Old 11-09-2006, 07:47 PM   #1
NW OBS
Member#: 101361
05 OBS
Obsidian Pearl Black
Exclamation Need Help On Setting/Changing Idle Speed On '05
I put in cams and the idle is 'lumpy' but the car runs great. My ECM cannot be set for idle speed ('07 you can). It is 'fly by wire' so there is no cable to screw with. I need to lift the idle speed from the OEM position of 500-600 rpms. At this low of speed I can watch the 'misfire' cell go out for all 4 holes. At 800 rpm and above the cells are not thrown!
So, I thought the answer was to change the 'bump stop' height on the pedal assembly, easy right? NOT. I need help for another solution:
I pulled the gas pedal assembly and it was very simple to change the 'bump stop' to have the pedal remaining pushed down a bit to give a 'mechanical idle' that should of got by the ECM... Nylon hammer attached to the gas pedal is slammed shut with two springs. There is a nylon wafer in there acting as the 'off' position for the gas pedal. Should be a simple matter of adding some material to the nylon, right?
With the ECM dialed into the 500-600 RPM idle I added material to the stopper (nylon).
I started with a small sticky circle felt pad (used for under ash trays, lamps... that sort of thing). Used the smallest (thinnest) one. RPM's jumped to 3200. TOO much!
Then went to a small sticky circle of Velcro®... felt side 1st (2800 rpm)... the hook side (2000 rpm).
Then tried a very thin piece if plastic, again 2000 rpm.
Then a small circle Band Aid®, down to 1500 rpm.
Then one die-cut sticker (just happened to have a circle), again 1500 rpm!
Did it again with nothing. Back to 500-600 rpm.
So I bailed on that strategy. It was never lower then 1500 rpm with anything on the stop!
I decided to go back to the Velcro® route and see if I reset the ECM to the 'new stopper' that might be the way. Went to the 'hooks' side for this. The car when I started it back up was trying desperately to '0' out my stopper. It swung wildly from 300 rpm to 1200 rpm and NEVER settled down. Went for a drive anyways... where ever the peak RPM was at a shift (when I would leave the clutch depressed) it would hold open. Same if I blipped the throttle to 4500, when I got back to the stop, the rpms stayed right at 4500!
So, mechanical fix doesn't look like it can be done...?
But I did figure out how to make it idle @ 900 RPMs!!!
When the air compressor kicks on for the AC, it send a signal to the ECM and it kicks the idle up 300 RPMs. Now, I need someone who can tell me which sensor wire it is on the compressor that goes to report to the ECM and what ohm the signal is that is thrown to the ECM. It seems it can be solved just like the resistor fix for the rear 02 sensor when you are running catless (with a PEP/resistor telling the ECM what it wants to hear)!!!
Now to find someone smarter then me to help with this matter! Any electrical gurus that might be able to help with the AC fix, or...?
NW OBS is offline   Reply With Quote
Old 11-09-2006, 07:58 PM   #2
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
which engine management do you have?
snwman is offline   Reply With Quote
Old 11-09-2006, 09:07 PM   #3
NW OBS
Member#: 101361
05 OBS
Stock OEM ECM ~ this is my problem. If I can't solve this any other way, then maybe I am going to have to look for a 'piggy back' for my '05 N/A so I can just set the friggin' idle speed!
Old 11-10-2006, 01:10 AM   #4
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
ohhh hmmm yeah that would be a problem... You could just drive with the AC on all the time lol. Where in the NW are you?
Old 11-10-2006, 01:33 AM   #5
Airboy
Member#: 72829
2006 WRX
2015 WRX
You could check over at enginuity.org. I think they have "definition" files to interpret the ECU image of the 2.5i.
Airboy is offline   Reply With Quote
Old 11-10-2006, 01:36 AM   #6
NW OBS
Member#: 101361
05 OBS
Wow! I am afraid I am not worthy... or am I insecure? Will hold up my hand and see if they can help me. Thanks.
Old 11-10-2006, 06:13 AM   #7
TheMadScientist
Member#: 23717
2005 Big red
Try the ecuexplorer. You used to be able to raise the idle with that, but it is tempory you will lose the setting when you reset the ECU.
TMS
TheMadScientist is offline   Reply With Quote
Old 11-10-2006, 07:53 AM   #8
UpPweez
Member#: 131712
Dude. Stop hacking. Just buy the tactrix cable for $80 and have the ability to reflash your ecu for whatever you want ... including the idle. ECUFlash + Enginuity = Powerful and Cheap.
UpPweez is offline   Reply With Quote
Old 11-10-2006, 12:10 PM   #9
NW OBS
Member#: 101361
05 OBS
Question
Tell me more! If there is a reflash option to be able to do this then I am all over it. But how does just a cable help me? Somewhat confused by that statement?
Just 'googled' tactrix and followed the links. ECUflash does no support the N/A motor, just WRX/STI, Forester XT and Legacy GT (at least according to their own Subaru chart.
Old 11-10-2006, 12:19 PM   #10
TheMadScientist
Member#: 23717
2005 Big red
Here is the list of ECU's that you can tune with Enginuity:
Supported ECU Revision List
The list of all currently supported revisions follows.
32BIT REVISIONS SUPPORTED
USDM
STi
2004 - A2ZJ500J, A2ZJ700J, A2ZJ710J
2005 - A2ZJB10J, A2ZJB11J
2006 - A2ZJE11J
2007 - A2UG0007
WRX
2006 - A8DH200X, A8DH201X
2.5i/2.5RS
2006 - E2VH202C
2005 - E2ZJ101G
FORESTER XT
2004 - A2ZJ201D, A2ZJ500I
2005 - A2WC410I
2006 - A8DH100I
LEGACY GT
2005 A2WC500N, A2WC500C, A2WC510C, A2WC510N, A2WC521C, A2WC521N, A2WC522N
2006 A2WF200N, A2WF200C
BAJA TURBO
2005 - A2WC501L, A2WC500L
OUTBACK XT
2005 A2WC511R, A2WC521R
2006 A2WF200R
EDM
STI
2006 - A8DH200Z, A8DG300G
FORESTER XT
2003/2004 - A2ZJ500F
2005 - A2ZJA10P, A8DH100P
ADM/SA
STI
2006 - A8DH200V
FORESTER XT
2004 - A2ZJ500M
2005 - A2WC420M, A2ZJA00P
LIBERTY GT
2003 - A2ZJ800G
2004 - A2ZJD02G
JDM
LEGACY GT
2005 - A2WD002T
2004 - A2ZJD00B, A2WD012A, A2WD010B, A2WD010A, A2ZJ601A
16BIT REVISIONS SUPPORTED
USDM
WRX
2002 - A4SG900C, A4SGA00C, A4SGC00C, A4SGD10C, A4SGE01C
2003 - A4TC101L, A4TC300L, A4TC400L
2004 - A4TF300E, A4TF300F, A4TF400E, A4TF500F, A4TF510F, A4TF520F
2005 - A4TH7000, A4TF800F, A4TF800E
EDM
WRX
2001/2002 - A4SE700D, A4SE900D
2003 - A4TE001G, A4TE100G
2005 - A4TE300D
STI
2001/2002 - A4RG060Q, A4RG060P, A4RN1000
2003/2004 - A4RM100H, A4RN200H
2005 - A4RN300G
JDM
WRX
2001/2002 - A4SD900A
2003 - A4SDA00P, A4TE000A
2004 - A4TE200A
STI
2001/2002 - A4SD900B, A4SDA01B, A4RG052N
2003 - A4SDA00Q, A4SDA01Q, A4TE002B, A4TE002C
2005 - A4TJ111B
2006 - A4TJ121B, A4TJ121C
ADM/SA
WRX
2001/2002 - A4SE700I, A4SE900I
2003 - A4TE001I
2004 - ARTH000O, A4TH000N
2005 - A4TH100H, A4RM200K
STI
2003 - A4RM100G
2004 - A4RN300I
If you car is on that list you just need to buy the openport cable, download enginuity and ECUflash and you can tune the ECU in your car.
TMS
Old 11-10-2006, 12:34 PM   #11
NW OBS
Member#: 101361
05 OBS
Wow! I am on the list '05 RS'. w00t!!! Now I get the cable and Enginuity is the software I want to use with it? Will google that next ~ maybe the 'reflash corral' at Subyfest next week would be able to help as well.
Old 11-10-2006, 12:42 PM   #12
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
IIRC Ecu Flash can't reflash the 05RS, but you can do it with ECU Explorer. Ecu Explorer can adjust the idle until the next ecu reset though, so you may not need to change your maps. But since you've got cams, changing your maps would most likely benefit you anyway.
Old 11-10-2006, 12:48 PM   #13
NW OBS
Member#: 101361
05 OBS
So ECUflash is out for my '05RS, but Enginuity and ECU Explorer can work with my car. Off to 'Google' ECU Explorer! Thanks.
Enginuity + Tactrix cable = $79.00
ECU Explorer + Tactrix cable = $358
Sort looks obvious which way to go eh?
Old 11-10-2006, 02:06 PM   #14
Airboy
Member#: 72829
2006 WRX
2015 WRX
The ECUexploer that is referred to in this thread is FREE and comes from here:
http://www.tari.co.za/cgi-bin/yabb2/YaBB.pl
It is not the one from APR that cost $279
Old 11-10-2006, 02:29 PM   #15
NW OBS
Member#: 101361
05 OBS
Thank you! So, it's either ECUexplorer + Tactrax cable or, Enginuity + Tactrax cable.
Since I use Mac/Apple I have downloaded Enginuity... now I need to upgrade my operataing system ($129) because it's a 'Jav'a based program that doesn't seem to like my 10.3 OX. Then i need to buy the Tactrax cable ($79), ALL just so I can bump my idle a few 100 RPMs ~ silly.
Need help with setting the backlash on the 6mt 1/500yellowwrx Transmission (AT/MT) & Driveline 6 03-11-2007 07:12 AM
Need Some Help On Setting/Changing Idle Speed on '05 NW OBS Normally Aspirated Powertrain 2 10-25-2006 11:41 AM
Need help for setting up tire pressure on Kumho V710 Modifying Motorsports 15 07-29-2006 02:36 PM
need help with wiring up a sub to '05 Leg stock HU phillywrx Car Audio, Video & Security 4 07-20-2004 09:27 AM
need a little help on setting boost vs speed on unichip HM3SC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-22-2001 08:05 PM
