Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 11-06-2006, 07:16 PM   #1
4pOwnag3
Member#: 53200
2005 LGT
Question question about clutch adjustment, please help
ok, so i bought the subaru loyale wagon from 1992. The problem is that the clutch is so short that its very difficult to drive ! i know its a mechanical clutch and that to adjust it the "fork" is located on one side of the engine bay? can anyone please give me some more details about how to do this, pictures would be great. i used the search feature, and other various sites to try and figure it out.
thanks in advance -MIKE
4pOwnag3 is offline   Reply With Quote
Old 11-06-2006, 07:48 PM   #2
dibblejr
Member#: 94070
05 LGT
You can try to adjust it under the dash. I cant remember when I installed my racing pedals.
The pedal will probably have a couple nuts to lock it.
Im not sure about your model though.
You sure the clutch isnt going?
Jay-R
dibblejr is offline   Reply With Quote
Old 11-06-2006, 09:11 PM   #3
4pOwnag3
Member#: 53200
2005 LGT
not 100% sure, but the guy i bought it from is a buddy of mine and when i drove it its seems fine. The thing is that the release point is really early! and idk how to raise it at least like an inch! - thanks again
Old 11-06-2006, 09:33 PM   #4
dibblejr
Member#: 94070
05 LGT
Check the spring underneath the dash, you might be able to get a shorter spring thus making it recoil higher.
Just a thought.
Someone will probably have a better answer.
Jay-R
Old 11-06-2006, 09:38 PM   #5
4pOwnag3
Member#: 53200
2005 LGT
interesting. . . going to play with it this weekend. . . maybe tomorrow morning? thanks Jay-R!
More suggestions always welcome! - Mike
Old 11-06-2006, 09:42 PM   #6
dibblejr
Member#: 94070
05 LGT
be careful with that spring, it is under a lot of tension, it can put a hole in your finger or take out an eye.
jay-r
Old 11-06-2006, 09:46 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You're asking about a cable clutch on an older car, most people seeing this are only familiar with the newer hydraulic clutches and will base their responses on that.
For more accurate info you might try posting in the "Old School" forum where there are people familiar with your car.
Old 11-06-2006, 10:17 PM   #8
4pOwnag3
Member#: 53200
2005 LGT
i would, but nobody looks there. . .
Old 11-06-2006, 11:02 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Well I suggest you try. Or at least post in the Transmission forum where some of the more technically knowledgeable folks hang out.
Old 11-07-2006, 12:30 AM   #10
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
There are two nuts on the end of the cable (just like your parking brake)
One is 10mm and the other is 11mm (IIRC)
Loosen one, tighten the other down a bit, then tighten the other to hold it in place. Drive it and adjust as needed. Don't overtighten it as that can cause the clutch to stick and wear prematurely.
coilover question-ride height adjustment-please help hunter15 Brakes, Steering & Suspension 3 08-12-2009 05:46 PM
Question about swapping suspension please help! ar0b Brakes, Steering & Suspension 1 01-04-2009 04:16 PM
Question about wireless modems. please help Eric SS Off-Topic 26 06-17-2005 01:33 AM
Questions about wheel install. please HELP! SubSonic Tire & Wheel 2 05-04-2003 12:22 AM
newbie question about Sway bars - please help Osgood30 Brakes, Steering & Suspension 2 08-16-2002 06:34 PM
