Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 11-05-2006, 02:03 PM   #1
rao
Member Sales Rating: (6)
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Default 1989 Mazda RX-7 with LS1/T56 swap lots of goodies fully sorted lots of pictures
Time to move on to a new project. I found a deal I couldn't pass up, so it is time for this car to go.
Cliff's notes - approximately 450 hp/450 ft lbs. curb weight 3,000 lbs
89 Convertible that runs and drives very well and is fully sorted. There were 68k miles on the car before the conversion; 5k miles since the conversion. Clean title, licensed and registered. I’ve taken in on several long trips and drive it almost everyday.
BODY
New top in good shape (small white spot was there when I got it)
Paint in good shape for age although not perfect, some dings, the right rear behind the rear wheel has a large spot missing paint, some scratches and the front plastic is fading fast. From 20 feet awaythe car looks great. No rust. The hood has some dents from my relieveing the bracing to make more room for the intake.
Power locks and windows
Kenwood CD/MP3 head unit with removable face
8” sub in a sealed box with a 320 watt RMS amp
Amps and sub hidden under the spare tire cover and not visible
Kenwood 6.5” door speakers
Optima small yellow top battery in trunk
Autometer speedometer, tach, oil pressure, water temp and fuel gauges (the speedo, tach and OBD gauge are in the dash, the oil pressure, temp and fuel level are in an aluminum bezel below the radio)
Interceptor OBDII gauge in the instrument panel; has an adjustable integrated shift light and lots of other goodies
Custom instrument panel with 1/8” turn signal and high beam lights
AC works and is controlled by the LS1 PCM.
Wipers and light work
Aluminum spare tire
New heater core
JDM black cloth seats
New black carpet
New exterior door/window trim on both sides
Dynamat-like sound deadener installed in the entire interior
ENGINE AND TRANSMISSION
Motor is a 98 LS1 with 44k miles before the swap
AFR 205 Cylinder Heads
Thunder Racing 224/224 114 LSA cam
New LS2 Oil Pump
Katech rod bolts
Jesse Bubb PCM tune
LS2 timing chain set
LS2 Flywheel
LS7 Clutch and pressure plate; rated for 500 hp
Ported LS6 exhaust manifolds
Custom mandrel bent stainless dual 2.5” exhaust with an x-pipe and dual cats, two polished Magnaflow stainless steel mufflers and two 3” polished stainless tips in the stock location (this setup cost a small fortune)
New AC Delco oxygen sensors
SUSPENSION
MB Motorsports wheels and tires 18x8 front and 18x9 rear
Falken 451’s front 25/40-18 front and 265/35-18 rear
Complete Turbo II limited slip rear end swap
Manual steering rack
Pinion Snubber
Montgomery Machine rear subframe and differential bushings
Rear steer eliminator bushings
New Energy Suspension bushings all around (front and rear control arms)
New front strut tops
Hurst Shift knob
Hinson motor and tranny mount
JTR radiator with nice aluminum mount
DC Controls 3800 cfm fan with integrated controller
New Wilwood clutch master cylinder with bracket to mount it upright
New Stock brake master cylinder
New pads and rotors at all corners
New stainless steel Speed Bleeders all around
Mazdatrix adjustable Rear camber adjuster
I tried to be as complete as possible, but I have probably left some things out.
Car is located in Naperville, IL. If you are interested please send me a PM or an e-mail.
__________________
rao is offline   Reply With Quote
Old 11-05-2006, 02:03 PM   #2
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Pics 1 of 4
Picture on a nice sunny day 1
Picture on a nice sunny day 2
Picture on a nice sunny day 3
Front 1/4 view
Back view - top down
Side view - top down
Instrument Panel 1
Instrument Panel 2
Trunk
Under the Hood
Old 11-05-2006, 02:04 PM   #3
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Pics 2 of 4
Uner the Hood
Clutch and Brake Master Cylinders
Radiator and Intake
Under the Hood Left Side
Passenger Side of Engine Bay
Marks Near Windshield on Passenger Side
Close up of Paint Flaw behind Left Rear Wheel
White Spot on Convertible Top
Old 11-05-2006, 02:09 PM   #4
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Pics 2 of 3
Under the Hood
Uner the Hood
Radiator and Intake
Hood Dings 1
Old 11-05-2006, 02:12 PM   #5
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Pics 3 of 4
Hood Dings 2
Front View
Front 1/4 View
Side
Back 1/4
Back
Side View
Front 1/4 View
Old 11-05-2006, 02:12 PM   #6
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Pics 4 of 4
Interior
Interior
Seat Fabric
Radio and Center Gauges
Left Rear Wheel
Left Front Wheel
Right Rear Wheel and Paint Defect
Right Front Wheel
Old 11-05-2006, 05:37 PM   #7
ITSME4G63
Member Sales Rating: (2)
Member#: 88511
wow, this thing must pull like a raped ape! noice!
ITSME4G63 is offline   Reply With Quote
Old 11-05-2006, 07:17 PM   #8
homestar_kevin
Member#: 92962
Oh ...um, yeah sorry about that white spot on the top...I just got a little excited when I saw this car... um yeah...awkwarddddddd
Bump, and a wish that I had the money for this.
Kevin
homestar_kevin is offline   Reply With Quote
Old 11-05-2006, 10:42 PM   #9
amukaoen
Member Sales Rating: (21)
Member#: 62595
04 WRX Cobb S2
World Rally Blue
Nice car, too bad its not the 3rd Gen though
amukaoen is offline   Reply With Quote
Old 11-06-2006, 12:18 AM   #10
2ndtimearound
Member#: 79882
Wanna trade for a 2005 Yamaha R6??
Probably not but it doesnt hurt to ask.
2ndtimearound is offline   Reply With Quote
Old 11-06-2006, 01:48 AM   #11
xtian
Member Sales Rating: (34)
Member#: 93248
95 20g powered gc8
PPG'd yO! & is250 AWD
siiiiiiiiiickkkkkkkkk.. love fc 's
xtian is offline   Reply With Quote
Old 11-06-2006, 07:40 AM   #12
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Thanks for the nice comments. I already have the next project which is why the price is pretty low and I am not looking for any trades.
Old 11-06-2006, 10:06 AM   #13
DiscoGsus
Member#: 47646
0511 RallyBaja
DGM Sedan
Damn, If I bought this, I would just open the hood and stare at it rather then drive it.
DiscoGsus is offline   Reply With Quote
Old 11-06-2006, 10:51 AM   #14
h0m3r
Member#: 129760
2004 STi
Very very nice!
I can't vouch for this particular car but I have 3 friends who have LS1 FCs and they are freakin monsters! I'm thinking about doing a 240 or an FC myself in a year or two. Anyone who buys this will not be disappointed with either handling or straight line speed.
Good luck with it!
h0m3r is offline   Reply With Quote
Old 11-06-2006, 10:58 AM   #15
gotsol
Member Sales Rating: (4)
Member#: 17346
08 Cayman S
Nice Car Bro, G/L with the sale
gotsol is offline   Reply With Quote
Old 11-06-2006, 11:00 AM   #16
All4bSpinnin
Member Sales Rating: (10)
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
amazing car!! free bump
All4bSpinnin is offline   Reply With Quote
Old 11-06-2006, 04:11 PM   #17
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
cool swap...nicely done...Id'a chosen the drop top too.....way cooler
Sneeky Pete is offline   Reply With Quote
Old 11-06-2006, 05:42 PM   #18
Saucemaxx
Member Sales Rating: (7)
Member#: 32891
'03 EVO
If you still have it in January I will be calling
Saucemaxx is offline   Reply With Quote
Old 11-13-2006, 05:06 PM   #19
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Bump.
Old 11-18-2006, 07:19 AM   #20
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
FS/FT : SC: '90 RX-7 with LS1/T56 swap andrewp724 Private Vehicle 'For Sale' Classifieds 53 06-24-2010 11:02 PM
FS(VA): '93 Mazda RX-7 with built LS6 and T-56 working AC and PS. New paint. Rookie84 Private Vehicle 'For Sale' Classifieds 33 09-27-2008 03:55 PM
FS: 1993 RX-7 with LS1 swap! 16k!! brent_strong Private Vehicle 'For Sale' Classifieds 17 06-27-2008 02:03 PM
Last issue RX-7 with supposed engine swap jvcjbl Grassroots Motorsports Magazine Forum 7 08-23-2006 10:33 PM
