Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 11-09-2006, 10:44 AM   #1
bpwatts
Member#: 111635
Default UTEC Tuners or anyone with tuning experience...
So my post in the EM forum is going horribly slow and I have time to work on the car right now...
4th gear pull, 70 degrees F 65% humidity.
Car has the XS Power TMIC, TurboXS TBE with Prodrive axleback, TurboXS ABC, and the latest generation UTEC (not flashed to 5.8 yet).
Code:
 3005 -10.8 1.8   0  00    00   +23.4   10.3 ECU.   +0.0 ECU.   1.8  >25:1
 2944 -10.8 1.8   5  00    00   +28.3    5.5 ECU.   +0.0 ECU.   1.8  >25:1
 2949 -10.8 1.8   9  00    00   +38.7   11.8 ECU.   +0.0 ECU.   2.0  >25:1
 2947  -9.8 2.4  20  00    00   +45.3   18.3 ECU.   +0.0 ECU.   2.6  >25:1
 2978  -7.5 2.9  39  10    00   +34.3   19.5 +20.3  +0.7 ECU.   2.9  >25:1
 3033  -4.7 3.1  78  10    00   +26.7   26.7 +20.0  +1.4 325.00 3.1  15.50
 3132  -1.2 3.2  99  10    00   +21.6   30.8 +20.0  +0.9 325.00 3.3  13.92
 3192  +2.3 3.4 100  20    00   +16.0   39.3 +17.0  +0.8 325.00 3.5  12.68
 3333  +5.1 3.7  99  40    00   +10.7   47.7 +15.3  +2.0 325.00 3.9  12.25
 3397  +8.8 3.8 100  60    00   +10.2   57.7 +14.2  +3.9 325.00 4.0  11.96
 3519 +12.3 3.7 100  70    00   +11.2   64.7 +14.0  +3.4 325.00 4.1  11.27
 3623 +14.7 4.0 100  70    00   +11.3   63.4 +14.2  +3.1 325.00 4.0  10.53
 3711 +16.1 4.0 100  70    00   +13.2   66.1 +15.0  +3.0 325.00 4.1  10.29
 3866 +16.5 4.0 101  80    00   +15.9   70.2 +15.1  +3.2 338.00 4.0  10.23
 3992 +16.5 4.0 101  80    00   +18.1   70.2 +15.9  +3.2 338.00 4.1  10.04
 4055 +16.7 4.0 101  80    00   +19.7   72.2 +16.6  +3.0 338.00 4.2   9.93
 4156 +16.9 4.1 102  80    00   +20.1   72.8 +17.1  +2.7 338.00 4.1  10.02
 4257 +16.9 4.1 102  80    00   +20.3   73.5 +17.5  +2.5 350.00 4.1  10.14
 4363 +16.9 4.1 101  80    00   +20.3   75.7 +17.7  +2.6 350.00 4.2  10.27
 4504 +16.9 4.2 100  80    00   +20.6   79.6 +18.0  +2.8 350.00 4.2  10.33
 4553 +16.9 4.2 101  80    00   +21.1   84.4 +18.4  +2.6 350.00 4.3  10.30
 4694 +17.1 4.2 101  80    00   +21.5   85.8 +19.3  +2.2 350.00 4.3  10.12
 4796 +17.1 4.3 101  80    00   +22.0   89.2 +19.6  +1.6 350.00 4.3  10.06
 4909 +16.9 4.3 100  70    00   +22.7   89.3 +19.8  +0.7 350.00 4.3  10.09
 5050 +17.4 4.3 101  80    00   +22.4   85.2 +20.0  -0.2 360.00 4.3  10.11
 5159 +17.6 4.3 101  80    00   +23.0   88.4 +20.2  -0.2 360.00 4.3  10.26
 5120 +18.0 4.3 101  80    00   +22.9   87.6 +20.4  +0.2 360.00 4.3  10.45
 5299 +18.6 4.4 101  80    00   +22.6   91.7 +21.1  +0.0 360.00 4.4  10.49
 5464 +18.0 4.4 102  80    00   +22.4   92.5 +21.7  +0.1 360.00 4.3  10.39
 5537 +17.6 4.4 101  80    00   +22.2   93.0 +22.2  +0.3 360.00 4.4  10.36
 5583 +16.5 4.3 100  70    00   +21.9   91.7 +22.4  +0.1 360.00 4.4  10.39
 5659 +15.7 4.4 101  70    00   +21.9   95.4 +22.9  +0.0 360.00 4.4  10.39
 5757 +15.5 4.3 100  70    00   +22.2   93.8 +23.0  -0.1 360.00 4.4  10.39
 5827 +15.1 4.4 101  70    00   +22.5   94.2 +23.3  -0.1 360.00 4.4  10.39
 6016 +15.1 4.4 101  70    00   +22.6   94.1 +23.5  -0.1 360.00 4.4  10.42
 6006 +14.9 4.4 101  70    00   +23.0   94.0 +23.4  -0.3 360.00 4.4  10.42
 6027 +14.5 4.4 101  60    00   +23.5   95.2 +24.4  +0.3 360.00 4.4  10.39
 6116 +14.5 4.4 101  70    00   +23.9   96.2 +24.1  -0.2 360.00 4.3  10.33
 6253 +14.7 4.4 102  70    00   +24.9   93.6 +25.3  -0.3 360.00 4.4  10.30
 6325 +14.5 4.4 101  70    00   +25.4   93.4 +25.7  -0.4 360.00 4.4  10.34
 6397 +14.5 4.4 102  60    00   +26.0   96.9 +26.5  -0.1 360.00 4.4  10.42
 6535 +13.7 4.4 100  60    00   +26.8   95.2 +26.7  +0.0 360.00 4.4  10.40
 6447 +13.9 4.4 102  60    00   +27.4   96.2 +26.8  -0.2 360.00 4.4  10.36
 6600 +13.9 4.4 100  70    00   +28.2   93.0 +27.0  -0.5 360.00 4.4  10.42
 6613 +14.1 4.4 101  60    00   +28.7   96.2 +27.0  -0.2 360.00 4.4  10.49
 6830 +14.3 4.4 101  60    00   +29.2   93.9 +27.0  +0.0 360.00 4.4  10.55
 6872 +13.9 4.4 101  60    00   +29.3   91.9 +27.0  +0.0 360.00 4.4  10.55
 6958 +13.9 4.4 102  60    00   +29.3   93.2 +27.2  +0.0 360.00 4.4  10.59
 6872 +13.9 4.4 100  60    00   +29.3   92.6 +27.5  +0.0 360.00 4.4  10.67
 6535 +12.0 3.1   0  00    00   +22.8   11.8 ECU.   +0.4 ECU.   2.1  10.83
 6006  +5.9 1.2   0  00    00   +22.9    4.1 ECU.   +0.5 ECU.   1.1  11.98
It seems I've worked through my knock issues around 3500RPM. Concerns are now that I'm reaching 100% IDC when I have no business being that high. I need to calibrate TPS as well as I'm not hitting 100% load either.
Primarily looking for recommendations. Looks like I can advance some timing around 5000RPM to redline and add some boost. 3000RPM to 5000RPM seems to be happy now. I could maybe try spooling a bit sooner or pulling some fuel down low.
Seems to be able to hold about 18PSI with 10.5:1 AFR which is what I'm aiming for.
And here's a 2nd gear -> 3rd gear run:
Code:
 3005  -9.0 2.2  11  00    00   +46.1    6.4 ECU.   +0.0 ECU.   2.3  14.61
 3033  -8.1 2.6  28  10    00   +43.1   18.5 +20.3  +0.7 ECU.   3.0  14.53
 3153  -5.9 3.0 100  10    00   +32.5   25.0 +20.0  +1.2 325.00 3.1  14.45
 3363  -3.0 3.2 102  10    00   +28.8   35.7 +20.4  +0.6 325.00 3.4  13.59
 3565  +0.6 3.6 101  20    00   +21.5   45.9 +18.0  +0.6 325.00 3.7  12.46
 3792  +4.9 3.9 102  40    00   +14.0   65.9 +19.0  +1.6 338.00 4.0  11.80
 4161  +8.4 4.0 100  60    00   +18.1   73.7 +17.7  +2.8 338.00 4.2  11.05
 4415 +12.0 4.1 102  70    00   +20.4   76.1 +17.9  +2.8 350.00 4.3  10.46
 4755 +14.9 4.2 100  80    00   +22.0   86.6 +19.6  +1.6 350.00 4.3  10.42
 5144 +16.3 4.3 101  80    00   +23.0   89.5 +20.2  -0.1 360.00 4.3  10.34
 5428 +16.7 4.3 102  80    00   +22.4   91.8 +21.7  +0.2 360.00 4.4  10.46
 5767 +16.3 4.4 102  70    00   +22.0   94.3 +23.0  -0.1 360.00 4.4  10.62
 5920 +15.7 4.4 102  70    00   +22.9   93.3 +23.5  -0.1 360.00 4.4  10.52
 6242 +15.5 4.4 102  70    00   +25.1   91.9 +25.5  -0.4 360.00 4.4  10.45
 6548 +14.7 4.4 102  70    00   +27.4   93.8 +26.5  -0.5 360.00 4.4  10.46
 6858 +14.7 4.4 103  70    00   +29.3   88.0 +27.5  -0.5 360.00 4.3  10.52
 6958 +14.5 4.4 102  70    00   +29.3   87.1 +27.5  -0.5 360.00 4.4  10.78
 6887 +11.2 2.5   0  00    00   +22.9    9.6 ECU.   +0.5 ECU.   1.9  10.96
 6447  +5.5 1.6 105  10    00   +39.4   28.6 +28.3  -1.0 360.00 3.6  12.45
 5385  +3.1 4.1 105  10    00   +26.3   76.2 +23.6  -1.1 360.00 4.2  14.53
 5602  +2.9 4.3 107  40    00   +22.1   93.4 +23.9  +0.4 360.00 4.4  12.56
 5787  +6.5 4.4 108  70    00   +22.1   93.4 +22.7  +0.0 360.00 4.4  10.99
 5847 +12.7 4.4 107  70    00   +22.3   90.3 +23.0  -0.1 360.00 4.4  10.76
 5995 +14.9 4.4 107  70    00   +22.7   94.0 +23.5  -0.3 360.00 4.3  10.62
 6082 +15.5 4.4 107  70    00   +23.3   94.0 +24.1  -0.2 360.00 4.4  10.53
 6184 +14.7 4.4 107  70    00   +24.7   91.2 +25.1  -0.3 360.00 4.4  10.52
 6277 +14.3 4.4 108  60    00   +25.2   96.5 +26.1  +0.1 360.00 4.4  10.49
 6410 +14.3 4.4 108  60    00   +27.0   94.7 +26.7  -0.1 360.00 4.4  10.43
 6640 +14.1 4.4 106  70    00   +28.2   94.3 +26.7  -0.5 360.00 4.4  10.39
 6844 +13.9 4.4 105  60    00   +29.1   94.7 +27.0  +0.0 360.00 4.4  10.49
 6761 +14.1 4.4 106  60    00   +28.9   92.1 +27.3  +0.0 360.00 4.4  10.64
 7092 +14.1 4.4 104  70    00   +29.3   88.7 +27.5  -0.5 360.00 4.4  10.80
 6761 +11.8 2.6   0  00    00   +22.6   13.8 ECU.   +0.5 ECU.   2.0  11.02
 6435  +6.1 1.6   0  00    00   +22.8    7.4 ECU.   +0.4 ECU.   1.8  12.56
bpwatts is offline   Reply With Quote
Old 11-09-2006, 10:49 AM   #2
rudy_t2004
Member#: 77017
SO, you have a wide band thats giving you that A/F ratio? Have you done a TPS calibration, if not you may want to check out wrxhackers.com where they have a good amount of people there that could help you with that.
Rudy
Oh yea.... and doing to 5.8v will eliminate those nasty ol' knocks w/in the 3k rpm range. It is just a huge difference with the revision.
rudy_t2004 is offline   Reply With Quote
Old 11-09-2006, 10:54 AM   #3
bpwatts
Member#: 111635
Rudy
Yup, running the UTEC Tuner with a brand new O2 sensor. I've done a calibration already, that doesn't seem to be the issue. I think the boost thresholds may be off.
Boost is based off throttle position.
Load% isn't.
UTEC Tuner or maps for download TheReaper UTEC 10 08-01-2006 05:00 PM
A question for any manufacturers, sponsors, or anyone who is experiance with 2.5 RS DemonScooby South West Impreza Club Forum -- SWIC 6 09-11-2004 01:08 PM
UTEC Tuner or Delta Dash w/ LM1 dudical26 Engine Management & Tuning 1 05-21-2004 03:56 PM
Utec tuners, would anyone be willing to check out my logs? Im a newbie.. M32WRXin3seconds Engine Management & Tuning 8 09-24-2003 01:33 PM
Attn: SST, or anyone with Esplorer Sport Trac experience. Eric SS Off-Topic 16 06-09-2003 09:20 PM
