Old 11-12-2001, 06:20 PM   #1
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
Default chirping/creaking noise
it sounds like i got a little bird in my car..
i have a 2001 rs with4400 miles with a 5 spd... i am getting an unusual chirping noise ..i hear it while idle, louder when hitting bumps, going in/out of driveways, and even shifting...i have tried to locate where it is coming from but i only hear it while im in the car cause when i go outside to locate it the noise is drowned out by the engine noise....it seems to be in the center of the car, but i dont know if its behind the dash or in the engine bay...
help..
StarDogChampion is offline   Reply With Quote
Old 11-12-2001, 06:57 PM   #2
Surboo
Member#: 8721
1999 2.5 RS
Rally Blue
I have been hearing this too... it is terribly annoying. I too, would like to know what it might be.
-Brandon
Surboo is offline   Reply With Quote
Old 11-12-2001, 07:05 PM   #3
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
i found out the problem
the exhaust is squeeking as it moves...i guess i will try greasing the hangers.
Old 11-13-2001, 09:50 AM   #4
ImpreziveRS
Member#: 6312
2001 Impreza 2.5 RS
Blue Ridge Pearl
I have the same problem too!!!! Do you guys have an aftermarket exhaust? I can't remember if my car was making the noise before I put my new exhaust on. I can definitely tell that mine is coming from the rear of the car. I even took mine to Subaru and they said they couldn't find anything wrong. I'll try to fiddle with the exhaust today.
~Kyle
ImpreziveRS is offline   Reply With Quote
Old 11-13-2001, 05:09 PM   #5
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
mine makes the noise with the factory Subaru exhaust...
Old 11-13-2001, 05:20 PM   #6
CSM101
Member#: 2805
2001 Impreza 2.5RS
BRP
25000 miles, same noise, Brospeed cat back.
Thought it sounded like a exhaust hanger. One of these days I'll look for it and fix it.
CSM101 is offline   Reply With Quote
Old 11-13-2001, 06:31 PM   #7
Surboo
Member#: 8721
1999 2.5 RS
Rally Blue
I am running a Borla... I'll have to fiddle around under there after the car cools down tonight and see if I can't find the noise.
-Brandon
Old 11-14-2001, 02:28 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
well i had something like this...kinda funky but there is a wire loom holder mounted to the top of the trans and was not folded over properly at the factory so it was rubing the firewall everytime the motor shook....after it had rubbed thru the rubber coating it was scraping on the body....man how irritating that was.
jeremy
Old 11-14-2001, 02:36 AM   #9
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I bet it's the WRC Blow off Valve
Eric
Eric SS is offline   Reply With Quote
Old 11-14-2001, 08:53 PM   #10
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
well i went to the dealer today, and it was a wire harness on top of the tranny that was rubbing against the firewall....it too rubbed away all the undercoating...well now its fixed....woohoo
Old 11-14-2001, 10:50 PM   #11
DoorKnob
Member#: 395
2000 Impreza 2.5RS
Blue Ridge Pearl
You guys can try tightening the heat shields. I had a really nasty squeek every time i pulled away from a stop. Tightened the shields and elimintate the squeek.
Now if I could only figure out where this WOT exhaust sounding rattle is coming from....
~Alan
DoorKnob is offline   Reply With Quote
Chirping metallic noise from engine jshada Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-23-2009 04:59 PM
Weird chirp / squeak noise from exhaust on deceleration? Rexxxx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-25-2004 04:47 AM
chirp/cricket noise fix blaznasn General Community 4 05-15-2003 10:55 PM
Suspension making creaking noise rap4th Normally Aspirated Powertrain 13 05-03-2002 10:42 AM
