Old 11-04-2006, 12:22 PM   #1
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
Question Aquamist Water Injection in the Cold Winter Months
What's the proper setup for the Winter months in New England?
I dont want any freezing problems.
What are people using?
Is 50/50 water/methanol the best, even in winter, or is straight windshield washer the best, etc.?
The car will be tuned for 50/50 mix (year round). Will this be a problem?
skimobile is offline   Reply With Quote
Old 11-05-2006, 09:39 AM   #2
mindchatter
Member#: 36447
Heav en for the weat
her & Hell for company
While in CT I ran a 50/50 blend of denatured alcohol and distilled water w/o any issues w/freezing. Planning on running the same in CO.
mindchatter is offline   Reply With Quote
Old 11-05-2006, 10:14 AM   #3
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
50W/50M will see you through most winter, freezzing point of the mixture is -40C or 40F. Good for summer as well.
Check the alcohol type on the washer fluid before use it, it could contain ethanol instead of methaol. Aquamisy pump is nopt designed to run ethanol alcohol.
Do not use denatured alcohol because it contain mainly ethanol.
Aquamist is offline   Reply With Quote
Old 11-05-2006, 12:04 PM   #4
norexyet
Member#: 39149
11 elantra
yea i said elantra
so what is the freezing point of the 50w/50m mix? 40 degrees above zero faranheit?? If so, what is it for pure meth as it gets down to the 20s faranheit in my area over winter time.
norexyet is offline   Reply With Quote
Old 11-05-2006, 12:26 PM   #5
flycaster
Member#: 60142
2011 WRX
Grey
No, no. It's about -40f. You're good to go unless you live in northern Alaska.
flycaster is offline   Reply With Quote
Old 11-05-2006, 12:28 PM   #6
norexyet
Member#: 39149
11 elantra
yea i said elantra
ahh thats what i thought, 40 above would be horrible. thanks
Old 11-05-2006, 02:41 PM   #7
Aquamist
NASIOC Manufacturer
Member#: 110029
Sorry, -40F. I confirm
Old 11-05-2006, 05:38 PM   #8
skimobile
Member#: 92114
03 WRX (NAVY Camo)
Thanks Guys!
50w/50m It Is!!!!
Old 11-06-2006, 10:28 AM   #9
mindchatter
Member#: 36447
Richard - is this advice based on the usage of only your pump? I've been running 50/50 denatured/distilled for almost 20,000 miles and through 2 winters thus far......but your statement has me curious. TIA!
Old 11-07-2006, 04:18 AM   #10
Aquamist
NASIOC Manufacturer
Member#: 110029
Depending on the age of the pump, we have changed the seals and valve materials in Dec 2005, by March 2006, most pumps will be equipped with the new seal and more resistance to high concentration of ethanol - depending on the astock rotation of the vendor, some older seal may be distributed beyond March. I still prefered people not to use ethanol based mix. If you have any problem, please contact me for the new seal.
Old 11-08-2006, 07:38 AM   #11
mindchatter
Member#: 36447
Thanks for the info Richard. I'd take you up on your very generous offer but I don't run an Aquamist system....hence my asking if the problem was specific to your pump. Mine utilizes a Shur-Flo. I'll keep an eye on the pump seals though. Thx again for the response.
Old 11-08-2006, 03:45 PM   #12
Aquamist
NASIOC Manufacturer
Member#: 110029
I believe Shurflo has many seals and valves material variations, since you have been running denatured alcohol for two years without any problems, I assumed you have the correct pump materials in your system. It is always worth checking every 6 months for signs of small leaks.
boost up or down in the cold winter? gungaslow General Community 109 03-23-2010 07:58 PM
Aquamist Water Injection Parts!!!! MidEngine4Life Private 'For Sale' Classifieds 1 06-28-2004 02:17 PM
New car break-in-period during freezing cold winter months...? driver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-13-2003 08:01 AM
Aquamist water injection mick_the_ginge Water/Methanol Injection, Nitrous & Intercooler Cooling 12 01-17-2003 05:20 PM
J&S Safegaurd and Aquamist Water Injection replacement killer Water/Methanol Injection, Nitrous & Intercooler Cooling 3 05-30-2002 05:27 AM
