Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Commercial ECU Reflashes
Old 11-02-2006, 12:04 PM   #1
KazamaJin
Member#: 109876
1360 monkey power...
Thanks Dave Coleman...
Default EcuTek and TGV codes...
Can Ecutek delete TGV codes?? I have a "stage 2" reflash, and I'd like to fully delete and plug my TGV's. TD04 turbo--trying to do the "push-the-stocker-to-the-max!" thing. Everything's gonna be P&P'd and then I'm gonna go Pro-tune. Any help would be appreciated.
KazamaJin is offline   Reply With Quote
Old 11-02-2006, 10:47 PM   #2
Gethin
Member#: 2998
Yes, your tuner should have the basemap to delete the TGV codes.
Gethin is offline   Reply With Quote
Old 11-06-2006, 02:59 PM   #3
KazamaJin
Member#: 109876
OK then, so is that pretty much the popular opinion then??
Old 11-06-2006, 03:13 PM   #4
sonic rx
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
you tuner can make it so there is no code or cel light for tgv deletes. i have had it done. hell he can turn off every code and disable the cel if he wanted
sonic rx is offline   Reply With Quote
Old 11-06-2006, 03:19 PM   #5
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
ah, but when you go for emissions testing, does anyone know if will still be a problem with the CEL disabled and they still scan your OBD2 port? will it come back as not ready?
SBW is offline   Reply With Quote
Old 11-08-2006, 05:00 AM   #6
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
I think the 02 - 03 ECU rom's were more powerfull this is a feature were still lacking with the 04 - 05's ive contacted Ecutek about this last week and they will be getting back to me, im in the same boat.
Token-Negro is offline   Reply With Quote
Old 11-08-2006, 12:44 PM   #7
KazamaJin
Member#: 109876
please post as soon as you know...I am still seaching as well
Old 11-08-2006, 02:51 PM   #8
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
I just got off the phone with Ben @ Ecutek in Canada and he said they do have a rom that will do that and it was sent on my behalf to PDXtuing for use on my car when i go down next. So he says its avalible but i have to yet to confirm PDX did get the corret thing.
Old 11-08-2006, 04:31 PM   #9
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
PDXTuning has the 02-03 roms which include TGV CEL disable (run it on my car) not sure about the 04+ WRX roms
mick_the_ginge is offline   Reply With Quote
TGV codes and misfire code upon start up eliezerrosario Service & Maintenance 3 07-03-2009 05:27 PM
EcuTek...and TGV deletes.... imprezivSTi04 Commercial ECU Reflashes 4 06-08-2007 12:51 AM
Can Ecutek remove TGV CEL after sensor removal? lukeskywrx Commercial ECU Reflashes 3 06-29-2006 12:20 PM
2004 legacy tgv code p1090 help cmgtstan Normally Aspirated Powertrain 5 08-30-2005 01:53 PM
TGV codes P1092 P1093 help 6starspeed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-13-2003 08:35 AM
