Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 11-03-2006, 06:19 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default HELIX V3 uppipe(EWG) Ready to ship ($199!!), VF34 Combos, other good stuff!
Hey guys,
We're pleased to finally release our Helix V3 Uppipes:
The Helix V3 uppipe was created for the 400+ horsepower EJ25. The V3 uppipe is designed to achieve real horsepower gains and improved torque curves by allowing the use of an external wastegate (EWG). An EWG eliminates the power-loss associated with internal wastegate turbos by moving the exhaust vent turbulence away from just before the nozzle area of the turbo. Not only does this result in improved power levels for high horsepower cars but also greater boost control and better torque curves. The V3 uppipe is mandrel bent from 2.3 SS304 tubing, TIG welded, and employs CNC machined flanges. The full 2.3 tubing allows for greater exhaust gas flow and only reduces down to 2.0 after the EWG port. The uppipe flange can be ported to 2.3 provided a 2.3 gasket is used (not included). The V3 uppipe can also be used as an internal wastegate uppipe with the included block off plate.* **
*External wastegate and external wastegate setup kit is not included. Optional V-band outlet is available.
**To use EWG option, internal wastegate must be secured by either welding the flap or locking the swing-arm.
HELIX V3 UPPIPE
-BIG 2.3" pipe diameter
-EWG Ready
-Direct bolt-on fitment
$199 Shipped!! (Introductory Price - EWG setup kit will be available shortly)
HELIX V3 UPPIPE & V3 DOWNPIPE COMBO
-Includes V3 Uppipe
-Includes V3 Downpipe
-Full SS304 Construction, TIG welded, CNC mandrel bent
$359 Shipped!!!
BIG TORQUE COMBO
We have seen HUGE gains in torque with the use of the Gruppe-S 4-1 headers and the Helix V3 Uppipe on the stock turbo STI. The reason is the huge 2.3" that allows substantially increased exhaust flow. Check out the dyno graph (sorry the scanner just broke).
COMBO INCLUDES:
-Gruppe-S 4-1 Headers
-Helix V3 Uppipe
-Helix V3 Downpipe
-Helix Cat-Back Exhaust
$1099 Shipped!!!
SWITCH OUT TO GREDDY EVO II - Add $125
TANABES ALSO AVAILABLE - CALL FOR PRICING!
VF34 COMBOS ARE BACK INSTOCK!!!
-IHI VF34
-Helix 660cc Injectors
-Walbro GS342 Fuel Pump
-375 HP Capable
$1299 Shipped!!
ADD COBB ACCESS PORT $1829 Shipped!! (Only 04, 05 cars left!)
CRAZY COBB AP & FUEL SYSTEM SPECIALS!
ALL STI 2004-2006 COBB ACCESS PORT COMBOS
-Cobb Access Port (All 2004-2006 STI's)
-Helix 860cc Injectors
-Walbro Fuel Pump with setup kit
-This fuel system supports 600HP (may require fuel pump rewire)
$999 shipped!!!
ALL WRX 2002-2005 COBB ACCESS PORT COMBOS
-Cobb Access Port (All 2002-2005 WRX)
-Helix 660cc OR 820cc Injectors
-This fuel system supports 475HP to 550HP respectively
$959 shipped!!!
Gruppe-S is offline
Old 11-04-2006, 03:56 AM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Helix V3 Uppipe shown in "venting to atmosphere" configuration (does not require EWG kit)
Gruppe-S is offline
Old 11-04-2006, 04:43 AM   #3
veightkiller
Member Sales Rating: (35)
Member#: 78967
2011 335i
do you have anything for 44mm? either way pm me for international order
veightkiller is offline
Old 11-04-2006, 06:05 AM   #4
el crichon wrx
Member#: 8493
2001 Impreza GDA
PSM-01G-IHI powered
no fitment issue with Helix hi-flow catted downpipe ?
no bung for oem EGT sensor ?
el crichon wrx is offline
Old 11-04-2006, 04:14 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hi,
There will be an optional 44mm V-band version produced in the very near future. Because the V-band requires additional machining it will be more though. Please e-mail me for your international order, and I will give you our wire transfer details. Thanks!
There's no issues with the Helix catted venting to atmosphere, although the Helix Catted downpipes do not have provisions for recirculation. There's no EGT port for the stock EGT on this uppipe.
Thanks,
Gary
[email protected]
Gruppe-S is offline
Old 11-04-2006, 05:17 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Default BUMP FOR GRUPPE-S V2 HEADERS (Coated also!)
Hey guys,
I have a bunch of Gruppe-S V2 headers that would work perfect with the Helix V3 Uppipe. These headers yield substantial gains THROUGHOUT the power band on 2.5 liter cars, and will lose a bit down low on a 2.0 but gain it all back on top. Coated and Uncoated are available for immediate shipment!
Gruppe-S V2 Coated & Uncoated Headers
-Tubular SS304 Construction
-Investment cast 4-1 collector
-Gains of 18ft/lbs & 8whp as tested (larger gains are reported on higher power cars)
-NO LOW-END LOSS for 2.5 cars
UNCOATED - $399 Shipped!!
COATED - $599 Shipped!!
ADD HELIX V3 UPPIPE $149!! (with purchase only)
Please contact us if you're interested. Thanks!!
Gary
Gruppe-S
510-783-5300
510-783-4300
Gruppe-S is offline
Old 11-05-2006, 01:41 PM   #7
veightkiller
Member#: 78967
2011 335i
e-mailed you^^
Old 11-06-2006, 11:55 AM   #8
Kitt
Member Sales Rating: (6)
Member#: 24621
2006 Legacy GT
2015 WRX STi
sent you a pm
Kitt is offline
Old 11-07-2006, 07:12 AM   #9
TheMadScientist
Member Sales Rating: (3)
Member#: 23717
2005 Big red
ETA on the 44mm version?
TMS
TheMadScientist is offline
Old 11-08-2006, 03:21 PM   #10
Kitt
Member#: 24621
2006 Legacy GT
2015 WRX STi
Will the V3 uppipe (w/Tial 38mm) fit with a divorced wastegate downpipe (Bosal, Crucial etc.)?
Kitt is offline
Old 11-08-2006, 06:02 PM   #11
WrXwaBBit
Member Sales Rating: (2)
Member#: 33296
Please check your pm thanks
WrXwaBBit is offline
Old 11-08-2006, 07:17 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Sorry we don't have an ETA yet to the "44mm" version. I believe the V-band version will be released along with the Helix 38mm V-band wastegate. The Helix V3 pipe is designed primarily for use with the Helix V3 downpipe, but will be compatible with most downpipes. I'm iffy on the Turbo XS one though, that design it may not clear.
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 11-08-2006, 07:33 PM   #13
Swine
Member Sales Rating: (42)
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Are they going to make a dump tube that routes back in to the v3 downpipe are do you have to get one made your self? Will they provide a regular dump to atmosphere dump tube?
Swine is offline
Old 11-08-2006, 10:30 PM   #14
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Yeah, there will be a dump tube (recirc) released for the Tial wastegates shortly. The hold up is because Helix is releasing their own wastegate very shortly. Thanks.
Gary
Gruppe-S
Gruppe-S is offline
Old 11-09-2006, 12:09 PM   #15
wcbjr
Member Sales Rating: (1)
Member#: 4001
2006 Legacy GT
Obsidian black
Gary
Gruppe-S
And hopefully a BOV/BPV too! I would love a one-stop-shop.
wcbjr is offline
Old 11-09-2006, 12:30 PM   #16
TheMadScientist
Member#: 23717
2005 Big red
Thanks,
Gary
Gruppe-S
I have both the Tial 44 and the TXS downpipe. If you need someone to test fit it.
TMS
Old 11-10-2006, 10:24 AM   #17
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Also a question on fitment. Will this combo work on LegacyGT downpipes (less clearance)? I could test fit it for ya.
wcbjr is offline
Old 11-10-2006, 02:36 PM   #18
pankopp
Member#: 29552
2005 Forester XT
Can you run it like show venting to the atmosphere? or is it required or recomended to have a dump tube, just wondering if i should wait for the release or just make my own dump tube...
pankopp is offline
Old 11-10-2006, 10:56 PM   #19
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
wcbjr - I'm not sure if the V3 uppipe is compatible with the legacy downpipe, as the bend is tighter. I *believe* it will fit, but there might be a fitment problem with the vacuum lines up top depending on which downpipe you want to run.
Pankopp - Hi, you can run it as show, but we highly recommend a dump tube just to get those gases way out of your engine compartment.
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 11-12-2006, 11:33 AM   #20
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Discount for research? I have a JGS 40mm wastegate sitting in my garage waiting for my 240SX's turbo kit to be completed. I bet I could put it to good use.
http://www.jgstools.com/turbo/jgs40wg.html
wcbjr is offline
Old 11-13-2006, 03:29 PM   #21
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Give me a call I'm sure we can work something out
Cheers,
Gary
Gruppe-S
Gruppe-S is offline
Old 11-14-2006, 09:35 AM   #22
Kitt
Member#: 24621
2006 Legacy GT
2015 WRX STi
I ordered the V3 uppipe + Tial combo on saturday morning but still have not heard from you guys. I just want to see if the order went through.
edit: Nevermind, I gave them a call.
Kitt is offline
Old 11-16-2006, 09:26 PM   #23
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!
Gruppe-S is offline
Old 11-16-2006, 09:47 PM   #24
WeldingHank
Member Sales Rating: (22)
Member#: 98645
2002 WRX Wagon
anyone know yet if this clears a divorced down-pipe like bosal?
WeldingHank is offline
Old 11-20-2006, 08:12 PM   #25
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Closed Thread
