Old 11-12-2001, 03:43 AM   #1
shogunate83
Member#: 6006
Post FOR THOSE of you who want an easy time getting off oil filters
If you want to get your oil filter off easily YOU want this tool...
Go to a local napa store and tell them you want part number
775-9018 or
http://www.napaonline.com/cgi-bin/nc...5&prmenbr=5806
this is a great tool....especially if you are changing your oil filter for the first time... this tool is used with a ratchet... the tool has claws that grip on to your oil filter... while turning the ratchet, the claw gets tighter and the oil filter starts to move
The price is only like 6 bucks
shogunate83 is offline   Reply With Quote
Old 11-12-2001, 09:17 AM   #2
HokieEngr
Member#: 6732
2002 WRX 5door
SOLD!
Thumbs up
Man, you've gotta work for or own a NAPA store. You pimp the place more than I do and my family has owned NAPA stores for 4 generations.
Ryan
HokieEngr is offline   Reply With Quote
Old 11-12-2001, 03:22 PM   #3
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Other than the initial oil change, I don't think I've had to use a tool to get the filter off, just used my hand. Put some oil on the seal before installing the new filter and don't crank on the thing after getting it snug, and it'll come off fairly easily the next time.
Steve
http://www.forcefed4.com
SteveS is offline   Reply With Quote
Old 11-13-2001, 01:22 PM   #4
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
SteveS,
You are NOT tightening the filter enough if you can remove it by hand. You should tighten it 3/4 to 1 full turn after the filter contacts the base. After all, it's better for it to be too tight than too loose. The LAST thing you want is for that filter to come off by itself. Unless you're one heck of a strong fellow, and you want to wait for the engine to be cool (which is not the best way to drain the oil) use a filter wrench!
Alan is offline   Reply With Quote
Old 11-13-2001, 06:02 PM   #5
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Thanks for the concern, Alan, but I have yet to have a problem and I've been doing this for quite a few years. Usually I use the wrench because, like you pointed out, the filter is warm/hot. But I stand by what I said, you want the filter tight enough not to leak or come loose, and that's it. Any tighter is useless. Hand tight is tight enough.
Also, make sure to use some oil to lubricate the ring seal. Wipe off the filter mount on the bottom of the engine. And fill the new filter up with oil before installing.
Steve
Old 11-13-2001, 06:27 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
The 2002 Owner's Manuals suggests:
6. Remove the oil filter with an oil filter wrench.
7. Before installing a new oil filter, apply a thin coat of engine oil to the seal.
8. Clean the rubber seal seating area of the lower crank case and install the oil filter by hand turning. Be careful not to twist or damage the seal.
9. Tighten it approximately two-thirds of a turn after the seal makes contact with the lower crank case.
I'm confident that the instructions for older Imprezas are very similar.
Jon [in CT] is offline   Reply With Quote
Old 11-13-2001, 09:13 PM   #7
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
I've had one for quite a while. Worth it's weight in gold:
Peaty is offline   Reply With Quote
Old 11-14-2001, 12:57 AM   #8
G-REX
Member#: 8804
2008 Impreza STi
Dark Gray Metallic
Default You want cheap?
Vacuum cleaner belt. 48 cents.
Slip it over the filter and twist. I don't remember how the hell I figured that out but I've been using it for years.
G-REX is offline   Reply With Quote
Old 11-15-2001, 05:03 PM   #9
wrx02blk
Member#: 11055
2002 Impreza WRX
Midnight Black Pearl
Thanks Peaty! i just changed my oil for the first time. I bought the filter wrench you suggested and it worked great. They are put on tight from the factory!
wrx02blk is offline   Reply With Quote
Old 11-16-2001, 07:49 AM   #10
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
I don't know why the factory installed filters are such a b!tch to get loose. I remember struggling with mine even with a filter wrench. I suspect it's because they don't lube the ring seal and they have some Sumo wrestler installing the filters.
When replacing my head gaskets, we were surprised at how "loose" the head bolts were. I suspect that Subaru was doing some cross training and the head bolt torquer was installing filters and the filter guy was installing the head bolts!
Steve
Old 12-15-2001, 02:13 AM   #11
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
Originally posted by Alan
SteveS,
Having it too tight is going to cause you almost as many problems as having it too loose. If its too loose chances are its not going to just fall off there is a good deal of pressure that will keep it in place so it will only leak. And the same thing happens if it is too tight, you will break the gasket or overexpand it and it will leak like a bitch. Also if too tight you can strip the threads either when putting it on or taking it off later that would be really bad!
Just hand tighten it, tighten it like you would turn down the volume on your stereo. Once it stops being easy to tighten stop trying. Once the knob on your stereo stops you dont keep trying to twist it further do you? Same principle, dont use a lot of force and when it stops your are done.
Evaider is offline   Reply With Quote
Old 12-28-2001, 04:45 AM   #12
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
WR Blue. Cobb Stage 2
I don't know about the 'volume control' analogy, but I agree with SteveS-hand tight is tight enough. As long as you can get close to the recommended amount of rotation after the gasket contacts the filter base you'll be fine.
There seems to be an American attitude that 'more is better'--if snug is good, as tight as possible is better! Even when put on by hand, filters sometimes require a filter wrench to remove them. If they are installed with 100 ft-lbs of force they are almost impossible to remove.
I've always lubricated the gasket with oil and tightened them by hand. I've put maybe 750,000 miles on various vehicles without a problem.
sajohnson is offline   Reply With Quote
Old 01-02-2002, 06:02 PM   #13
tdman77
Member#: 9832
2004 STI
When I had my mustang I went to Saleen and had them do some eng work. Their tech quoted this rule and since I have always used it. "One hand on and two hands off" Works just fine on 3 different cars so far.
tdman77 is offline   Reply With Quote
Old 09-19-2002, 02:47 AM   #14
WTypeRogerX
Member#: 20968
2005 WRX Sportwagon
World Rally Blue
Why? Doesn't that make it harder to screw on and you risk spilling everywhere if you don't screw it on correctly?
WTypeRogerX is offline   Reply With Quote
Old 09-19-2002, 08:47 AM   #15
z&cobb
Member#: 12344
2002 2JC
blue
It is supposed to prevent start up wear on your engine. If you have warmed up the car, there should be some oil on the parts anyway. I have never seen data to show that putting oil in the filter will make your car last xxx,xxx thousand miles longer.
My Maxima, 300ZX and Camry filters are oriented to make this approach impossible anyway. The 300ZX has like new performance, actually better since there are some mods, and has 300,000 on the original internal engine parts. If you pull up next to it in a 240hp van at a light, it is definitely still a sleeper.
I guess with the WRX we have the opportunity to do this. But will it mean that we will have like-new factory compression at 400,000 miles? Who knows?
You can avoid making a mess by not filling it all the way up, so you should at least get xx,xxx miles more.
z&cobb is offline   Reply With Quote
Old 09-19-2002, 05:42 PM   #16
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
During pre-fill the filter media will absord ~4oz of oil until saturated then you will begin to see a level in the bottom of the filter. Stop pre-filling at this point if the angle of the filter during install will spill oil.
Albert is offline   Reply With Quote
Old 09-19-2002, 09:02 PM   #17
z&cobb
Member#: 12344
2002 2JC
blue
On the ZX the angle = a total dump of oil. Always a mess to remove too. However, you can remove it from the topside. The WRX is the first car I have had where it is relatively easy to install a nearly full pre-loaded filter.
For those of you who installed an oil temp gauge Division By Zero Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-15-2002 08:41 PM
For those of you who want Hakka 2/Q's for winter tires youthanasia Vancouver Impreza Club Forum -- VIC 0 02-05-2002 04:57 PM
For those of you who wanted to see my CF intake pipe... webkris New England Impreza Club Forum -- NESIC 9 10-24-2001 01:20 PM
Antarctica - For those of you who want to know... SubieRacer General Forum Archive 28 10-25-2000 02:42 PM
For those of you who want stickers Penphoe Vancouver Impreza Club Forum -- VIC 11 08-26-2000 01:36 PM
