11-04-2006, 01:18 AM | #1 |
Member#: 52890
Quick ??? on the hydra
Hey everyone i just purchased my hydra got a sweet deal, bought phils hydra for $1200 with WB. This may seem like a dumb question, do i need to keep my factory 02 plugged in? reason im asking because stupid me forgot to unplug the harness while taking the engine out and ripped the wires from the sensor
was the uppipe 02 sensor Cheers Stu
11-04-2006, 01:52 AM | #2 |
Member#: 78957
RMIC
Vehicle:'06 Evo IX RS White on white on salt |
the up-pipe is an egt sensor in stock form if i'm not mistaken
11-04-2006, 03:00 AM | #3 |
Member#: 113734
South East
Vehicle:2023 FL5 Type R Subaruless |
I thought the wideban 02 sensor went on the down pipe? 4inches back from the turbo??
11-04-2006, 11:17 AM | #4 |
Member#: 52890
exuse me the one in the manifold ther a 2 one there and one in the downpipe
11-05-2006, 08:54 PM | #5 |
Member#: 110648
PRSIC
Vehicle:2005 Hydramist 35R82 93oct 479whp 456tq |
Either you use the stock one, or the wide band when tunning. The Hydra uses the one after the turbo in the STI's. Use the wideband for tunning and auto tune, then when done, install the stock one back. This will make your wideband last longer, especially if you use a lot of racing gasoline. In the select/settings/closed loop menu, in the left and right sensors enable 14.7 U/HEGO when using the stock sensor. With the wide band, when not in auto tune, use 14.7 Wide Band HEGO. When doing auto tune with the wide band, use the wide band target table. I do not think you can use both at the same time.
11-06-2006, 01:35 PM | #6 |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
Remove the front stock sensor. The Hydra does not use the front sensor on the Subarus, and leaving an unpowered sensor in the exhaust is a good way to kill the sensor.
11-06-2006, 09:27 PM | #7 |
Member#: 110648
PRSIC
11-07-2006, 12:14 AM | #8 |
Member#: 52890
Nice well i dont have to worry purchasing one of thoses then cheers guys
11-11-2006, 08:21 PM | #9 |
Member#: 87446
NWIC
Vehicle:2005 STI 3 second start club |
11-12-2006, 02:22 PM | #10 |
Member#: 27108
Need help quick on springs | g7run | Brakes, Steering & Suspension | 0 | 06-03-2010 02:57 PM |
Mazda city car quick on the draw | AVANTI R5 | Non-Subaru News & Rumors | 1 | 05-26-2008 08:36 AM |
Auxiliary injectors on the hydra | poormansporsche | Other Engine Management | 1 | 01-24-2007 11:09 AM |
Quick ? on the diff (STI) | gerald06sti | Newbies & FAQs | 2 | 05-26-2006 10:52 AM |
How does the antilag work on the Hydra? | Crazykev | Other Engine Management | 2 | 10-15-2005 07:11 PM |
