Old 11-06-2006, 02:28 PM   #1
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Default Your car is warmed up and you let it idle for a long time: What's that damn knock?
Like the long title says:
What's that knock from the engine after it idles for a long time (5 minutes)? I figure on replacing EVERYTHING in my shortblock just to be on the safe side. I've heard of other scoobs doing this and it's normal. The "normal" part is what I don't believe. However, it did run like a champ the whole time, so I'm hard pressed to say anything was wrong. It was totally random and my car didn't consume any oil. Was it the timing belt tensioner?
<---confuzzled. His car is in pieces and he's looking for an excuse to upgrade everything
HamFist is offline   Reply With Quote
Old 11-06-2006, 02:47 PM   #2
atech_rallyrs
Member#: 116638
00 impreza naSTi
el typico silver
Its your car requesting to have everything upgraded.
atech_rallyrs is offline   Reply With Quote
Old 11-06-2006, 03:06 PM   #3
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
Don't really know, however I had a wrist pin freeze and shatter the piston once. Not a subbie engine, but I would get this light knock on and off. Too deep for a lifter but too light for a connecting rod. Anyway when it finnally went it took the block with it.
If you got it apart check them out.
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 11-06-2006, 04:58 PM   #4
protocall
Member#: 38348
My moms 2002 forester knocked when cold. I told her it was normal. She took it to a dealer anyways. They replaced one cylinder and head gaskets under warranty. I don't know how that makes any sense, but the car never knocked again and drove much, much smoother
protocall is offline   Reply With Quote
Old 11-06-2006, 05:48 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I'd check the tensioner, as well as the idler pulleys for the timing belt.
Old 11-08-2006, 12:17 AM   #6
kavy
Member#: 124824
07 Impreza
CGM
normal,
lifter tick happens to all vehicles boxer's are just louder.
kavy is offline   Reply With Quote
Old 11-08-2006, 10:44 AM   #7
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
My SOHC doesn't have lifters. The DOHC have buckets, is that what you mean? That doesn't explain my occasional knock like this. I'm tearing down the motor and it's almost out. I didn't know what I might look for aside from any bearings that might be fried.
Old 11-09-2006, 09:25 AM   #8
GreenMarine
Member#: 36080
If you can tell me how they "replaced one cylinder" that would be great... Never heard of people replacing cylinders in engines (other than old Aircraft engines)...
GreenMarine is offline   Reply With Quote
Old 11-09-2006, 09:48 AM   #9
protocall
Member#: 38348
Sorry man don't know the details. This was over a year ago. I got the info through my mom which probably isn't the most reliable. Could it have just been one cylinder head?
The point of my post though was that I don't think the knocking is always normal. Her car knocked the same why mine did when it was cold. After the service it no longer did that. And it drove smoother and stronger.
Old 11-09-2006, 11:53 AM   #10
wagonman
Member#: 971
I would say piston slap, but if it does it when its warm....I would lean towards the normal Subaru valve ticking.
My 93 did it until we sold it with 184,000 miles on it, and my 00' RS does the same thing.
wagonman is offline   Reply With Quote
Old 11-09-2006, 12:55 PM   #11
Hayes
Member#: 11808
I'm with 8complex, as a possible cause is the timing belt tenioner
Hayes is offline   Reply With Quote
Mechanical Engine Knock After Car Is Warmed Up buzz313th Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-26-2013 09:10 AM
Cold Startup: How Long Do You Let It Idle? bnr34rb26dett General Community 58 11-17-2008 02:33 AM
If your car is towed how would you know where it went? -=C=- Off-Topic 6 04-24-2007 09:56 PM
Why do I smell gas when the car is warming up? BangWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 02-18-2007 08:25 AM
CAR is back up and running insane. AHAH sad turbo civic tried to race me! AWJunkies Southern California Impreza Club Forum -- SCIC 2 07-26-2003 01:13 AM
