Alaskan Impreza Club
Old 11-04-2006, 04:59 PM   #1
akryder86
Member#: 74916
1993 Impreza L
1989 Turbo Racescort
Default EGR Solenoid testing
Hey all, I have this reacuring problem with my car. It runs pig rich and does not idle after I first fill it up and when the gas tank gets down to 1/4 tank.After I drive it about 1/2 mile it runs fine except for that it is rich. I tested my O2 censor and it's ok. I have replaced the PCV valve, fuel filter, and O2 censor within the past 2 months. Last night I vaccum tested my EGR valve and it would hold pressure at or above 15psi. Is that normal? I tested my EGR valve because I know that with a cold engine if you take off the vaccum hose to the EGR valve their should be some sort of change in the way it runs. Well with my car there is no change.
So after testing the EGR valve I wanted to see if it was getting any vaccum and I connected the vaccum pump to it and ran her and I had no vaccum. Now, is there supposed to be vaccum at all times or just at certain times? And I know the EGR valve solenoid is before the EGR and located under the intake manifold (a real PITA to get to). Is there any way of testing the solenoid before buying a new one for $92.45 from the dealer and taking my engine apart just to find out that it was good?
Thanks,
Montana
akryder86 is offline   Reply With Quote
Old 11-04-2006, 07:37 PM   #2
00Maddog
Member#: 62410
2004 ra'd redrex in
8k w/ STI kit :) DASH
egr only gets ported vacuum, anotherwards no vacuum until you open the throttle a crack. egr usually sticks open when it screws up, and the car backfires through the intake and won't idle at all.
sounds like the fuel pump is under par, do a pressure test. low psi will cause poor atomization, leading to longer injector pulsewidth and a rich condition.
00Maddog is offline   Reply With Quote
Old 11-04-2006, 07:51 PM   #3
akryder86
Member#: 74916
1993 Impreza L
All right. What would normal psi be so I know what to look for cause I don't know what that would be with a Subaru. Thanks
Old 11-09-2006, 12:32 AM   #4
00Maddog
Member#: 62410
2004 ra'd redrex in
figure it out?
Old 11-09-2006, 04:10 PM   #5
akryder86
Member#: 74916
1993 Impreza L
I'm trying to find a t-fitting that will fit my press. gauge and fuel line. It's hard finding a 5/16"x1/4"x5/16" fitting. Hopefully by Fri. I'll have a press. reading so if it is the fuel pump I can replace it on Sat. at my parents house. Would do it at work but when I get in at 7am the temp inside the shop is 18deg. and raises to a scorching 25deg. at about noon. I don't operate too well in the cold...like our deisel trucks
Old 11-09-2006, 06:54 PM   #6
00Maddog
Member#: 62410
2004 ra'd redrex in
i have a guage setup you can use if you want.
i'll be home saturday.
it's 70 in sacramento right now...
Old 11-09-2006, 10:14 PM   #7
akryder86
Member#: 74916
1993 Impreza L
Lucky, I wish it was 70 in the shop but a guy can dream right?
I found a fitting and am going to do the press. test here in a sec.
Old 11-09-2006, 10:17 PM   #8
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
u find it at ak rubber?
SQUAD_907 is online now   Reply With Quote
Old 11-09-2006, 10:50 PM   #9
akryder86
Member#: 74916
1993 Impreza L
Yeah, and just did the test, 30psi, which is 6psi under the normal operating range. Looks like I'm in the market for a fuel pump.
Old 11-10-2006, 01:00 AM   #10
akryder86
Member#: 74916
1993 Impreza L
Also, where is my fuel pump located? Napa says it's in the tank and Chilton's says it's external somewhere. Thanks again for the help and Jerry you were right on the money.
Old 11-10-2006, 11:29 AM   #11
00Maddog
Member#: 62410
2004 ra'd redrex in
the pump is in the tank, and all subarus have a pump access hole in the trunk or under the back seat. i think that ones at the front of the trunk on the r/h side. i have some pumps, wrx ones but i think they'll work.
6 psi is low, but it depends if thats at idle or accelerating. if that's at idle tape the guage to the winshield and go do an acceleration and then take a reading.
Old 11-11-2006, 02:16 AM   #12
akryder86
Member#: 74916
1993 Impreza L
Ok, I'll do that tomorrow. And Squad_907 gave me a wrx pump that I'll put in there tomorrow as well. If it's not the fuel pumo I'll be calling you. Thank you again Chris for the pump.
WTB: egr solenoid (los angeles area) wrx-chris SCIC Private Classifieds 1 05-12-2009 03:45 PM
WTB: purge / EGR solenoid for WRX / STI pirotlord Private 'Wanted' Classifieds 1 03-24-2009 07:59 PM
Wanted: Knock Sensor, EGR Solenoid, EGR Backpressure Sensor, Egr Valve Quix VIC Private Classifieds 2 07-09-2008 04:09 PM
Air suction solenoid valve and EGR solenoid valve Fail Wagon Normally Aspirated Powertrain 1 05-24-2007 11:05 PM
('93-'01) egr solenoid brus brother Impreza Forum 11 08-07-2002 01:27 PM
Message Board Statistics All times are GMT -4. The time now is 11:44 AM.
