Old 11-09-2006, 07:27 PM   #1
scooterforever
Member#: 55011
Default More fun new problems... borked MAF? Suggestions welcomed
Edit: All better. Details in post #3.
Just started loosing power on WOT pulls tonight. No CELs other than a hidden P1094 for TGV delete (hidden via Street Tuner).
On successive short WOT bursts I felt noticeable power loss. AFR started dropping, 10.6... 10.5... when I saw a 9.6 I stopped testing. RPMs are strong, no transmission slippage (ATF is accurrately filled now, thank goodness), and boost readings are fine. EGTs are low, call it around 1,400, but I don't have a peak & hold gauge, so it's hard to tell for sure.
So... does it sound like I have a dead MAF? Car idles fine. No CELs other than the tumbler valve. Could a dead MAF start reading too high voltage? Which would then cause my injectors to add too much fuel??? Just brainstorming.
Thanks in advance.
scooterforever is offline   Reply With Quote
Old 11-10-2006, 08:47 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it sounds like a boost leak. can you pressure test the induction tract?
best way to test a mafs is to swap with a known good one from a buddy.
Old 11-11-2006, 04:10 PM   #3
scooterforever
Member#: 55011
Thanks for the suggestion, Ken. The problem solved -- it was either the MAF or the O2 sensor or both, but it's all better: I just pulled 4.78 MAF volts on a highway pull. I'm back!!!!!!
Details
At the suggestion of Crazymikie, I logged my AF learning + AF correction versus MAF voltage at low speeds, and they were all over the place. Mikie's conclusion was a bad MAF or O2 sensor or both, so... given that I have already sunk a fair amount into this new platform (and the idea of washing my cylinders sickens me), I figured I'd swap out the 4.5 year old 76k mile sensors and start fresh. Village Subaru in Acton helped me out and gave me really competitive pricing on a new O2 and MAF sensor, plus they were the only dealer within 100 miles to have both in stock. Props to Village Subaru!!!
This morning I swapped the MAF and the O2 sensor. Started up the car, let it idle, and sure enough the AF correction dropped once warmed up. Once warm, I changed my oil for good measure (didn't smell gas in it... but figured I'd start from scratch with fresh oil).
Test drive showed the car to be immediately responsive, back to it's old state of enjoyment. 4.78 MAF volts... feels ooo so good.
Blown95's sti- coils, lip, new trunk/exhaust etc. suggestions welcome.. Blown95ImpalaSS Member's Car Gallery 20 11-24-2008 03:56 PM
Tranny dying - suggestions welcome forced4 Transmission (AT/MT) & Driveline 0 09-03-2005 03:20 PM
My current mods.. and my plans for the future.. comments/suggestions welcome Soldier88 General Community 11 03-07-2005 06:20 PM
I need shoes. Suggestions welcome il96 Off-Topic 30 08-23-2004 05:18 PM
Cobb VS Others please suggestions welcome Mariuslt Normally Aspirated Powertrain 6 07-16-2004 06:46 PM
Message Board Statistics All times are GMT -4. The time now is 06:42 AM.
