11-07-2006, 09:55 AM | #1 |
Member#: 127694
Who Tunes Hydra in FL?
Hello,
We are getting ready to install the following on my 05 STi sometime tomorrow: Hydra EMS Hydramist Meth Injection PE 850cc Injectors Perrin Fuel Rails Walboro 255 Fuel Pump Perrin FMIC Tial 44mm Wastegate Greddy Type R BOV GT35R (.82) Turbo GTSpec Exhaust Manifold Greddy Profec B Electronic Boost Controller The block will be stock Clutch will go in within a week or two after tune The rest will be under body braces and suspension related. Now, I don't know where in Florida I can get the car tuned reliably for this setup. I have heard many great things about Doug over at TopSpeed but that is about 420 miles away from me. I am looking for some suggestions, should I drive my car up to Georgia (untuned) for Doug to tune or is there a reputable tuner in FL that can work with Hydra's that is not 7 hours away like Doug is? If I can drive the car like this for that many miles, how can I do so without going into boost? Is it safe to set the wastegate for just 8psi via the boost controller so that I can drive the car up there with the stock ECU connected at least and connect the Hydra up in Georgia? I need some suggestions. Thanks
11-07-2006, 11:14 AM | #2 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
You can try jblaine. He's too humble to call himself a tuner, but he might help you get started.
11-07-2006, 11:43 AM | #3 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
Wow, that's quite an ambitious list for tomorrow
I am unaware of any "professional" tuners in FL with experience tuning Hydra units. Phil showed the ins and outs of the Hydra to the head tuner at Central Florida Turbo ("Rolo") when he was down for a Hydra tuning day. CFT is in Orlando, but I really cannot recommend them in good confidence. They have many very fast cars, but they're not my kind of guys (professionally, level of detail, care... etc). Phil, in contrast, is. You have the WB02 add-on? You have a ~850cc STI base map from Phil @ Element Tuning? I wouldn't do anything with the stock ECU after those mods. If you want to drive without the ability to make boost, you have few options. 1. Set the Soft RPM Limit to 3500RPM (max). 2. Give yourself a big purposeful leak between the turbo outlet and throttlebody. This should be relatively easy with the BOV. If (and only if) you have an 05 STI base map from Phil already, you are welcome to book a hotel in St. Petersburg and we'll go out at midnight and I can very likely get you a rough (but safe) tune up to 15psi or so. That's as far as I'll take it. I've tuned my own Hydra for the last 12 months, but obviously I will not be held responsible for your car, engine, or safety. |
11-07-2006, 12:30 PM | #4 | |
Member#: 127694
I am in Orlando. I am interested in scheduling something with you to get a base tune like you mentioned. I have to call Phil today to get a stat on my hydra (as far as delivery) My girlfriend lives in St. Pete so I can crash there ;-) Please give me a call at 321-226-0193 Tito PS thanks for the help guys!!! |
11-07-2006, 12:54 PM | #5 |
Member#: 8512
South East
Better yet, I'll PM you my number. I can do this any night with 1 day's notice (no wife, no kids) but, I want to be really up-front and clear here at the risk of sounding dick-ish:
- I'm not gonna wrench on your ride to fix anything in order to get things tuneable. If the car is not finished and buttoned up (aside from the tune), you are welcome to use my tools, but it will likely be a wasted night. - I know absolutely nothing about the Greddy Profec B. I suggest you bring the manual if you're not savvy. - You'll respect my life while driving while I am tuning - I will try my best and if everything falls into place as it should, it should be a pretty easy night, but I don't want to hear any flack if we're not able to get you a rough 15psi tune |
11-07-2006, 01:07 PM | #6 |
Member#: 32636
Vehicle:2004 Impreza STi Silver/Silver |
Congrats to jblaine for being availble for help, I don't think any of that sounds dick-ish at all.
offset |
11-07-2006, 03:22 PM | #7 | |
Member#: 127694
I'll be there just for the tune and no wrenching. I'll bring the manual for the boost controller. Thanks a million for the help. I will contact you tonight. I have to give Phil a call |
11-07-2006, 03:27 PM | #8 |
Member#: 8512
South East
Right on.
11-08-2006, 10:51 PM | #9 |
Member#: 113734
South East
Vehicle:2023 FL5 Type R Subaruless |
Hydramist in one day, haha good luck, and a turbo
11-18-2007, 08:42 PM | #10 |
Member#: 84377
South East
Vehicle:2011 335d |
i cant read dates correctly.
11-19-2007, 06:53 PM | #11 |
Member#: 56468
NWIC
I'll be there in January if you are still looking to tune. I've tuned dozens of hydras and of course my own. I tune with open source stuff and UTEC as well. We'll call me "semi-professional" since I'm not giving up my day job yet, but I tune 1-3 cars per week. Might be there in Dec. we'll see. Sister is in Stuart, FL.
11-19-2007, 07:51 PM | #12 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
I hope this continues because then I'll never have to leave DC
I have also heard good things from a couple customers about Brandon at PSI Racing in Miami. Just do your homework and look for happy customers who have been tuned with the Hydra. It doesn't matter what shop X says, it always boils down to happy customers for product X. As JBlaine mentioned as long as you are starting with an Element base map and your tuner knows the Hydra well then they should have a fairly easy time dialing in the fuel curve and making various adjustments where they are needed. Just go with someone who really knows the Hydra well and you can't go wrong. No matter how good the tuner is they can never tune out "broken." Bring your tuner a car that is put together properly with the kinks worked out. Thanks, Phil www.elementtuning.com |
11-28-2007, 06:40 PM | #13 |
Member#: 69461
South East
Vehicle:2004 WRB/Sti 11.41 @ 123mph |
LoL dude i have almost the same exact set-up as your car, I`am tuned on 91 and c16. If you need a nice map to run the car and get started, I have a decent one, I still need a 93 retune so i can make more power with our wonderful 93 octane and elevation
I should have my car back up and ready in the next month or so, praying for January If someone is able to I`d love to learn the ins and out of tuning the hydra, ya know the basics. seeing i cant pay someone to tune my car forever haha. OR how about, a Dyno day for phil from element tuning to come down here and tune some hydras! Last edited by STi_Guy04; 11-28-2007 at 06:49 PM. |
11-29-2007, 07:00 PM | #14 |
Member#: 58405
Vehicle:2004 Element GT65'd Hydra, Hydramist'd STi |
^^ I should be receiving the rest of my parts in anyday now from element and would love to get it tuned by Phil,
I'm in south florida as well, GT65, hydra, hydramist, TGVs, etc... lets get this together, sometime in January after the holidays would be great |
11-29-2007, 07:05 PM | #15 | |
Member#: 58405
I'm in Florida as well, (Delray Beach) GT65, hydra, hydramist, TGVs, etc... lets get this together, sometime in January after the holidays would be great Quote:
11-29-2007, 10:34 PM | #16 |
Member#: 69461
South East
Yea man My hydra mist was a task to install, mines hooked up pretty sick! If you want i can show you pics, Really that thing takes a few days to get right. BUt damn does it make power. I run 50/50 h20 and meth.
but really though we should push and get together and try and get phill down here for some tuning soon! maybe shoot for mid january or something, For sure hit me up with some of your details, I`d like to get tuned on the new Hydra software thats coming out. |
12-01-2007, 03:05 AM | #17 |
Member#: 54918
Guys I would be happy to tune you when I have time. One of the Orlando shops called me trying to get me down there but I'm not even in the country right now so I couldn't accommodate but January should be a good time for me if you are interested. Any excuse to get out of our freezing cold weather. LOL
12-01-2007, 04:25 PM | #18 |
Member#: 69461
South East
Nice Phil! It would REALLY REALLY be great if you could come down here, I was wondering by chance if you would have the the newest version of the hydra if you did decide to come down here for January,
To the other guys we should all talk a little bit about making this happen, if we all divide the price it wont be so expensive, and we`ll all get the best tunes from the best hydra tuner. As for me I have 2 tunes I would Need, Pump 93 tune with 50/50 meth/h20 and C16 race gas tune. so I would imagine i would need 2.5-3.5 hours of tuning |
12-04-2007, 12:35 PM | #19 |
Member#: 58405
sometime in January/February would be great,
hopefully i can get everything in by then |
12-04-2007, 06:17 PM | #20 |
Member#: 69461
South East
yeah I`am more down for February. as that would give me time to break in the motor properly. And or sort out any issues,
12-10-2007, 06:30 PM | #21 |
Member#: 58405
good things come to those who wait,
just got in my GT65, hopefully going to install the kit this weekend, the holidays pose a bit of a scheduling problem for my install, car will prolly be down for a bit though anyone with free weekends wanna pitch in, lets push and get some people on for Phil to come down and tune, Phil, what do you need from us to come on down?? How many cars, cost, etc.?? looking like sometime in February for me too seeing that this year is pretty much over |
12-18-2007, 10:24 PM | #22 |
Member#: 58405
http://forums.nasioc.com/forums/show...7#post20441777
Hey Phil, i posted a thread up in the SE forums to see if there is any interest, how many cars would you like to see commited? |
12-19-2007, 11:35 AM | #23 |
Member#: 54918
I will come as long as there is 8 hours worth of work. Keep in mind that most Hydra tunes take 2-3 hours for pump gas and +1 hours for race gas or water injection so I can really only squeeze in 3 cars a day as there are always car issues and you have to factor in setup and breakdown of the dyno. I used to allow four but someone usually got the short end of the stick so I rarely allow that anymore.
12-19-2007, 02:27 PM | #24 |
Top Scoob 002
Member#: 32771
BAIC
Vehicle:03 Black WRX 04 White M3 |
You mean you don't like staying up till 2am in the morning tuning cars?
12-19-2007, 02:46 PM | #25 |
Member#: 54918
who tunes ecutek in the hudson valley (or close) | chu my pu | Tri-State Area Forum | 0 | 03-05-2008 09:46 PM |
Who tunes hydra in the tri-state area? | [email protected] | Tri-State Area Forum | 3 | 05-03-2007 08:02 PM |
Who can tune EcuTek in FL? | wrxwhat | South East Region Forum | 17 | 04-23-2007 08:31 PM |
Element Tuning Hydra is in my car!!!! No really it is. | JRJ WRX | Other Engine Management | 49 | 10-26-2004 11:19 AM |
Utec tuning help in FL | wrxsc | South East Region Forum | 6 | 09-17-2004 02:23 PM |
