump apexi boost controller and aem intake. now im wondering if i should run a colder then stock plug? At my job we list 2 different gap settings now but it doesnt specify why. .044 and .030 these are NGK plugs of course. I put the .044 in and is missing and losing power at times it seems. anyone got anything on this? thanks .....mikey.....
cruzinWRX2 is offline   Reply With Quote
Old 11-02-2006, 08:08 PM   #2
ktmrider
Member#: 125687
2005 Legacy GT - 6MT
First guess is the 0.044" gap is non-turbo ( pretty std for NA ).
Colder plugs are suggested when boost levels are increased over stock ( general rule of thumb is +5psi = 1 colder ). It helps with detonation reduction. Smaller gaps are also good to keep the flame kernel from "blowing" out under extreme cylinder pressures.
Regap your plugs to 0.030" and the issues will probably go away.
ktmrider is offline   Reply With Quote
Old 11-02-2006, 08:35 PM   #3
cruzinWRX2
Member#: 83922
05 STi
black
yea i warrantied some older ones out today and got the smaller gap ones, i'll give that a shot. but i am running a lil higher boost A=14-15 B=17-18 im usually in A unless its colder out.
Old 11-02-2006, 09:53 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Looks like you are having issues with posting in the right forum.
Looks like you are having issues with reading the sticky in the right forum.
Anybody wish to help me with spark plug removal & install? Xymox Mid Atlantic Impreza Club -- MAIC 10 06-22-2016 12:23 AM
Boost issue after spark plug change ajp11 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-30-2008 08:18 PM
help with spark plugs Joshua123 Service & Maintenance 3 06-09-2005 04:42 PM
Need quick help with spark plug install sneeky Service & Maintenance 4 04-17-2005 08:55 PM
NE1 have a STi spark plug in Houston? metoo Texas Impreza Club Forum -- TXIC 0 07-23-2004 01:05 PM
