Old 11-12-2001, 01:46 PM   #1
EneMy X
Member#: 12222
1991 Toyota Mr2
Red
Default New to the scoobys, can someone answer some simple Q's for me?
Hello AWD guys...
I own a Very fast mr2, I am planning on getting a second car, Im thinking about picking up a 1998 2.5 RS...
I have no intention on keeping it stock. I have searched the net and the threads and havnt been able to get much info on engine swapping and turboing the RS....
so Im wondering if anyone has any info or websites where I can read up on the 22b swap or any other swaps for the Impreza.
I chose the RS over the DSM and other RWD/AWD cars becuase they are the lightest of the AWD cars out there (as far as I can see) My goals would essentially be a low 12 or high 11 second pass time. I could of course just build the 2.5 liter motor and turbo that but Im not sure what the best option is...
Are the Scoobys powerd by a map sensor or a Mass air flow type of sensor?
Thanx for any help guys.
EneMy X is offline   Reply With Quote
Old 11-12-2001, 02:33 PM   #2
jeffg
Member#: 2958
2001 WRX (GC8)
The 1998 RS you are looking at has a MAF based fuel system. It also has 9.8:1 compression. The compression makes it hard to run very high boost. I have seen a couple of people running ~10psi on stock internals, but not much more than that. If you want a high boost car to use at the strip, do not buy an RS. Buy a cheaper L series Impreza that is AWD. You can then turbo the 2.2L engine or swap it out for a 2.0L WRX motor. This will save you a lot of money and you will end up with basically the same car.
Just my opinion.
Jeff
jeffg is offline   Reply With Quote
Old 11-12-2001, 02:35 PM   #3
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
Most of your answers will be in the non-factory forced induction forum.
As far as airflow, my98 and my99 2.5s have MAFs, and my00-01 have MAPs. my98 is DOHC, and my99-01 are SOHC. They found the SOHC to produce more torque.
Hope this helps
Rob
DanzBorin is offline   Reply With Quote
Old 11-12-2001, 02:57 PM   #4
sstyle
Member#: 2743
98' RS
Pearl Black
Keep in mind that turbo or engine swap = new tranny and clutch. Also the MY98s have the older style front bumper and not as many options as the MY99+ because of the MAF. This car is not a drag car, it is a lot more. Just ask any of the rally or autocross guys. I would slap on a turbo but also work up the suspension.
sstyle is offline   Reply With Quote
Old 11-12-2001, 02:59 PM   #5
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
Lightbulb
Yeah... you really want an engine with a MAP. All I hear are people complaining about their blown MAFs.
-IggDawg
IggDawg is offline   Reply With Quote
Old 11-12-2001, 03:05 PM   #6
EneMy X
Member#: 12222
1991 Toyota Mr2
Red
Default Hi
thanx for the info guys
Of course that is always in my mind. Especially with the AWD, I have built 4 cars, all turbo, civic, DSM, Mr2 and a golf...have been working on cars for about 8 years, So I know how the lines go, I just really love the 2.5 Im maybe thinking about getting a WRX clip or somthing...but it looks like will cost a pretty penny
Old 11-12-2001, 03:07 PM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
MAF's are terrible when desinged and anchored right. But i don't understand the impreza drag racing scene...these car well not designed for straight line acceleration. I also seocnd the buying an 94-95 L Model...you'll save yourself a TON of money. can sawp all the RS looking parts onto it w/ a EJ22T or EJ20T for QUITE a bit less then the price of the RS alone. Oh and yes to run low 12's and ll's you had better bring your wallet.
Jeremy
Old 11-12-2001, 03:42 PM   #8
DanzBorin
Member#: 7131
2015 Outback - Croc
I believe MAFs are better for Turboing. Yes, they are fragile, and a pain in the a$$, but they measure airflow more accurately than the MAPs. I think my99 would be the best for a 2.5, but you will have to rebuild the engine to lower the compression ratio. If you can find a nice condition 2.2l Impreza, go with that. Looks can be added fairly easily and you will have an engine better suited for boost.
Old 11-12-2001, 03:44 PM   #9
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
as the old saying goes, there's no replacement for displacement... so, for an all out monster where money is no object, the EJ25 would be your best bet... it's gonna cost you tho to build it up. the 98 motors work fairly well for turbos because of their "low" compression... unfortunately the block itself hasn't proved to be as durable as the 2000's and 2001's... the problem w/ the 2000's and 2001's seems to lie the the compression of 10:1 and perhaps weaker pistons(probably related)... what else... there have been a couple people who swapped in EJ22 blocks from the early 90's turbo legacies... those will need some work too, to breath better, and still have a fairly high compression of 9:1, ithink, so you might want new pistons... I think alot of people have had problems w/ thier pistons dying in those... Trey Cobb seems to have the best parts, service, info about building the EJ25 up... www.cobbtuning.com good luck...
mrbell is offline   Reply With Quote
Can someone do a full carfax for me for free?? WRXINTX General Community 8 02-08-2007 03:38 PM
NOVA: New to the area, can anyone lend me a hand/tools? Schleppy Mid Atlantic Impreza Club -- MAIC 12 01-23-2004 04:54 PM
Can someone create a simple script for me ? Please! setiawani Off-Topic 18 08-13-2003 11:37 PM
Can someone check under their seat for me? AaronB Car Audio, Video & Security 4 03-13-2000 03:41 PM
