Welcome to the North American Subaru Impreza Owners Club Friday August 1, 2014
Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 11-08-2006, 09:39 PM   #1
pjhe
Member#: 81725
73 zcar
amidst ls2 swap
Default twin scroll turbo with dual ball bearing options
what's out there? i've heard garrett makes some...
i'm looking for non-rotated perferrable
and i want a true twin scroll turbo, not a twin scroll header that feeds a standard housing turbo
so what's out there, i'll listen to rotated ideas too as long as they are no bigger then gt30-ish, as personnally i'm interested in spool (full spool by 3800rpms at the lastest and 3200-3400 being the tarket for full spool with it starting around 3000rpms), and big fat torque bands...
so list any and all twin scroll dual ball bearing turbos that are out there and their spool and power characteristics...
pjhe is offline   Reply With Quote
Old 11-08-2006, 10:01 PM   #2
solarin006
Member#: 109975
You can buy a GT30R with a twin scroll turbine housing (.78 A/R) off of atpturbo.com. However that is just the turbo, you'd need to get twin scroll headers, an uppipe, and a downpipe fabbed. Might be able to use something like the APS twinscroll headers and just have to fab the uppipe section.
solarin006 is offline   Reply With Quote
Old 11-08-2006, 10:10 PM   #3
pjhe
Member#: 81725
73 zcar
amidst ls2 swap
i can have plumbing all done at work (god i love my job and mandral benders)
Old 11-08-2006, 10:58 PM   #4
pjhe
Member#: 81725
73 zcar
amidst ls2 swap
thanks for the heads up on that, the gt3071 def seems like it'll be the way to go
Old 11-08-2006, 11:21 PM   #5
mdd1986
Member#: 83450
2000 Audi S4 Stage 3
not sure if this is in your price range but its what you are looking for. everything you need. http://www.automasterofwestchester.c...product_id=117
mdd1986 is offline   Reply With Quote
Old 11-09-2006, 09:00 AM   #6
pjhe
Member#: 81725
73 zcar
amidst ls2 swap
price isn't a problem i'll wait and save...
i'll def have to contact them and see if i can get certain pieces of/from that setup...
Old 11-09-2006, 01:40 PM   #7
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
IMO, the APS TSR70 would be a better kit than the Automaster and cheaper.
R0DENT is offline   Reply With Quote
Old 11-09-2006, 01:51 PM   #8
`04AlpineWhite
Member#: 65562
^I agree. It looks like there is a lot more piping on the Automaster header. The APS design is very similar to the Subaru twin-scroll header, where the runners are as short as possible, given the limited space in the engine bay and around the oil pan.
AVO has posted about a stock location twin-scroll series of turbos. They bolt-up to the stock JDM header and twin-scroll downpipe.
APS may also have a twin scroll version of the SR56 in the works, according to some posts in iwsti.
The stock location turbos from IHI that are twin scroll are the VF36, VF37 and VF42. The 36 and 42 are dual ball bearing, according to the MRT site. Power Enterprise has a turbo based off of the VF twin scroll series that incorporates a larger compressor wheel. On my 2004 STi, the VF37 delivers 1 bar at 2700 rpms (at over 5000 ft in elevation), so there is definitely room to add a bigger compressor wheel and still reach your spool goals.
HKS may also have some twin-scroll turbos available. But, these might be hard to get ahold of outside of Japan.
`04AlpineWhite is offline   Reply With Quote
Old 11-09-2006, 02:36 PM   #9
pjhe
Member#: 81725
73 zcar
amidst ls2 swap
thanks for the knowledge alpine!!
Old 11-09-2006, 03:23 PM   #10
solarin006
Member#: 109975
If you're going 30R, I'd get the 3076 instead of the 3071. Slightly large comp wheel, plus the anti-surge housing.
Old 11-09-2006, 03:27 PM   #11
Cooter05WRX
Member#: 110567
2009 JK
Sunburst Orange
www.rallitek.com has the AVO twin scroll set ups with everything you need.
Cooter05WRX is offline   Reply With Quote
Old 11-09-2006, 04:14 PM   #12
pjhe
Member#: 81725
73 zcar
amidst ls2 swap
negative on the 3076, that housing doesn't spool as nicely for my application/desire compared to the 3071 housing
the 3076 is a great turbo, but i want insta-spool haha
Old 11-10-2006, 12:28 PM   #13
wrxhard
Member#: 108091
I was going to suggest the twin scroll housing on a 3071r, but apparently i've been beat to the punch!!!
edit: garrett also makes an internally gated twin scroll called the gt32 i believe.
wrxhard is offline   Reply With Quote
Old 11-10-2006, 01:49 PM   #14
pjhe
Member#: 81725
73 zcar
amidst ls2 swap
you didn't miss the punch by much though i was just looking at the gt32 with both the 42 and 51 wheels...
it'll be a tough tough call between the 3071r and the gt32...
Old 11-10-2006, 01:53 PM   #15
pjhe
Member#: 81725
73 zcar
amidst ls2 swap
whats the advantage to going with a gt32 with an EWG versus using the 3071r which is already designed for an EWG?
Old 11-11-2006, 12:22 AM   #16
redrex2002
Member#: 118915
2002 wrx
srp
ok i am also interested in this answer and also where can you get a twin scroll gt32 kit and also is the gt32 and the 3071 stock location? or are they rotated
redrex2002 is offline   Reply With Quote
Old 11-11-2006, 01:44 AM   #17
nekdut
Member#: 91880
The VF38 and TD04HLA are also stock location twinscroll ball bearing turbos. Titanium turbine shaft as well. Definitely Instaspool®. 1 bar below 2000rpm with a 2.5L.
They aren't terribly large though, but you could stuff a larger compressor in there.
nekdut is offline   Reply With Quote
Old 11-11-2006, 02:17 AM   #18
wrxhard
Member#: 108091
neither the 3071r or the gt32 are stock location turbos. To my knowledge, gpmoto makes a gt32 kit as well as crawford (however i just found out the crawford kit is not a true twin scroll setup, as it uses a single up pipe, but it is stock location it looks like). The gt32 can be had as an externally gated setup, but that would add a bit of complexity to an already thought out solution in the form of the internally gated setup, IMHO. The 3071r is a complete custom job, however it may/may not bolt to the twin scroll APS header, but only comes as an EWG setup if you want twin scroll. Both of these turbos can be sourced from atpturbo.com. And in my opinion, if you're going to do that much work and are dead set on twin scroll, spend the extra couple hondo and spring for the dual BB 3071r (or 3076r) twin scroll, and you won't regret it. I believe clark did a test on the gt32 kit and it spooled very respectably i believe. I can't find it now, but i think it had green power with close to stock spool, and the 3071 being a tad more efficient all around (hotside, compressor side and dual BB) it should spool even quicker. (sorry, got long winded)
Old 11-11-2006, 11:34 AM   #19
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
I would wait about three more months on this. There seem to be many, many twin scroll turbo kits which will be released in the very near future (APS, AVO, ATP, etc...) and many have multiple turbos to choose from. I'm sure within 3-4 months test results of some of these kits will be showing up on this forum. You said you can wait so I would wait and see what's available soon, and then if you don't like what you see go the custom kit route you were thinking about.
SilverSurfer04STi is offline   Reply With Quote
Old 11-13-2006, 09:29 AM   #20
pjhe
Member#: 81725
73 zcar
amidst ls2 swap
wrxhard you nailed my thinking on the head, there not long winded either just good info... I'm thinking about buying an APS header and having my fab guy do a clone with a different flange on it that'll be gt30r friendly
and silver i'll def be waiting til after the first of the year to start picking up components (to use and admittly copy the design of with minor tweaks for my useage, note to vendors and manufacturers i won't be selling the clones i make, just shortening plumbing length or making the plumbing with with the fmic i plan on using and or with the rotated intake manifold and or using different materials...)
Old 12-14-2006, 05:32 AM   #21
Wrinkleboi
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
i didnt think the GT32 was ball bearing...
I am planning to do a twin scroll with a GT3076r or a GT3582r and I expect to have full boost around 3500 or 3800, respectively, although thats obviously just speculation. There's a thread in the Built Motor forum right now where a guy has a T/S GT40r and is claiming full boost around 4000 rpm... if thats true its really impressive.
Wrinkleboi is offline   Reply With Quote
Old 12-14-2006, 02:00 PM   #22
wrxhard
Member#: 108091
[quote=Wrinkleboi;16321476]i didnt think the GT32 was ball bearing...
QUOTE]
it isn't. sorry, i didn't mention that in my rant
Old 12-14-2006, 03:25 PM   #23
keaniegenie
Member#: 94494
2005 Element 92x
this was exactly what I use to look for. after doing research, I haven't seen any spool improvements with ball bearing turbos.
whether twin scroll helps is hard to tell. we'll find out when these rotated kits come out.
keaniegenie is offline   Reply With Quote
Old 12-14-2006, 08:40 PM   #24
WaXed
Member#: 88273
2003 STi 2.0L
GT32 or twinscroll GT3071R
GT32 - 64mm turbine wheel(76 trim), 71mm compressor (52 trim)
oil cooled, internal wastegate
GT3071R - 60mm turbine wheel (84 trim), 71mm compressor (56 trim), oil & water cooled + Ball bearing CHRA, requires external wastegate
GT3071 compressor can produse more boost pressure (above 17psi) at lower aiflows airflows and flow more HP more efficiently than the GT32...
to boil it all done the GT3071R twin scroll (based on GT30R technology) should easily out spool the GT32 as well as out perform on top end..
WaXed is offline   Reply With Quote
Old 12-14-2006, 08:57 PM   #25
WaXed
Member#: 88273
2003 STi 2.0L
is ball bearing better than journal bearing?
there is some information around to say it spools up faster.... lower friction
quite believable and I guess this is still debateable
A big benefit from Ball Bearings is they can take thrust loading.... I believe this is a big plus for a turbo... better oil sealing at the end of the journals and less friction from thrust washers...
All the high end IHI VF turbo's are BB... I think IHI do this for good reasons? it just costs more to produce....
I think if you got a bicyle with ball bearing wheels and took it for a ride then rode one with non ball bearings you will quickly realise it takes less effort with BB...
I personally believe once the turbo is spooled and on boost the difference is "negligible" as the energy lost on shaft friction is very small in relation to the actual power going through the shaft.. turbine/compressor operating efficiencies would be making the differences then
I think dyno plots would show this which gives the idea of no gain for Ball Bearing
but we are talking about improvement to spooling which is all important for a high performance street driver
AVO 450 turbo. stock location, dual-ball bearing garret gt30r based turbo! IIdiceII Tri-State Area Private Classifieds 13 08-12-2009 03:41 PM
Slow Boy Racing GT13 Dual Ball Bearing Turbo!! Kylar Engine/Power/Exhaust 21 03-28-2008 06:43 PM
VF22 Dual Ball Bearing Turbo... rocketsauce16 Factory 2.0L Turbo Powertrain 3 12-17-2007 06:55 AM
DP options for twin scroll turbo? John2.5RS Subaru Conversions 7 08-24-2006 12:14 AM
Dual Ball Bearing AVO GT30R turbo TurboBeast21 Private 'For Sale' Classifieds 18 10-05-2005 02:50 AM
