Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 11-05-2006, 04:06 PM   #1
DeadBolt Enterprises
Vendor
Vendor Sales Rating: (16)
Member#: 34272
2005 STi
Crystal Grey
Default Turbos Turbos Turbos! Also Thermotec and Tial Products-New pricing!
Deadbolt Enterprises - Often Imitated, NEVER duplicated!
NEW BUDGET SERIES TURBOS
Our products have never been the least expensive on the market, and we know that. We have recently gotten more and more requests from our customers to carry a budget series turbo that could save some money over our standard models so we have decided to offer these on a limited basis. The turbos below DO NOT INCLUDE ANY OF OUR PORTING OR COATING SERVICES!!! Water cooled models carry the same warranty and free rebuilds services as our Zilla series above, but NON-WATER COOLED MODELS DO NOT COME WITH FREE REBUILDS.
Prices for budget models include only the following accessories: Coolant lines, coolant banjo bolts, coolant banjo seals, oil return line, oil return line gasket, oil return line bolts, standard wastegate actuator. NO PORTING NO COATINGS.
Water Cooled Models (Wet cartridges)
TD05H-18G - $999.00
TD05H-20G - $1099.00
TD05H-Super16G - $899.00
TD06H-18G - $1199.00
TD06H-20G - $1299.00
Non-Water Cooled Models (Dry cartridges)
TD05H-16G - $499.00
TD05H-18G - $699.00
TD05H-20G - $799.00
TD06H-18G - $999.00
TD06H-20G - $1099.00
SHIPPING SPECIALS:
Standard turbochargers-$15.99
Larger Garrett Models (GT40, 42, etc.) - $18.99
STANDARD DEADBOLT TURBOS
TD04 Turbos
REBUILT TD04 $399*
Starting with a good condition core, we will perform a complete teardown, and rebuild including all seals, bushings, retainers, and O-rings.
MONSTER TD04 $599*
This is our original and most popular offering. Get a turbo upgrade without spending a ton of money. Quicker spoolup, much better "roll-on" acceleration, all new internals, we can even ceramic coat them for you!Starting with a good condition core, we will perform a complete teardown, and rebuild including all seals, bushings, retainers, and O-rings. After the rebuild we perform our now-famous Monster Port(TM) procedure.
Monster TD04 with upgraded compressor wheel - $799.00*
Same Monster TD04 as above, but with a larger, higher-volume compressor wheel and clipped turbine wheel for better midrange AND top end power. Nice turbo for folks running in race classes that require a "stock appearing turbocharger."
TD05H-16G Turbos
We were the first vendor in the US to market these on a large level, and still sell a TON of them all over the world! This turbo was originally never offered on the USDM WRX, or the later JDM versions as the compressor housing is not correct fitment for these models. We modify the inlet so that they fit perfectly on the USDM cars.
We include the metal coolant lines, banjo bolts, banjo seals, oil return with gasket, and stainless steel downpipe studs at this price unlike some other vendors! $799.00*
MONSTER TD05H-16G! Special Order - Same unit as above, except that we perform our famous Monster Port(TM) on the turbine housing providing even quicker spoolup, better midrange, and enhanced top end.
$949.00*
ZILLA SERIES TURBOS!
Remember, unlike some other companies our ZILLA series INCLUDES Installed Coolant supply lines, banjo bolts, AND Oil return line AND downpipe studs! (Over $150 for all necessary parts if purchased separately from that other vendor)
The ZILLA(TM) lineup will include our famous Monster Port(TM) Service, Port Matching to downpipe gasket, Wastegate porting, and turbine housing inlet smoothing. TD06 and Fat-boy models also include port matching of turbine inlet to gasket.
Coatings Included are Black Xtreme(TM) on exhaust housing, and Grey ceramic on compressor housing.
This is a LOT of turbo for the money!
WATER COOLED MODELS
Water cooled models include coolant supply lines, coolant supply banjo bolts, banjo seals, oil return line with gasket and bolts, and stainless downpipe studs.
18G Oil and Water Cooled TD06H turbine - $1445.00*
20G Oil and Water Cooled TD06H turbine - $1545.00*
Super16G Oil & Water TD06H turbine $1345.00*
18G Oil and Water Cooled TD05H turbine - $1295.00*
20G Oil and Water Cooled TD05H turbine - $1395.00*
Super16G Oil & Water TD05H turbine $1195.00*
3 inch inlet models of the 20G available at no additional cost, but require the use of Tumble Generator Valve deletes and 3 inch inlet tube.
All prices quoted above are for internal wastegate setups. We can weld the wastegate closed on the turbo for use with the TIAL brand of wastegates we sell below.
As always, email [email protected] or PM us with any questions.
SUPERZILLA!!!
SuperZilla turbos are available with internal or external gate, water cooled, or by special request, non-water cooled (dry)cartridges.
SZ55 19PSI-pump / 26 PSI C16
SZ49-55 are available with a 3 inch or standard inlet. 3 inch inlet models require TGV deletes and a 3 inch inlet pipe.
Limited time special pricing!
SuperZilla SZ49 oil and water cooled internally gated* - $1595.00
SZ55 oil and water cooled Fat-boy IWG configuration* - $1895.00
SZ60 oil and water cooled Fat-boy EWG configuration* - $1945.00
SZ65 oil and water cooled Fat-boy EWG configuration* - $1945.00
*-Prices do not include shippnig costs.
NEWLY RELEASED AND READY TO SCARE YOUR NEIGHBORS!
MEGAZILLA MZ72
Our newest monster, the Megazilla MZ72 features our gigantic Tsunami 555 turbine wheel, and a truly gargantuan 72 lb/min compressor wheel. This is the largest stock location turbo in the world. IT IS NOT BOLT-ON!!! Tumble Generator Valve Deletes MUST be used and a 3 inch inlet pipe. This turbo is available in very limited quantities, and is special order only. $2195.00 + shipping.
Don't forget! We are also a Thermotec warehouse distributor so we sell all the Thermotec goodies at the best prices!
We also carry Tial brand blow-off-valves, wastegates, etc.
DeadBolt Enterprises is offline
Old 11-05-2006, 07:45 PM   #2
Capt Crunch
Member Sales Rating: (15)
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
I want pics of the megazilla plz
Capt Crunch is offline
Old 11-05-2006, 11:13 PM   #3
pornie
Member Sales Rating: (1)
Member#: 5620
so is this before or after core?
pornie is offline
Old 11-06-2006, 08:15 AM   #4
Vendor
Member#: 34272
2005 STi
Crystal Grey
The only items with cores are the Monster TD04, which are priced not including the core refund. The rest of our products are all brand new, not rebuilds.
Old 11-07-2006, 08:10 AM   #5
Vendor
Member#: 34272
2005 STi
Crystal Grey
Upsy daisy.
Old 11-08-2006, 07:45 AM   #6
Vendor
Member#: 34272
2005 STi
Crystal Grey
Trying once more on the two VF series we received about 60 days ago with no turbine housings. If nobody claims these quickly we will put them in our off-site storage.
Old 11-08-2006, 03:56 PM   #7
AirDogg2599
Member Sales Rating: (5)
Member#: 102150
07 WRX
what kind of VF turbos are they? what condition? hey, i'll claim them if nobody wants them lol j/k
AirDogg2599 is offline
Old 11-08-2006, 04:19 PM   #8
Vendor
Member#: 34272
2005 STi
Crystal Grey
Actually looking for the real owner. We have this type of thing happen on occasion, usually we don't have to wait this long however, I suppose the person that sent them is not in much of a rush (they have been here for almost 60 days now)
Old 11-08-2006, 04:31 PM   #9
AirDogg2599
Member#: 102150
07 WRX
lol ........60 days is a long time. what kind of turbos are they?
Old 11-08-2006, 06:21 PM   #10
Vendor
Member#: 34272
2005 STi
Crystal Grey
A couple of older VF's with no lines or housings. Not in the best shape, I am starting to wonder if the customer decided it wasn't worth the hassle.
Old 11-13-2006, 08:06 AM   #11
Vendor
Member#: 34272
2005 STi
Crystal Grey
Happy Monday!
Old 11-13-2006, 09:31 AM   #12
numba1si
Member#: 107360
i want one =(
numba1si is offline
Old 11-14-2006, 02:29 AM   #13
Bishop
Member Sales Rating: (108)
Member#: 59993
Ass, grass or cash
no one rides for free!!
bumpin!
Bishop is offline
Old 11-14-2006, 07:48 AM   #14
Vendor
Member#: 34272
2005 STi
Crystal Grey
Originally Posted by Bishop View Post
bumpin!
Thanks
Old 11-14-2006, 02:04 PM   #15
Vendor
Member#: 34272
2005 STi
Crystal Grey
Upsy Daisy! Get 'em while they're hot!
Old 11-15-2006, 10:32 AM   #16
EVOTHIS
Member#: 66822
do you guys sell a regular 16g watercooled? Any IHI's around?
EVOTHIS is offline
Old 11-15-2006, 01:23 PM   #17
Vendor
Member#: 34272
2005 STi
Crystal Grey
Yes, we have a couple different 16G offerings, either the straight inlet or a 90degree version for the older (non-US) WRX. Not much in the way of IHI's since the price increases, but on occasion we do get a decent used one here.
Old 11-17-2006, 08:24 AM   #18
Vendor
Member#: 34272
2005 STi
Crystal Grey
Its Friday!!!
Old 11-18-2006, 07:01 AM   #19
wileecoyote
Member#: 82610
2003 WRX GDA
Black Carbonfibre
Thanks for your free rebuilt for my superzilla!
Bump!
wileecoyote is offline
Old 11-20-2006, 08:45 AM   #20
Vendor
Member#: 34272
2005 STi
Crystal Grey
Bump!
No problem! Has it arrived back to you yet?
Old 11-20-2006, 09:04 AM   #21
symby
Member Sales Rating: (4)
Member#: 7011
2002 Impreza WRX
I have a couple questions for you. I think I know what some of your options do, but please correct me if I'm wrong. In particular I am shopping for a TD05-16G.
What gets ported when you do the Monster Port?
What do either of the coatings Black XTreme->turbine and and Ceramic->compressor coatings do for me? I think this is more for heat retention.
Compressor housing outlet port - smoother compressed airflow to the intercooler I guess. Does this make a significan't difference?
Turbine Wheel Clip - What exactly do you do for this and what kind of benefits/tradeoffs come with a clipped wheel?
I would assume that if I did every extra upgrade to a 16G turbo I would essentially have a quicker spooling turbo that can produce about the same power? Is this correct?
Edit: I did look for explanations of some of these options on your website, but found nothing. It would be sufficient if you had a link explaining what they do instead of typing it out.
symby is offline
Old 11-20-2006, 03:10 PM   #22
wileecoyote
Member#: 82610
2003 WRX GDA
Black Carbonfibre
Already got it in my home,learn a few things about nice packaging
by looking at your big box. Thankyou
Old 11-20-2006, 03:18 PM   #23
Kvarnis
Member#: 18753
95 WRX STI-RA
WHITE
Jeryy, tried to mail you but the mail bump back pm'd also
/Jan
Kvarnis is offline
Old 11-20-2006, 05:18 PM   #24
FastInMass
Member#: 96082
2003 Stage 2 WRX
Sedona Red
great questions...i was wondering the same
FastInMass is offline
Old 11-21-2006, 07:57 AM   #25
Vendor
Member#: 34272
2005 STi
Crystal Grey
The Monster Port(TM) setup is actually several services rolled into one package. We smooth the turbine inlet, port the wastegate, port match the turbine outlet to a factory gasket, and then do a lot of heavy resculpting/re-contouring and smoothing of the turbine discharge area.
The ceramic coatings are thermal barriers. The Black Xtreme(TM) product, when applied to the turbine housing will have a couple of benefits due to the increased thermal insulation. The extra heat retention will allow more energy to be transferred to the turbine wheel, giving better spoolup. The improved heat-holding capability will also help reduce underhood temperatures by a bit and help to avoid heat soaking a top mounted intercooler or front mount piping. The grey coating actually does the reverse. This coating is designed to keep the uppipe heat, engine heat, etc. from pre-heating the charge air.
The difference is not very great. This will smooth out throttle response and in some cases add 2-3 HP. The cost is not very great, but the benefit is not huge either.
Clipping refers to a system in which we remove the trailing edges of the turbine blades. This allows better airflow and less backpressure. When done properly there is a very slight (almost not-noticeable) slowing of spoolup time, but better exhaust evacuation can allow better top end power.
This is correct with the exception of the turbine wheel clip, which is not normally recommended on the 16G.
Closed Thread
Garrett 60-1 turbo / NEW Tial Wastegate / NEW Tial BOV Dr. Dooms Engine/Power/Exhaust 6 04-21-2015 11:56 AM
Fs: Wv: Blitz Full Auto Turbo Timer DC III/IV and harness BRAND NEW! BoostedSti MAIC Private Classifieds 0 06-21-2008 11:50 PM
Fs: Wv: Blitz Full Auto Turbo Timer DC III/IV and harness BRAND NEW! BoostedSti Engine/Power/Exhaust 0 06-21-2008 11:49 PM
